  1. Barn Find
    Barn Find
    from Missouri
    I don't think they did have posi in the GM diffs used in the NAPCO trucks. What part of the video suggests otherwise?
  2. Barn Find
    Barn Find
    from Missouri
  3. Barn Find
    Barn Find
    from Missouri
  4. swi66
    swi66
  5. swi66
    swi66
  6. jimmy six
    jimmy six
    I wonder what happened to all these Jimmys with hydros and FWD boxes?
  7. Raiman1959
    Raiman1959
    That is sooooo cool!....not seen this before! Thanks!:D:D:D
  8. RichFox
    RichFox
    You would think they were for Army trucks.
  9. 56shoebox
    56shoebox
    I believe that is a 1968 "California" GS. The rally stripe along the rocker came on the California GS.
  10. seb fontana
    seb fontana
    from ct
    Thats what I think too..
  11. You'd be correct! WW2 Army Trucks.
  12. jcmarz
    jcmarz
    from Chino, Ca
  13. Larkster68
    Larkster68
    This is a ’68 Buick GS 400. This model only offered a convertible for the GS 400 and Skylark Custom. The GS California was only offered in a 2 door post sedan because it was basically a modified Buick Special.
    automaticslim and grifcarnut like this.
  14. Larkster68
    Larkster68
    [Q
    Cool, this looks like the high rise on Central Ave and Camelback Rd in Central Phoenix. I drive p***ed it quite often.
    UOTE="MiniCooperCl***ic, post: 11480318, member: 265718"][​IMG][/QUOTE]
  15. Larkster68
    Larkster68
    [/QUOTE]
  16. Barn Find
    Barn Find
    from Missouri
    WWII trucks would have been manual shift.
    The Korean era deuce and a halfs had the 302 hydro setup. I would have expected divorced transfercases, but I could be wrong.
    gas pumper likes this.
  17. Barn Find
    Barn Find
    from Missouri
    Now, I really want to know. I'm not convinced that is a 4WD transfer case. I don't see a forward output. They could have run dual rear outputs to tandem rear axles, but it almost looks like a single , offset output. Could this be for something that has two engines?
    The exhaust dumps on the front. It is not a water-cooled manifold like a boat, but it may have a port near the exhaust flange where you could inject seawater as in a boat. What is that long tube on the top?
  18. Chrisbcritter
    Chrisbcritter
    Awwwww. ;)
    (Hays, KS 1961. Getting more but I wanted to post this first)
    bedwards likes this.
  19. seb fontana
    seb fontana
    from ct
    Looking back at the pic I think I see reversed cooling fans so air would be pushed forward or away from the engine through the Radiator instead of pulling through towards engine..The top tube over the valve cover is from the thermostat housing..
  20. jimmy six
    jimmy six
    I know they were for WW II I was thinking surplus.....
  21. jimmy six
    jimmy six
    Or Korea
  22. Deepwater
    Deepwater
    from Tennessee
  23. Deepwater
    Deepwater
    from Tennessee
