1952-59 Ford IFS for 52
Discussion in 'Off Topic Hot Rods & Customs' started by stonemck, Apr 23, 2016.
  1. stonemck
    stonemck
    from Anna, TX
    Looking for full replacement IFS front end for my 1952. I know Fatman makes one but it crazy expensive. Anybody else out there make a cut and weld version?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Having owned four '53 Fords (kingpins) and three '54 Fords (IFS) the difference in ride was not noticeable they both shared the same front springs and shocks,so what do you hope to gain from spending a bunch of loot ?
  3. Edsel58a
    Edsel58a
    I'd swap in a 54 ford front end.
    voodookustoms likes this.
  4. stonemck
    stonemck
    from Anna, TX
    I appreciate the comments and yes I have thought about those options, really looking for the answer to my question at this time.
  5. Paul2748
    Paul2748
    Ford had IFS's from 49 to present. The difference is the 49-53 used king pins, the 54 to ?? used ball joints.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Fatman independent front suspension is probably the least expensive one on the market,Heidts is the only other that I am aware of and they don't offer anything for your car.
    A less expensive alternative may be a frame swap,the '54 model was the first year Ford introduced independent front suspension incorporating ball joints. HRP
  7. cb186
    cb186
    My guess is that he wants something from a more modern car.
  8. evintho
    evintho
  9. Paul2748
    Paul2748
    And a lot of these "swaps" end up on ebay or Craig's List because the work involved got to be too much.
  10. stonemck
    stonemck
    from Anna, TX
    I'm going with a LS 5.3, power steering and AC so there's going to be lots of mods anyway. I'll talk to the shop I'm looking at doing the work about the above options. Keep the feedback coming, lots of good thoughts.
  11. bobss396
    bobss396
    I would look into a GM clip. The track width is critical with these swaps, so do your homework. I'd look at metric donors, like a 1985ish Monte Carlo or later Camaro. The removable stub may be the way to go.
    I saw a very neat clip years ago, a 1975 Torino on a '58 Ranchero, very nicely done and gave the owner all the modern perks, AC, PS, PB and so on.
