Features The Official [Ed] Winfield Speed Equipment Thread!
Discussion in 'Traditional Hot Rods' started by gwhite, Jul 3, 2013.
  1. 62pan
    62pan
    Check the plugs on the bottom of the float bowls to make sure they match the bowl. Even though the bowl is marked B you could have BB tubes in the accelerating wells. I run BB tubes in my B float bowl. The plugs should be stamped on the bottom.
  2. 62pan
    62pan
    Both my BB S models and one BB SR model have the same choke disc. One thing to note is I found that if you crank more than one or two times with the choke on this will flood your engine quickly.
  3. waxhead
    waxhead
    from West Oz
    62pan Thanks for the fast response. The SR carb B float is stamped with a B. The S-BB carb float is stamped BB. I pulled them and the SR and S tubes are different and can't be swapped, but you probably already knew this.
    SR B carb tube
    S-BB carb tube
  4. john mullen
    john mullen
    I was wondering while we are on the subject of Winfield speed parts if anyone knows what cams he was grinding for the flathead 4 banger or flathead v8,s running at Bonneville. I have one of his SU1-A cams and like it very much but what it was ground for I haven't a clue maybe oval track, maybe drags...don't know ... wondering what he would have ground for wide open throttle engines used for top speed record attempts
  5. 62pan
    62pan
    John, Best deal to do would be to contact Jim Brierley about his cams. I have one of his cam list and for Bonneville or Dry lakes four cyl flathead he list a No. 410 FI, duration is 288 and lift is .410 Not sure if this is a Winfield grind or one of his own.
    Are you running the 1A on the street? Any problems with idle?
  6. john mullen
    john mullen
    IMG_2494.JPG IMG_2434.JPG Yes I run the SU1-A on the street..1952 8rt .060 over w/3x2- 94s, Edelbrock alum heads, reds street headers bubba's dizzy... The idle is somewhat rough but very manageable. idle speed is 800 rpm. I have it in my 52 f1. and drive it everywhere. It is sensitive to high al***ude above 3500 feet hear in Virginia. I live down on the coastal plain and its jetted for that. I'm sure a jet change would help it at high al***ude but I drive mostly down on the low land .
    303racer likes this.
  7. flatjack
    flatjack
    I run a SU1A in my 39 with a 276 engine and 390 Holley carb. Love it.
  8. 97
    97
    alanp561 likes this.
  9. Equipped28
    Equipped28
    I'm thinking of selling these. 2x NOS never used Winfield D throttle body's With choke horns. Pretty rare I'd say. Open to offers as not sure what they'd be worth. ImageUploadedByH.A.M.B.1453752822.868730.jpg
  10. brasscarguy
    brasscarguy
    from seattle
    I have a Winfield model O barrel throttle aluminum carburetor. I have it on my 1928 Chevrolet sprint car. Does anyone have any information on the Winfield "0". I am having too much fuel dump on heavy acceleration causing lots of black smoke and fouling. Hope to find the answers.
    br***carguy@Comcast.net
  11. richardusa
    richardusa
    I need some old juck like that
  12. RainierHooker
    RainierHooker
    from Tacoma, WA
    I finally joined the carb club last month...
    I've got the RayDay head, Winfield intake, and Cyclone Winfield-to-Stromberg Adaptor that all came off of a hot-rod Roadster Pickup back in '56. So the question is, do I run the what I've got now with the Stromberg as it all was in the '50s? Or do I just go all elitist and throw the SR up on there?
    waxhead and Tiny like this.
  13. Hitchhiker
    Hitchhiker
    not really enough carb for that ray day head.... imo
  14. 62pan
    62pan
    I've seen Winfield ads where you got a 6-1 head, intake and a B carb as a package deal. I'm sure it will work just fine. You can always add BB tubes to upgrade.
  15. T__N__A
    T__N__A
    Winfield Powered Banger!!
  16. RainierHooker
    RainierHooker
    from Tacoma, WA
    There's the rub, my Ray Day head is an 8.3:1 compression ratio. Might be looking for some BB stuff...
  17. Hitchhiker
    Hitchhiker
    @Rainier****** I have a BB updraft we could hang that downdraft bowl on.
  18. Hitchhiker
    Hitchhiker
    I've heard that before as well and also heard that the C was offered with the 7:1 redhead.
  19. 12secvx
    12secvx
    I found this intake at a swap meet today. It has me a little puzzled though as it doesn't look like all the other Winfield A/B intakes I have seen. It doesn't have the linkage bosses cast into the bottom and no size stamped into it. The carburetor opening measures 1 3/8" whichI have read is a BB. Any help is greatly appreciated.
    ImageUploadedByH.A.M.B.1462657988.062045.jpg ImageUploadedByH.A.M.B.1462658014.771773.jpg ImageUploadedByH.A.M.B.1462658029.979428.jpg ImageUploadedByH.A.M.B.1462658044.186138.jpg
  20. waxhead
    waxhead
    from West Oz
    Looks like my A/B Winfield BB intake except for the flat plate, instead of the threaded holes. I am not at home to confirm intake opening size, but as you have stated, should be 1 3/8" for a BB carb. I have attached a couple of pics of my BB intake. Yours is the first intake I have seen without the bosses. I had always ***umed the bosses were for bolting to the stock exhaust manifold. Nice find by the way.
  21. waxhead
    waxhead
    from West Oz
    Did you end up running your Winfield carb ??
  22. 12secvx
    12secvx
    Thanks it was a good deal even though I do have a Winfield carburetor to go with it. I still couldn't p*** it up. Has anyone adapted any other carburetor to this manifold with success? I have stromberg 81, 97, and the a Plymouth Carter which I thought would be the easiest to make a bolt on plate for.
  23. waxhead
    waxhead
    from West Oz
    I was planning on running a stromberg 97 on my Winfield intake, before I managed to get my hands on a winfield BB carburettor. I seem to recall that Winfield (or someone else) may have even made adapters for this back in the day. I may have some part numbers/info on the adapters in my file of winfield info at home. Unfortunately I am away at work. I was planning on buying an adapter similar to the offenhauser one in the link below and fabricating an adaptor plate. Another option might be to get BCCHOPIT here on the HAMB to fabricate you an adapter to use.
    Will be interested to hear how you get on.
    http://www.offyparts.com/product_info.php/products_id/118
  24. RainierHooker
    RainierHooker
    from Tacoma, WA
    Unfortunately, since I'm on the opposite side of the planet from my garage, I haven't yet. I still have a few more months in which to waffle...
  25. 28downunder
    28downunder
    Here's my collection of Winfield parts, I'm still on the lookout for a complete down draught S or SR carburetor in either B or BB in size! For the moment I'm going to run a Stromberg 97 on an adapter to to the Winfield intake on my 4 banger. Hopefully I'll find one soon!
    ImageUploadedByH.A.M.B.1462712022.896556.jpg ImageUploadedByH.A.M.B.1462712046.228188.jpg ImageUploadedByH.A.M.B.1462712069.062889.jpg ImageUploadedByH.A.M.B.1462712089.392938.jpg
    Outback, Tiny, waxhead and 1 other person like this.
  26. orangeamcs
    orangeamcs
    Trying to I'd this winfield cam
  27. waxhead
    waxhead
    from West Oz
    Finally got all of my Winfield goodies bolted to my banger, and it is now running.
  28. rtsidejohnny
    rtsidejohnny
    Beautiful waxhead! I have almost the same setup I'm hopeing to have on the road soon.
    I notice you're not using small blocks on the other side of the manifold mounting bolts...I thought those were needed. Not so?
    Johnny
  29. waxhead
    waxhead
    from West Oz
    Thanks mate. I am using blocks on the other side of the manifold mounting bolts. They are hard to see as they are black. You might be able to see them better in these pics.
    1928Fordman and dana barlow like this.
  30. rtsidejohnny
    rtsidejohnny
    I see them now. Welded to the flange, good idea. Thanks for the follow up, and PLEASE let us (me) know how she drives with that great looking setup!
    Thanks, Johnny
