Hot Rods Hurst Style Engine mount design to use Mech Pump??
Discussion in 'The Hokey Ass Message Board' started by Aussie Chev, Apr 13, 2016.
  1. Aussie Chev
    Aussie Chev
    Hi guys
    I'm wanting to get a Hurst style mount drawn up and cut out but I want to access the timing cover and run a Mechanical pump. Running in 32 rails
    Pics or advice or a drawing would be sensational
    Thanks in advance
  2. redo32
    redo32
    Look up Industrial Ch***is in Phoenix.
  3. redo32
    redo32
  4. tfeverfred
    tfeverfred
  5. there supposed to be a spacer between the mount and the block that allows room for a pump
    OLSKOOL32 likes this.
  6. pitman
    pitman
    ~1/4 inch (6+mm) of steel
  7. Aussie Chev
    Aussie Chev
    That is nice...
    I'm over in OZ so I'm looking to fab my own over here.
  8. Aussie Chev
    Aussie Chev
    Another pic found on here
    Max Gearhead likes this.
  9. Jmountainjr
    Jmountainjr
    Build your frame mounts, set your engine height, and make a template. I cut this one from 3/8" plate on a band saw. You will need a 1/4" spacer between the block and the plate for a stock fuel pump.
    Aussie Chev likes this.
  10. 56sedandelivery
    56sedandelivery
    Check in with deto here on the HAMB, and his 49 Chevrolet Coupe build. He said he still has the specs/equipment to reproduce the one he made for his car, and still has the mechanical fuel pump. Nice work too.
    I am butch/56sedandelivery.
  11. Deucedreamer
    Deucedreamer
    from BC Canada
    I have a Hurst saddle mount in my Deuce. I have 3/4" spacers to enable me to run a manual fuel pump.
    slack, Aussie Chev and OLSKOOL32 like this.
  12. mgtstumpy
    mgtstumpy
  13. Aussie Chev
    Aussie Chev
    Same fentons as I have and plan to run :)
