Overhalling: How did day do dat
Discussion in 'The Hokey Ass Message Board' started by RodLand, Mar 7, 2006.
  1. RodLand
    RodLand
    Just watched the A build on Overhauling. Did not see the firsrt of it. Did I miss something?:D How did they use wide five wheels on a nine inch rear?:confused:
    The car looked Great!
  2. Terry
    Terry
    Funny, I was wondering the same thing!
  3. Dakota
    Dakota
    from Beulah, ND
    Speedway sells adapters to do that.... racecar stuff
  4. tommy
    tommy
    Had to be. It had discs on the front too.
  5. leon renaud
    leon renaud
    from N.E. Ct.
    hotrodding and circle track go hand in hand you realy need to check out some circle track parts suppliers. Need special brackets check out Lefthander Ch***is catalog. Wide five adapters ,wheels quickchanges etc.some are the same parts sold in streetrod catalogs at a lower cost !Circle track and Stock Car magazine are a good place to start
  6. Bugman
    Bugman
    The wide 5 pattern is very very common on roundy rounds. Makes for a very light wheel.
  7. rocknrods
    rocknrods
    Shhhhhhh;)
  8. seymour
    seymour
    from PNW
    bitter about something?
  9. KCRodder
    KCRodder
    No.
    Didn't know you could get wide 5 adapters from speedway though.
  10. specialk
    specialk
    From the OP
  11. kustom72
    kustom72
    Yeah, wasnt nuts over the disk brakes either, but at least they went I-beam and ditched the tube axle, and days of body work...that was an expensive build, dude was lucky, end results beat a hacked up sedan anyday. That dude sure showed some calm at the "inpound yard" I would have been arrested for sure.
  12. Gotzy
    Gotzy
  13. Tudor
    Tudor
    from GA
    I watched that show last night and thought it was awesome. It shows them old hot rod bodies ain't as easy to make purty as the muscle car stuff. It was the first build ever to over run.
    I think they did some awesome stuff. I have to say I did like the car alot before they even started.
    Chip was in there painting, cutting, bending - he ****ing rocks. Very cool guy. That hood was awesome.
    I really dug the old Y block build. I was wondering how they did the wheels too. Thanks.
    I'll bet old Charlie sleeps a lot better now.
    My wife said the fire wall was too much. I liked it though.
    That episode really shows how much work it takes for one man to build a car in his own little shop. Think about it, they had somehting like 35 people on that ****er for 8 days. Say they had 16 hour days - that's almost 4500 man hours. - thats 112 (40 hour) weeks or over 2 years for one man putting in straight 40 weeks.
    Now do that in your garage by your self with a normal job and family.
    It's Crazy.
    Oh yeah - 4500 hrs x 50 bucks an hour = $225,000. That doesn't even include parts.
    50 bucks an hour may be cheap for some of the **** they did. And people think you are ****ed when you want to sell a built car for 30K.
  14. krylon32
    krylon32
    from Nebraska
  15. A few years ago-I made one from 1/2" flat steel plate cut in a circle.....two patterns were drilled-.5lug 0n 5-1/2" and 5lug on 10-1/2" patterns-larger pattern had lug bolts pressed in from the rear on the wide five side and drilled holes for the rear end hole's pattern...........it worked great and was cheap to make.
      66.2 KB
  16. If the IRS uses that formula to calcuate labor as income, that dudes now got a tax bill somewhere in the neighborhood of "Grasp ankles firmly!"
  17. brandon
    brandon
    looked like at the end it had buick drums on the front.....or possibly socal functional fakes....brandon
