Technical 54 chevy frame
Discussion in 'Traditional Customs' started by jeffyg82, Apr 27, 2016.
  1. jeffyg82
    jeffyg82
    I have a 51 chevy fleetline someone cut the motor mounts off with a torch and just destroyed the front rails.... anyhow I found a 54 4 door frame a couple hours from home will these interchange??
  2. 'Mo
    'Mo
    Someone will know for sure, but Art Morrison lists their frames as fitting 1949-1954 Chevy.
    http://www.artmorrison.com/49-54chev.php
    If the running gear is with it, you will also be getting a brake upgrade, and better highway gears
    (unless your Fleetline is a Powerglide).
  3. Nailhead Jason
    Nailhead Jason
    Should be fine but some 54 frames are wider over the rear axle but a 1/2 inch or so. could make lining up body mounts tough. The trans crossmember changes slightly in 53 but still functionall the same. if it has the steering box and everything on it, that will get you better brakes, a steering box with better bearings and uprights that have 1/2 more drop in them than yours. snag that frame build the whole thing then swap your body on to it. much easier to do all the brake lines, fuel lines and such with the body off.
  4. jeffyg82
    jeffyg82
    Perfect thanks guys
  5. jeffyg82
    jeffyg82
    Here is the little sweet heart the plan is a 5 inch chop, clipper tail lights, accuair air ride going very traditional tail dragged with it.... I will start a thread when the build gets underway..... I just finished my 53 belair wife says she wants a house built b4 I can start lol
  6. Begin here, a guy named Fitz, in Canada, has much experience with '49 to '52 frame.
    Different from '53 and '54.
    http://www.chevytalk.org/fusionbb/showtopic.php?tid/333192/.
    Click below for Fitz's build and frame info. LONG thread, a real detailed guy.
    http://www.chevytalk.org/fusionbb/showtopic.php?tid/181323/tp/1/
  7. 56sedandelivery
    56sedandelivery
    A 51 frame did't have engine/frame mount towers; that began in 52. The 51 and earlier engines were mounted at the front, 52-54 were side mounted. Are you certain about someone torching them off? The 49-54 frames will swap, with some minor differences (we won't consider the convertible frame here); the biggest difference is in the hardtop frames. They were reinforced from the factory, so a hardtop frame would be not only usable, but stronger. I am Butch/56sedandelivery.
