Projects My 1950 Chevy Styleline Build
Discussion in 'The Hokey Ass Message Board' started by krbarnes, Jan 22, 2016.
  1. ACO.OG
    ACO.OG
    Awesome! Sounds good. That block color is great.
  2. laidbackluis
    laidbackluis
    from Sachse Tx
    Awesome progress ! I like the detailed photo's and video.
  3. krbarnes
    krbarnes
  4. Buddy Palumbo
    Buddy Palumbo
    It sure is coming along nicely. I wish I'd have bought such a nice car to start with, lol.
  5. krbarnes
    krbarnes
    As I'm starting to wrap-up all the mechanical stuff on the car, it's time to turn my attention to the electrical side. I ordered a wiring harness from Speedway, and dove-in head first this weekend.
    All the original wiring has been removed, so I'm starting from scratch.
    Having never done this before, it can be a bit intimidating.
    But with a pretty good understanding of how things work, it wasn't that bad. The hardest part is trying to figure out where to run all the wires so it doesn't look like a rat's nest. Here's a few pics:
    I've been looking for a tachometer that didn't look too 'new', and scored this old Sun SuperTach II from Craigslist for $20.
    In anticipation of being on the road this summer, we found these new "car show chairs" at COSTCO this weekend - complete with cup holders and snack trays!!
  6. welderup!
    welderup!
    Wow great build! I admire you for your at***ude on rewiring. My T-Bird is in desperate need of a total rewire. "Looks intimidating" is an understatement for me lol wiring utterly terrifies me, I know it shouldnt, I can handle anything else, but still. Haha
    I'm tuned in for this one can't wait to see the finished product!
  7. krbarnes
    krbarnes
    Spent the weekend trying to complete and clean-up the wiring in the dash. Got all the gauge, radio, clock, dome, and glove box lights working, along with a new 12volt cigarette lighter. Now I'm just down to the front & rear lights (need to get the front sheetmetal back on the car).
    GreenMonster48 likes this.
  8. krbarnes
    krbarnes
    Wiring is almost done. I have running lights, brake lights, turn signals, and hazards. I removed the original Throttle & Choke knobs, and fabricated LED turn-signal indicators in their spots using the original dash mounting bezels (picture to come). Since I couldn't figure out a way to use the original gauges the way I wanted, I added a 3-gauge panel below the dash. (I tried to go for a more 'retro' looking set.)
    and a shot of the ***embled dash
    Plans are to get the front sheetmetal back on the car this weekend. Then it's down to the final detail work.
    kidcampbell71 likes this.
  9. krbarnes
    krbarnes
    Another great weekend in the garage. Got the front-end sheetmetal back on the car, and all the front wiring complete (headlights, park/turn signals, horn, alternator). Getting down to the last few thing before she's back on the road.
    Rigged some chains and used my hoist to handle the front end
    Engine looks right at home in there!
    Chavezk21 likes this.
  10. krbarnes
    krbarnes
    I've got my list going of all the little things that need to be done on the car. After ordering an electric fan from Summit I realized it was too thick to fit between the radiator and the water pump (don't you just love having to return parts?). I was able to find another that pulled the same CFM in a thinner package, and it worked fine.
    **** EDIT **** That electric fan was TOO NOISY! I replaced it with a regular Flex-Fan.
    Next, I started putting the inside back together. I cut the hole in the transmission hump for the shifter, and pre-drilled all my shift-boot holes
    Then I had to make a few patches to cover holes in the floor -- Master Cylinder access hole under the seat
    and patched all the old throttle/brake/clutch pedal holes in the driver toe-board.
    Finally got everything cleaned up, carpet & seats installed, and shift boot screwed down.
    Pretty much the final item before she's roadworthy again is exhaust. That will keep me busy for the next couple of weeks. More to come!
  11. krbarnes
    krbarnes
  12. krbarnes
    krbarnes
  13. upspirate
    upspirate
    Which one did you buy?
  14. krbarnes
    krbarnes
    This was the 190HP one from Jegs. They say it's good for ~260HP with intake/carb/headers. That's plenty for my cruiser. The price was right, plus a 12 month/12,000 mile warranty!
    upspirate likes this.
  15. Nailhead Jason
    Nailhead Jason
    Just finished putting the same motor in my 51 and wrapping up installing the same wiring harness this weekend. I really liked that harness. worked great in my 51!
  16. krbarnes
    krbarnes
  17. I used pretty much the same motor in my 84 Monte SS. It was a Goodwrench, which I think Jeg's is probably selling as a no name. I did the headers/4 barrel thing. I smoked an early WRX off the line all the way up to 100mph back in the day.
  18. krbarnes
    krbarnes
  19. krbarnes
    krbarnes
    And we're back in business again!!
    Caddy-O and GreenMonster48 like this.
  20. krbarnes
    krbarnes
    Cut a coil off the front springs, and 3" blocks in the back. Getting close to the stance I'm looking for. (anything more will require some major surgery....plus the front crossmember is only about 4" off the ground.....)
  21. krbarnes
    krbarnes
    Amazing what a $17 indoor/outdoor rug and a $10 can of spray adhesive.can do!
    Finally bit the bullet and ordered new 15x6 Wheel Vintiques Smoothies, Bowtie center caps, and Diamondback Wide White radials (205/70/15 front, 215/70/15 rear). Painted the wheels the same color as my engine - "Ocean Mist"
    Next on the agenda is to install the Newport Engineering electric wiper motor that arrived last week, then try to figure out how to fabricate/connect a parking/emergency brake lever. I had to remove the old lever when I converted to a V8.
    olscrounger and i.rant like this.
  22. tierod
    tierod
    Sweet, nice build.. Have fun..
  23. jfreakofkorn
    jfreakofkorn
  24. krbarnes
    krbarnes
    Wiper motor went in without a hitch. Very easy install. I did modify the old Choke knob to use on the wiper switch instead of the ugly black knob that was included in the kit. ( "C" for Clean & Clear !!!)
    Another mod I did was to fabricate LED turn signal indicators, and put them into the old bezels where the original Throttle and Choke knobs were on the dash. Worked really well!
    Although the noise wasn't that bad inside the car, and since I really needed new carpet anyway, I decided to pull out the seats & carpet, and lay down some FatMat. Should make for a nicer ride on longer trips.
  25. krbarnes
    krbarnes
    In case anyone is interested, here's my "build list"
    1950 Chevrolet Styleline Deluxe 2-Door Sedan
    Restored about 15 years ago – engine, body, suspension, paint, interior
    Original 216 I-6, 3-speed manual, closed driveline, rear suspension, and rear differential removed
    Original front suspension and steering gear removed
    Brake pedal, master cylinder, brake lines, clutch pedal & linkage removed.
    Original wiring removed
    Build List (new purchase/parts in BLUE)
    Front Suspension
    Ch***is Engineering bolt-in front crossmember
    Speedway Motors Mustang II front suspension kit
    Tubular upper & lower control arms with new ball joints
    2” drop spindles, seals, bearings
    Manual rack & pinion steering
    Disk brakes – rotors, calipers, brackets, hoses
    Monroe shocks, coil springs
    Steering
    Factory steering wheel and column adapted with:
    CPP Column Saver bearing
    CPP Stainless U-joints
    ¾” D-D shaft
    Heim-joint for shaft support
    Rear Suspension & Differential
    Ch***is Engineering rear suspension kit
    Leaf spring mounts
    Leaf springs
    Upper shock mount crossmember
    Shocks, U-bolts, lower shock plates
    3” lowering blocks
    1967 Nova 10-bolt rear with 3.08 gears (Craigslist)
    All new rear brakes – wheel cylinders, pads, springs, clips
    Wheel Vintiques 12-Series Smoothie wheels – 15x6
    Wheel Vintiques Chevy Bowtie logo center caps
    Stainless Trim rings
    Diamondback Wide Whitewall Radials (Toyo tires) – 205/70/15 front and 215/70/15 rear
    Engine
    New GM Crate 350 / 195 HP long block (GM part # 10067353)
    New harmonic balancer and bolt
    Polished stainless block-hugger headers
    Edelbrock dual-plane intake (Craigslist)
    Edelbrock 1406 600cfm carburetor - rebuilt (Craigslist)
    New HEI distributor with MSD StreetFire plug wires
    New water pump, fuel pump, alternator
    Finned polished aluminum valve covers and air cleaner
    Chrome pulleys and alternator brackets
    16” flex fan
    Polished stainless steel radiator catch can
    2.5” exhaust with Flowtech Raptor turbo mufflers, Flowmaster tailpipes, and Gibson 3” stainless tips
    Lokar ‘S****’ gas pedal
    Lokar throttle cable
    Lokar carb bracket
    Lokar engine oil dipstick
    All new hoses and belt
    Champion 3-row aluminum radiator
    Hand-fabricated steel fan shroud
    Transmission
    Walton Fabrication bolt-in Transmission crossmember
    Rebuilt 700R4 Automatic transmission (from my son's 1990 Camaro IROC)
    Converted to switched TC lockup
    Converted to mechanical speedometer drive
    New filter & pan gasket, new rear seal, new dipstick seal
    New transmission mount
    New custom made drive-shaft – new yokes & U-joints
    Lokar 16” Shifter & boot
    Lokar transmission TC cable
    Brakes
    Speedway Motors frame-mounted (under car) pedal ***embly, power brake booster, and master cylinder
    All new Copper-Nickel brake lines
    Speedway proportioning valve
    Wilwood residual valves.
    Saab parking brake lever adapted to vehicle with new cables and hardware
    Electrical / Instrumentation / Interior
    Speedway Motors 21-circuit wiring harness
    All visible wires wrapped in Flexo braided cable sleeve wrap (like Techflex)
    New ignition switch (original push-****on still works too), headlight switch, cigarette lighter
    New turn signal/hazard switch
    LED rear tail lights
    All new bulb sockets and light bulbs
    Front parking light converted to park lights/turn signals
    Choke/Throttle bezels on dash converted to LED turn signal indicators
    Original 6 volt horns wired in series to work with 12 volt system
    Original Speedometer and Fuel gauge functional (voltage reducer on fuel gauge)
    Column mounted SUN super tach II (Craigslist)
    Autogage ****og gauge panel – oil pressure, voltage, water temperature mounted in dash speaker grill
    New speedometer cable
    Newport Engineering 2-speed electric wiper motor
    Torque converter Lockup switch and LED indicator mounted in Radio Delete plate
    Interior floorboards covered with FatMat sound deadener
    New Carpet
    Front seat belts
    Goose-neck rear view mirrors mounted on custom-made polished aluminum base
    kaizen and i.rant like this.
  26. i.rant
    i.rant
    Enjoy! Damn nice 50 you built there.
  27. Blues4U
    Blues4U
    from So Cal
    Very nice job, looks great. I may not have done everything the same way, but variety is the ****e of life, right? In any case, enjoy that car!
  28. krbarnes
    krbarnes
  29. krbarnes
    krbarnes
    I have been running into some temperature issues while idling/sitting in traffic. Thinking the old 6-cylinder radiator just wasn't going to cut it, I bought a new 3-core aluminum radiator.
    only to discover that this wasn't my problem -- it's an airflow problem. After a discussion on the Tech forum, I decided I needed a better fan and a shroud. I replaced the flex fan with a fixed-blade fan. After a trip to Harbor Freight for a sheet metal brake, I made a shroud, welded it up, painted it black, and put it on. Now i'm seeing temperatures about 30degrees lower! Woohoo!!!
    Blues4U likes this.
  30. upspirate
    upspirate
