Projects Rob Bobs 1932 truck part 2
Discussion in 'Traditional Hot Rods' started by rob bob, Nov 14, 2014.
  1. gordspeed
    gordspeed
    from Oregon
    I am waiting with great anticipation! Sure is looking good so far rob bob! :)
  2. rob bob
    rob bob
    from Canyon TX
    Thanks! its getting closer.
    Sent from my LG-MS870 using H.A.M.B. mobile app
  3. enloe
    enloe
    from east , tn.
    This pic looks like a model diorama.
  4. Paint work looks beautiful! Keep doing what you do!
  5. rob bob
    rob bob
    from Canyon TX
    In a weeks time I pulled my frame apart and got it painted. ImageUploadedByH.A.M.B.1461596845.791070.jpg I sanded everything to get the frame as clean as possible before I sprayed the epoxy sealer. ImageUploadedByH.A.M.B.1461596981.955087.jpg Here it is with two coats of sealer. ImageUploadedByH.A.M.B.1461597870.657214.jpg I let the frame sit overnight then sprayed 3 coats of 2k primer over the epoxy let it sit for a few days and it's ready for final sanding with 400 grit on the DA with interface pad. ImageUploadedByH.A.M.B.1461598042.185602.jpg ImageUploadedByH.A.M.B.1461598069.615922.jpg Now it's ready for paint.
  6. rob bob
    rob bob
    from Canyon TX
    My paint store let me demo some Spies Hecker 8180 clear this is a high end, high quality clear. I have to say this stuff is amazing it goes on easy, drys super fast, hard to run. I made the decision to clear the cab and flow coat the rest of the parts with this clear! It's very expensive but I feel if I've come this far why not go a little further and use a good quality clear for the final step. ImageUploadedByH.A.M.B.1461598623.171959.jpg ImageUploadedByH.A.M.B.1461598639.196920.jpg ImageUploadedByH.A.M.B.1461598667.600411.jpg ImageUploadedByH.A.M.B.1461598689.685677.jpg After a cut and buff. ImageUploadedByH.A.M.B.1461598779.626417.jpg ImageUploadedByH.A.M.B.1461598794.060709.jpg ImageUploadedByH.A.M.B.1461598812.892720.jpg ImageUploadedByH.A.M.B.1461598835.795996.jpg
    kiwijeff, 54reno, waxhead and 4 others like this.
  7. Runnin shine
    Runnin shine
    Now it's "be careful time"!
  8. Wow, that's smooth!
  9. mrobvious34
    mrobvious34
    from Canyon, TX
    Damn that looks good
  10. rob bob
    rob bob
    from Canyon TX
    If you look close you may notice im using one of them fancy no air DA's!
  11. rob bob
    rob bob
    from Canyon TX
    I got my rear axel housing sealed and painted this week nothing fancy just a nice satin finish I'm also doing a gear change while everything is apart. ImageUploadedByH.A.M.B.1462761644.848678.jpg
  12. rob bob
    rob bob
    from Canyon TX
    I'll be doing a step by step post in real time of the paint and body on my cab. The cab is the last piece I have left to paint so I'm starting to see the light at the end of the tunnel. I cleaned and sanded everything in perpetration to spray an epoxy sealer. ImageUploadedByH.A.M.B.1462762101.341337.jpg ImageUploadedByH.A.M.B.1462762130.487461.jpg ImageUploadedByH.A.M.B.1462762188.890237.jpg Like I said I'll be posting the progress In real time. I hope that way I can go a little more in depth on the process rather than trying to post pictures and narrating all at the same time. In the next few days I'll be spraying epoxy primer down first then starting the body work! Stay tuned and thanks for looking.
  13. deucetruck
    deucetruck
    from Missouri
    Great looking project. Your frame is beautiful!!! Thanks for posting.
    deucetruck
  14. As slick as that frame is, I can't wait to see what you do to the body! :)
  15. Malcolm
    Malcolm
    from Nebraska
    Looking good, Robert!
  16. 2deuces64
    2deuces64
  17. rob bob
    rob bob
    from Canyon TX
    Id be lucky if the cab turns out as slick as the frame! [emoji3]
  18. rob bob
    rob bob
    from Canyon TX
    Thanks guys!
  19. barrnone50
    barrnone50
    from texas
    No air DA's Well they do a wonderful Job!! Where may I purchase one.. Great Job on the Frame looks like a mirror..Sweet!!
  20. rob bob
    rob bob
    from Canyon TX
    On sale now at Harbor Freight!
  21. rob bob
    rob bob
    from Canyon TX
    Today after work I sprayed two coats of sealer down and will start body work tomorrow. Some paint and body guys like to apply filler direct to metal (DTM) an some like to spray a sealer ( DTM epoxy primer) then apply filler on top of that, I have done both methods and on something with lots of pits and pin holes I do believe filler over primer is the best method. ImageUploadedByH.A.M.B.1462847961.687005.jpg ImageUploadedByH.A.M.B.1462847985.887473.jpg ImageUploadedByH.A.M.B.1462848025.488662.jpg ImageUploadedByH.A.M.B.1462848058.033347.jpg ImageUploadedByH.A.M.B.1462848080.997987.jpg
    Late to the Party, 54reno and greaser like this.
  22. rob bob
    rob bob
    from Canyon TX
    Tomorrow I start spreading the mud, thanks for following along!
  23. Jalopy Joker
    Jalopy Joker
    looks Cool and cozy
  24. bengeltiger
    bengeltiger
    Wow, what a great build and a great job do***enting it. Thanks for sharing it!
  25. rob bob
    rob bob
    from Canyon TX
    This evening after work I started the body work on the roof, with epoxy primer you can apply the filler directly to the primer without sanding for adhesion the filler will just cross-link into the primer, but there is a window for proper cross-link adhesion I have heard 24 hours all the way up to 5 days. Personally I wouldn't go much past two days, if you miss the window just rough the primer up with 240-180 grit paper then apply filler. ImageUploadedByH.A.M.B.1462933743.898432.jpg I applied filler over the whole roof section and started with the air file and 36 grit paper this step moves rather quickly so pay close attention to what's high and what's low on the panel and remember a guide coat is you friend so use it at every stage of the body and primer work, krylon rust-tough satin spray paint works well for this. ImageUploadedByH.A.M.B.1462934189.114664.jpg ImageUploadedByH.A.M.B.1462934207.396252.jpg I ran the air file over the roof watching the guide coat, feeling how the air file "walks" over the panel meaning when it's sanding on a high spot it tends to want to pull off to the side, keep sanding in that area till it's level. Keep watching the panel closely when you see the primer/ metal start to come through stop sanding, and your ready to re apply more filler to the low spots indicated by the black guide coat. ImageUploadedByH.A.M.B.1462934756.314688.jpg ImageUploadedByH.A.M.B.1462934771.832283.jpg That's all for today more progress to come tomorrow.
    Max Gearhead likes this.
  26. mrobvious34
    mrobvious34
    from Canyon, TX
    "It puts the filler on the skin and then it gets the file again" - Buffalo Rob Bob
    117harv, Tim_with_a_T, 32coop and 2 others like this.
  27. rob bob
    rob bob
    from Canyon TX
    Haha I hope the name doesn't catch on.
    cadillacoffin likes this.
  28. Vhodoo
    Vhodoo
    Great build thread thanks for your body and paint tips and tricks
  29. 32 Spitfire
    32 Spitfire
  30. MUlrich07
    MUlrich07
