thinking of upgrading from an A ****** to a later ****** with syncros...spotted this one for sale on Craigs list. Question is looks like it is designed for starter on p***enger side. Will this still work with driver side starter like stock A. If so I ***ume you would just ignore the bumpout for the starter.
Looks like a 60 hp ****** which has a smaller dia. Input shaft which would lead to couch disc issues I think you would be better off with a reg 39 ******,it has the same size clutch spline. Doug
A reg v-8 ****** is not a direct replacement for an "A" ******,,and yes,that ****** you found on C/L is for a v-8 60 hp.
Dennis Cling makes an adapter kit for V8 transmission to models A. https://www.clingsaftermarket.com/addtocart.asp?prod=43 John
or you can find a 32-34 banger trans and bell housing then fit synchro ge****t from later trans.... up to 48 car and 52 pickup or even lincoln zephyr, all fit (with some effort). Change to V8 flywheel and later clutch at the same time...you have to modify the banger starter...i.e. reverse the pinion. details are found in the banger meet archives.
What is the advantage to the V8 flywheel? Weight? I think I would go with a lightened Model A flywheel modified for a V8 clutch. Charlie Stephens
You might be wise to get Vern Tardel's book on the early Ford transmission, it'll save you in the long run.
Mitchell Manufacturing is building a Model A trans with synchros now that is a direct replacement for the regular non-synchro A trans. I think they'll build it with a longer ("Zephyr") second gear if you want. Expensive, but it'll byp*** a lot of the headaches of fitting a '39 trans.
Yeah I have Jim Brierlys book and it explains some of this stuff and ive looked at the Mitchell trans swap...little pricey, but the worst part is having to trade in a trans to get one as a core. I would like to have everything and do a swap without a bunch of down time waiting for parts and exchanging ******s and such...I don't know, still up in the air as to what I will do right now, with used 39s going in the $500 neighborhood and $400 for adapters and any used ****** would possibly need work or rebuild done, which adds up to even more, the Mitchell thing looks like it might be a good way to go. Looking at all options
The Mitchell is a real nice unit, we installed one in a customers car. First cl*** stuff but costly. Bob
Buy a junk trans on the HAMB want ads for the case trade in. ***uming your A is stock, a transmission swap to a V8 trans loses the pedals and radius ball mount, and the brackets offered in the kits look pretty shaky in comparison to stock.
This is a question I have never seen answered, how does the Mitchell compare to the '39 in terms of smoothness and shifting speed? Can a novice tell the difference? Is there anything you would notice in the course of normal street driving (not racing)? Charlie Stephens
