Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. flatheadpete
    flatheadpete
    from Burton, MI
    Lookin' good! It's really cool to see the little details you've worked in that not everyone will notice.
  2. hot rod pro
    hot rod pro
    from spring tx.
    Thank you.
  3. hot rod pro
    hot rod pro
    from spring tx.
    Thank you so much.
  4. loudbang
  5. hot rod pro
    hot rod pro
    from spring tx.
    Thanks. Yea. I saw them. Charles does some great photo work
  6. hot rod pro
    hot rod pro
    from spring tx.
    Machined some more fittings for the AC and heater lines. ImageUploadedByH.A.M.B.1459180485.634205.jpg
  7. hasty
    hasty
    Just re-read the whole thread - inspiring! And dangerously close to completion... (will miss it).
    Thanks you for all the detail photographs of the work, really informative and hugely enjoyable to follow.
    Stunning workmanship.
  8. hot rod pro
    hot rod pro
    from spring tx.
    Thank you. I still have a lot of work to do. Stay tuned.
  9. hot rod pro
    hot rod pro
    from spring tx.
    More progress on the AC lines and fittings. #brucesrodshop #32mafia ImageUploadedByH.A.M.B.1460460729.472779.jpg ImageUploadedByH.A.M.B.1460460743.009388.jpg ImageUploadedByH.A.M.B.1460460753.751758.jpg
    loudbang, Pewsplace and 63fdsnr like this.
  10. hot rod pro
    hot rod pro
    from spring tx.
  11. Tim
    Tim
    from KCMO
    Loved seeing this in person only wish it was in some shade so I could have looked at it some more haha. Those back tires look perfect on the car but you really don't grasp how huge they are until your standing next to the car.
    Love it man this things gonna be a beast!
  12. Bader2
    Bader2
    *****in stance! Gonna be bad***!
    willysguy and loudbang like this.
  13. hot rod pro
    hot rod pro
    from spring tx.
    Thanks.
  14. hot rod pro
    hot rod pro
    from spring tx.
    Thanks
  15. hot rod pro
    hot rod pro
    from spring tx.
  16. Uncle Phil
    Uncle Phil
    Rust Holes Gone.....****....can you buy that in an aerosol? I'll take a couple of cases.
    bengeltiger and loudbang like this.
  17. hot rod pro
    hot rod pro
    from spring tx.
    Machined me a custom front brake kit for my spindle mount wheels. #brucesrodshop #32mafia ImageUploadedByH.A.M.B.1462496069.553120.jpg ImageUploadedByH.A.M.B.1462496081.333731.jpg ImageUploadedByH.A.M.B.1462496094.820435.jpg ImageUploadedByH.A.M.B.1462496107.618214.jpg ImageUploadedByH.A.M.B.1462496120.254323.jpg ImageUploadedByH.A.M.B.1462496134.355402.jpg ImageUploadedByH.A.M.B.1462496144.890194.jpg
  18. willysguy
    willysguy
    from Canada
    That's really trick Danny, great job!
  19. That's a neat bit of engineering right there.
  20. deucetruck
    deucetruck
    from Missouri
    True art on wheels ( no pun intended - well maybe a little!) :) Very neat.
  21. Just Gary
    Just Gary
    Beautiful work.
    A few questions:
    1) Did you consider using stock Ford spindles with the arms still attached?
    2) How much are your steering arms dropped to fit through the hairpins?
    3) Are those Wilwood brake calipers... with the logo ground off?
    Thanks!!!
  22. hot rod pro
    hot rod pro
    from spring tx.
    This is a 5" drop axle. Had I used a 4" drop I could have used stock spindles.
    Super Bell sells the arms flat for going over wish bones, for 4" drop axles, for 5" drop axles, and deep drop for going under wish bones. I used the ones for 5" drop axles.
    These are older Wilwood calipers, before they started putting their logo on them.
    Thank you for the questions. Glad you like the progress.
  23. hot rod pro
    hot rod pro
    from spring tx.
    Thank you.
  24. hot rod pro
    hot rod pro
    from spring tx.
    Just a little. [emoji41]
  25. hot rod pro
    hot rod pro
    from spring tx.
    Thank you. I'm trying my best not to cut corners or rush this thing, even though I want to drive it so bad!
  26. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Danny,
    Awesome Job on this one.......I'm jealous as hell!!......
  27. hot rod pro
    hot rod pro
    from spring tx.
    Thank you.
  28. hot rod pro
    hot rod pro
    from spring tx.
    Heater lines are finished on the motor. ImageUploadedByH.A.M.B.1465255287.127945.jpg ImageUploadedByH.A.M.B.1465255297.745640.jpg ImageUploadedByH.A.M.B.1465255306.779721.jpg
  29. 3wLarry
    3wLarry
    from Owasso, Ok
  30. alchemy
    alchemy
    Heaters in Texas?
