Features The 1955-1956 Plymouth and Dodge Thread
Discussion in 'The Hokey Ass Message Board' started by MrBelvedere2, Feb 12, 2009.
  1. Hillbilly Hauler 61
    Hillbilly Hauler 61
    I am new to this forum and have found this very helpful. I plan to buy a 56 savoy 4dr rollin body in a couple of weeks. The guy i work with is holding it for me. Here are a few pics as it sets on a farm. I plan to put in a 78 rv 318 eng and trans. Supposedly all parts are there except engine and trans. DSC05668.JPG DSC05664.JPG DSC05666.JPG DSC05667.JPG
  2. Old Ray
    Old Ray
    That is a very nice old girl, ..................thanks for posting the pictures.
    Good luck with the project. :)
  3. da dodge brother
    da dodge brother
    from wisconsin
    Plan on changing the rear end also. You will find out about some really weird U-Joints if you don't. Also you will get rid of those dual cylinder rear breaks. Trust me on this and make your job a lot easier. And if you are going to lower it go to 14" wheels, chip one coil from the front and 2" blocks in the rear. Works just right ...
  4. Hillbilly Hauler 61
    Hillbilly Hauler 61
    Thanks!!!
    Thanks for all the good advice, The guy who owned the car before has a disk conversion i plan to get for the front. Hopefully i will be getting a 78 rv with a 318 2bl 727 i think 60,000 miles. it has a leaky roof so hes disgusted and said he would sale for $200. theres alot of parts i can use there.
  5. Hillbilly Hauler 61
    Hillbilly Hauler 61
    Thanks!!
  6. Hillbilly Hauler 61
    Hillbilly Hauler 61
    Ok, got the rv home it has a 318 with 37,o 000 miles i think it has a 727 i plan to strip out the wiring and the speedometer as it will work with the ******, also plan to use the master cylnder and booster.
  7. t-rod
    t-rod
  8. Hillbilly Hauler 61
    Hillbilly Hauler 61
    I have been working on placing a 318 and a 727 auto in my savoy. Does anyone have a good pic of their engine mounts and trans mount? I am thinking it may be really close to the drag link i have the engine almost in and i have removed the top of the trans tunnel so far. Any advice/help is appreciated. Thanks in advance.
  9. George
    George
    On my '60 Plym I used the drop down loop with the horizontal tube type ****** mount (truck?) and modified the OEM ****** crossover to where there would be a verticle steel plate @ each end of the tube. Then drilled the plates for a long bolt through the tube.
  10. Powerflite
    Powerflite
    You shouldn't have to cut the floor at all. You just need to use the proper oil pan with a front sump on it. The front sump oil pan should fit right where the original poly motor oil pan was.
    Hillbilly Hauler 61 likes this.
  11. George
    George
    Floor was probably for ****** clearance, though it shouldn't have been necessary.
  12. Hillbilly Hauler 61
    Hillbilly Hauler 61
    sadly this savoy had its 277 sold before i got the body so i did not know of the front sump oil pan that seems right as the drag link looked like it was gona hit the rear sump pan so thanks alot on that. I will search summit/jegs for a front sump pan. I also understand about the trans mount but what engine mounts do you guys use? I have an old friend that has some health issues but said maybe he could fab some up if and when he feels good enough to visit. If i had a good picture of the application i could prob copy myself, You guys are great thanks so far.
  13. GaryS
    GaryS
    I have '66 engine with 727 that is going in my '56, and the stock '66 pan fits fine. I changed the motor mounts to the spool style. The transmission mount is in a different location, so I made my own using the '66 bracket on a custom crossmember. The engine has been fit checked in place, but without the transmission. If interested, you can see pictures in my blog: http://56plymouth.blogspot.com/
    Old Ray likes this.
  14. Hillbilly Hauler 61
    Hillbilly Hauler 61
    Thanks alot very good pics and even better writing. I will be visiting this page often. Great writing and great info. Thanks again!!!
  15. Old Ray
    Old Ray
    Garry, thanks for posting your blog info, great stuff and of much ***istance with my project. :)
    I sent you a private message (I think).
  16. blazin6969
    blazin6969
    from NePa
    Hey guys got a savoy I am going to be parting out soon. I'm taking the drive train. And crushing the car in a few weeks.
    Moldings look good they were taken off and placed inside the car.
    Let me know if anyone needs anything.
    Sent from my SM-G935T using H.A.M.B. mobile app
    stillrunners likes this.
  17. renee stampone
    renee stampone
    Hi guys! Hopefully you can help a gal out, does any one have the 55 dodge shop manual? I am going to order one (they go for 45.00 to 95.00!) I just need the page for the gas gauge and sending unit. Have a great day!
    Sent from my SM-N920V using H.A.M.B. mobile app
    aguynamedcj likes this.
  18. Phillips
    Phillips
    This 55 has been on the Quad Cities c*list for months, cheap!
  19. aguynamedcj
    aguynamedcj
    Have one at the house in TX. PM me and I'll see if the ol' lady can scan the right pages. Whats the question, though?
    Sent from my SAMSUNG-SM-G900A using H.A.M.B. mobile app
  20. aguynamedcj
    aguynamedcj
    What's the story on this girl? Can't find the Cl ad.
  21. aguynamedcj
    aguynamedcj
  22. stillrunners
    stillrunners
    from dallas
    ok guys you can get jealous now....
  23. stillrunners
    stillrunners
    from dallas
    little hint....
  24. gonmad
    gonmad
    Update on my buddies 55, he did the roof!
  25. FinnishFireball
    FinnishFireball
    gonmad now we're talking, congrats to your buddy!
  26. Dan Timberlake
    Dan Timberlake
    Some 50s Dodge and Plymouth manuals here -
    http://www.mymopar.com/index.php?pid=109
    regards,
    Dan T
  27. stillrunners
    stillrunners
    from dallas
    took two evenings to clear out the boxes of parts from the inside and the trunk.....damn if I didn't find my old train set....last worked the floors into it back in 1998 the year my mom pasted - had it stored over at her/our house...
  28. stillrunners
    stillrunners
    from dallas
    funny every window but the windshield was busted out and before I could get the guy to sell it - his ex son-in law set his field full of cars on fire....part of the bottom patinia you see is paint burn....is no one getting excited ?
  29. Rusty Karz
    Rusty Karz
    Always great to see some one save one. Looks like you have your work cut out for you but much worse ones have been resurrected. Keep us posted.
  30. thunderplex
    thunderplex
    Take digital pics of the pages. Scanning is digital. Digital is digital, just be sure you use as many pixels as possible for reading.
    Sent from my SM-N910V using The H.A.M.B. mobile app
