Technical Tbucket spongy brakes..
Discussion in 'Traditional Hot Rods' started by hankbreu, Apr 25, 2016.
  1. hankbreu
    hankbreu
    Hi !! I have build a tbucket , and the brakes are spongy , the specs I used was from T.P.. drawings the master cylinder is from a 1975 mustang from speedway motors. used a 10 psi residual valve for the back 11 inch drums, and 2 psi residual valve for the front with chevy disk brakes.. and a proportional in the back....I have bled them, numerous times and I can not get good a good brake pedal... .what am doing wrong !!!!! I replaced the master cylinder ,and getting same results....Darn!!!!!!!
  2. Tim O'Kelley
    Tim O'Kelley
    from texas
    What bleeding method are you using?
  3. hankbreu
    hankbreu
    Hello ,Tim !! thanks for responding, I bled them starting with the left front than right front , than right rear than left rear, I must have this 10 times at ea. wheel ..than I used a small vacuum pump did that a numerous times with same results , a little pedal 1st pump ,2nd pump a pedal 2/3 down..
  4. Lost in the Fifties
    Lost in the Fifties
    Bleed farthest wheel from master cylinder first, closest wheel last. That should get all the air out.
  5. hankbreu
    hankbreu
    I think I did that , but I will do that tomorrow just to make sure , I have been working on this for than more a week now , even replaced the master cylinder.. so bleeding the normal way should do it ..
  6. Texas Webb
    Texas Webb
    Did you bench bleed the master first?
  7. when they say to bleed the furthest first it means the one that has the longest line, if you already didn't know....
  8. tricky steve
    tricky steve
    from fenton,mo.
    post a picture of the calipers please,and the wheel cylinders from the bleeder side.
    hankbreu likes this.
  9. Hackerbilt
    Hackerbilt
    You say Chevy Disc brakes...are you sure you don't have low drag metric calipers?
    They pull farther back when the brake pedal is released and require a special quick take up master cylinder to push them back to the rotor quickly.
    Using a normal master like the Mustang one you have will mean the brake pedal will always seem very low.
    I forget the exact cars you need to specify to avoid the low drag versions (late 70's Malibu is one I think), but a Google search for something like "low drag caliper" should get you the info you need.
    Atwater Mike likes this.
  10. V8 Bob
    V8 Bob
    Two things important for a good pedal and bleed; minimum push rod clearance of about 1/16" when the pedal is fully released by it's return spring, and being able to fully stroke the master. Bleeding sequence with a dual master is not important, and in fact will let you know if each system in intact with the other failed while bleeding.
    Also, the 15/16" Mustang 2 master may be too small for a high pedal, depending on ratio and your brakes.
    Make sure the drum brakes are properly adjusted.
  11. 52HardTop
    52HardTop
    Shouldn't the proportional valve be in the front and not the back?
  12. studebaker46
    studebaker46
    a lot times improperly adjusted drum brakes will seem spongy especially if you didn't turn the drums Tom
  13. onetrickpony
    onetrickpony
    from Texas
    If the calipers are on the wrong side the bleeders will not be in the right place to fully bleed the air out.
  14. tricky steve
    tricky steve
    from fenton,mo.
    yes.. pictures please.
  15. hankbreu
    hankbreu
    I bought the chev brake kit from Ron pope, intermediate chev brakes. I bought the whole front end from Ron.
  16. hankbreu
    hankbreu
    I will take pics tomorrow and post them...thanks to everyone. Hank..
  17. sunbeam
    sunbeam
    Do you have a square tubeing frame and use through the frame brake line fittings? Some have a large p***age and are hard to all the air out.
  18. hankbreu
    hankbreu
  19. Nailhead Jason
    Nailhead Jason
    Also is the master cylinder lower in the frame than the the calipers and wheel
    cylinders? That can make bleeding a real pain. I agree with @V8 Bob that mustang master may not move enough fluid for your brakes. I personally dont like the mustang ones and have always used a gm one, and replaced Mustang ones with a chevelle or vette type.
  20. butch27
    butch27
    I don't have permission to view the pics. ???
  21. abe lugo
    abe lugo
    Nailhead Jason likes this.
