Technical *** APRIL 2016 BANGER MEET - DON'T BE FOOLED BY SUBSTITUTES ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2016.
  1. 97
    97
    He walks the walk too and has done for years, way before Trad hot rods became popular ... here is his 29 closed cab shop truck... Riley OHV , twin SUs , on a G28T and an OD trans behind one of his own bellhousings.
    It's not new , been around for years.
    ROCKER77, Wardog and waxhead like this.
  2. colinsmithson
    colinsmithson
    97
    You were sayin' ?:cool:
  4. Binger
    Binger
    from wyoming
    I am sorry I didn't know about those products. I will definitely keep them in mind!
  5. noboD
    noboD
    Pretty slick!
  6. :D:D
  7. Will Kimble
    Will Kimble
    Hello banger friends,
    I am looking for a wide front motor mount for a Model B engine, I believe they are from '33-34 and the holes are 19" apart - does anybody have one they would like to sell?
    Thanks,
    Will Kimble
  8. orangeamcs
    orangeamcs
    My 32 mount is 12" apart and fits in the model a crossmember nicely
  9. winduptoy
    winduptoy
    He is running a Holley 94 that we have dialed in with an exhaust gas ****yzer. We both have real steep drives, 18% at one point. Creeping along my car, set up basically the same way but an A engine, pulls good at 600 to 800 RPM. He had to run faster up the hill or stall. The only real difference in the engines is the cams. I'm running a 'B' grind.
    We both have A transmissions and I am running a 3:78/1 rear end ratio and he has 4:11. I have smaller rolling radius on my tires but my final drive ratio is a little higher.
    He has a 4 into 1 header and gl*** pack
    I have stock exhaust
    Come try my driveway and a hill that we call 'Heart Break Hill' that is 9% for just under a mile, I out pull him.
  10. T__N__A
    T__N__A
    Finally got the Gerber Special running. model T with a SR fronty head.
    Jet96 and Tiny like this.
  11. That sounds pissed!!!
  12. V4F
    V4F
    from middle ca.
    that is really cool . happy for you ................... steve
  13. Binger
    Binger
    from wyoming
    I have never heard a T that sounds like that! awesome!!
  14. hotrodA
    hotrodA
    Pretty torquey, especially on the floor jack. Sounds perfect!
  15. denis4x4
    denis4x4
    from Colorado
  16. waxhead
    waxhead
    from West Oz
    Awesome
  17. I' running a 1A in my lakes modified and while it is not driven on the street it is a very tractable engine. It will idle around 600 w.ith dual C's
  18. 62pan
    62pan
    Thanks Bill, I was planning on two BB's so it sounds possible.
  19. V4F
    V4F
    from middle ca.
    Chocolate Myers explains in the do***entary clip above:
    "We're racing at Richmond, and he's got the car -- it's totally covered in mud -- and he hollers on the radio, "Richard, I need to pit." And Richard says, "Dale, I'd hate to come in and pit, lose all that track position." And Dale comes on the radio and says, "I'm gonna be off the radio for a few minutes." And then you see Dale driving with his knee and got one head and he's cleaning the windshield off." * Richmond*
    GOT TO LOVE THE MAN ................... steve
  20. V4F
    V4F
    from middle ca.
    I also have my motor (front) on 55 chevy rubber donuts . works fine
  21. Will Kimble
    Will Kimble
    Think I got it figgered out....
    Tiny likes this.
  22. V4F
    V4F
    from middle ca.
    that will be great ! my stuff works , but not pretty like that .............. steve
  23. Dustyp489
    Dustyp489
    On the t-5 ,I used a Miller- High speed Head company Adaptor plate with a AA bell which moves the 88 s10 trans up about an inch . this set up uses a stock clutch disc and plate that I got from speed way . Has the open drive to the quickchange peddles are on a bracket that comes with the kit Bill Sheer was great to Deal with
  24. V4F
    V4F
    from middle ca.
    went to F.A.S.T. hill climbs today . great day . saw some awesome OHV,s there . surprising to me was how fast the bangers with a c-4 were . great stuff ...........
  25. I had a blast! I know I'll be building a new rear end with one of my 201's and a locker!
  26. GASSERBOB
    GASSERBOB
    from USA
    Looks like you had a good time Joe. That thing is bad to the bone. What trans did you put in there? Bob.
  27. Thanks G***ERBOB, I had a BLAST!!!!!! I'm running a 39 trans with a Clings adapter. I'm looking forward to the next race but I need to use some different tires, maybe some HURST PIE CRUST cheater slicks and weld my spider gears? Ha Ha, I do have QC though! An LSD is what I really want! or a Spool if I have too!?
  28. briphaeton
    briphaeton
    from cal
    Did you win your cl***? Sounds great!
  29. V4F
    V4F
    from middle ca.
    ask him about his right rear tire wear !
  30. briphaeton
    briphaeton
    from cal
    Better time without the tire spin
