Projects 1950 Ford 16 inch wheels
Discussion in 'Traditional Customs' started by Doug Cook, Mar 15, 2016.
  1. Doug Cook
    Doug Cook
    Hey, Looking for Traditional Hubcaps for my 1950 Ford with the optional 16 inch wheels. Any ideas? Thanks, Doug
  2. 59ab
    59ab
    I too have a 1950 Ford with 16"wheels. They were standard equipment on the Deluxe series cars. Not much out there for 16" wheels. There are a few out there that were made by the Lyon corp. I see them sometimes at flea markets. Good Luck, Eddie
  3. 302GMC
    302GMC
    from Idaho
    Traditional was replace 16'' wheels with 15'' wheels ...
    Hnstray likes this.
  4. Hnstray
    Hnstray
    from Quincy, IL
    I bought a '50 Ford Tudor in 1958 and it had the 16" wheels. Couldn't swap 'em out fast enough.
    Ray
  5. Torchie
    Torchie
    You will find that full covers for 16" wheels are limited.
    Early Caddy sombreros. Some after market Lyons that you mat find on e-bay.
    Beware that many people list there covers as 16" because that may be the outside width but that means that is fits a 15" wheel. Covers for a 16" wheel are more like 17"s in width.
    I am running 16's on my early period custom and dealing with the same issue as you.
    Torchie.
  6. Dreddybear
    Dreddybear
    16" Shoebox wheels are awesome. Best thing you could do is chrome em! I'm running them on my coupe. For a while I was running Chromesides without the center cap:
    But now have switched to Lyons Full caps:
    I love them both equally and go back and forth over which I like more. If you keep your eye out, you will find a set. They are about equally rare...
  7. 562roadster
    562roadster
    glendale likes this.
  8. Mr48chev
    That takes me back to my teen age years when I pulled a pair of tires and wheels off an abandoned 50 Ford business coupe that had pretty nice tires and then found out that they were 16s when I went to swap the tires over to my rims for my 51 Merc.
  9. glendale
    glendale
    I have aftermarket sombreros on mine.
  10. Funny, when I was a kid the first thing to do on your newly acquired Ford was to dump the 16's and put on 15's. Now I see why guys were ******ing the 16" early Ford wheels I took to the swap meet before I got them out of the truck. Go figure.......
  11. mlewis114
    mlewis114
    from Omaha, Ne
    Just did the same to myself. Picked up a pair of nice 16's for $20 today. Looking for caps.
  12. A Boner
    A Boner
    Are there any "dog dish" caps that fit?
  13. Although most Fords had 15" wheels from '49 on, Ford made 16" wheels up through '55. Ford's last 16" wheels were available on '55 6 cylinder Mainlines. That's why the label inside the glove box door on my '55 has recommended tire pressures for 16" tires as well as the more common 6.70x15 that came on most '55s.
  14. chriseakin
    chriseakin
    Half ton International trucks in the 50s had the same bolt pattern as Ford (5X4.5) - my '57 has 16 in. wheels, so if you really want 16 in. wheels, check out IH trucks.
  15. Hnstray
    Hnstray
    from Quincy, IL
    Standard 'dog dish' Ford caps from '49 thru at least '56....very possibly thereafter as well for several more years.
    Ray
  16. mlewis114
    mlewis114
    from Omaha, Ne
  17. mlewis114
    mlewis114
    from Omaha, Ne
    I just found these 16's. Pretty excited for the eBay find. Not sure what they are ImageUploadedByH.A.M.B.1461205602.069481.jpg ImageUploadedByH.A.M.B.1461205634.555588.jpg
  18. Rusty O'Toole
    Rusty O'Toole
    I have heard that 16" and even 17" wheels were optional on most cars up to the late 50s. Usually ordered on station wagons for heavy duty use, or for extra ground clearance for rural mail delivery and the like. Don't suppose they were ordered very often. I have seen 16 and 17 wheels on half ton pickups and pickup based panel trucks and Suburbans made as late as 1968.
