Projects 1930 model a
Discussion in 'Traditional Hot Rods' started by jt1949, Feb 15, 2016.
  1. jt1949
    jt1949
    Dreaming and scheming. ..
    brEad, Jeff34 and 47flyer like this.
  2. Nailhead Jason
    Nailhead Jason
    Make sure you sit inside it and make reving engine sounds! It helps motivate!
  3. Garagekulture13
    Garagekulture13
    I wish I had those wheels and tires!
    jt1949 likes this.
  4. jt1949
    jt1949
    Got the front end mocked up this weekend. Need to tackle getting the **** down now.
  5. jt1949
    jt1949
    Steering column in with a new shaft turned down to dd shaft at the box end.
    brEad, lothiandon1940 and Jeff34 like this.
  6. Binger
    Binger
    from wyoming
    Looks like you are having fun. Subscribed.
  7. 31Apickup
    31Apickup
    Good progress, should sit nice.
  8. Garagekulture13
    Garagekulture13
    You get all your parts from Speedway?
  9. Raiman1959
    Raiman1959
    Oh man....that is gonna be a fine lookin' car...heck, I like it the way it sits now!!!....haha...cool man, love the car!;):D
    Frank Balsama likes this.
  10. patmanta
    patmanta
    from Woburn, MA
    Could you show a little more detail on how you mounted your steering box and where it is located? I made my adapter plate to put the top bolt over the rail and now I think it needs to go under because of my engine mounts.
  11. jt1949
    jt1949
    I got all the front end stuff from pete and jakes...
  12. jt1949
    jt1949
    1927graham likes this.
  13. jt1949
    jt1949
    I went a little lower just for that reason.
  14. Hot Rod 50
    Hot Rod 50
    I do this often in my coupe.
  15. Hot Rod 50
    Hot Rod 50
  16. patmanta
    patmanta
    from Woburn, MA
    Thanks! I may have to do this. Currently my steering shaft is in line with the center exhaust port on my flathead.
    How is it mounted on the other side and did you do anything to make it perpendicular to the front axle or did you just mount it flat to the rail?
  17. jt1949
    jt1949
    I mounted it flat to the rail... I am using those u joints to connect it from the box to a dd shaft to another u joint to the steering column shaft... figured that angle wouldn't matter too much.
  18. patmanta
    patmanta
    from Woburn, MA
    I totally spend like 2 hours getting my plate to 3° because I thought it MIGHT be important... and I tend to hyper-focus on things like that when I start fabricating little things apparently.
  19. Russ Tee
    Russ Tee
    from Florida
    Yeah, me too.
  20. jt1949
    jt1949
    I decided to go with a 153 ci chevy for the engine in this one. I've used these before. Great little motors.
    OFT, Tim and RoddyB34 like this.
  21. jt1949
    jt1949
    Body off today.... next changing out the rearend.
  22. 1931fordtruck
    1931fordtruck
    Coming right along!
  23. 1931fordtruck
    1931fordtruck
    I've got a 194ci for mine.
  24. 1931fordtruck
    1931fordtruck
    '62 Chevy 194ci with power glide trans. 25,000 original miles.
    keywestjack and jt1949 like this.
  25. jt1949
    jt1949
    Not much to these :)
  26. jt1949
    jt1949
    Little early morning car show with my 36'
  27. jt1949
    jt1949
    Mocking the motor up today.
    Rich B. likes this.
  28. 1931fordtruck
    1931fordtruck
    How did you do your rear end, what set up?
  29. jt1949
    jt1949
    I'm using a 97 s10 rearend. Going to build a triangulated 4 link with coilovers. Hoping to get it low enough without modifying the frame.
  30. 1931fordtruck
    1931fordtruck
    I'm using an S10 rearend as well, 4 link setup, and a '38 ford front leaf spring. I am undecided on weather its going to be a spring above or behind. I have to mock it up and see which is going to be better for the stance i am going for.
    Lilred36 and jt1949 like this.
