Technical GOT A BITCH
Discussion in 'The Hokey Ass Message Board' started by frosty-49, May 1, 2016.
  1. frosty-49
    frosty-49
    Ever try to drain the antifreeze out of a car and have it not hit the drain pan because everything is in the way or you can't get to the drain plug at all. This is a hazmat material. It ends up all the shop floor and you have to use some stay dri to clean up, and that ends up in the land fill. If its a plastic radiator, don't even bother. Draining oil. Why is that crossmember in the way? Just my opinion.
  2. choptop40
    choptop40
    Yes , same on my 88 gmc , I use a wide plastic tray , gets 99.9 % of it , then off to autozone.....
  3. Atwater Mike
    Atwater Mike
    The car was designed and manufactured before anyone ever thought about Environmental agencies, Occupational Safety Hazards Agency, or related 'bureaus' to protect us from ourselves.
    There should be a Retroactive Automotive Scavenge Bureau to provide biodegradable formed pans that fit the various and sundry poorly thought out designs than make such spillage.
    There. I said it.
    But don't expect me to vote for types that would enforce such pettiness...
  4. chevy57dude
    chevy57dude
    There's an inline pipe with a pet**** in it to splice into the lower radiator hose. pretty sure Speedway sells 'em. Your results may vary.
    Hnstray likes this.
  5. slammed
    slammed
    Recover rain water w/a large barrel. Next spillage, dissipate the offending hazard. Remain calm. Keep it close to the vest. FAR worse is dumped into our air/water/food by the Big Brother Hood.
    CowboyTed, kiwijeff and slack like this.
  6. stimpy
    stimpy
    most of the pet****s I seen have a nub for a hose , put the hose on after you break the valve loose and then slip the hose on and aim it into a pan ... if there is no pet**** , remove the install one they are cheap , I have one the radiator and 2 on the blocks also you can direct solutions with a wire too
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    Block drain plugs are usually lower than the bottom of the radiator or its bottom hose. So it's prolly best to replace these 1/4" MPT steel plugs with compact 1/4" MPT br*** drain****s if there's not enough room for a pet****/valve and hose. You may still need a big catch-pan but you won't be fighting to remove the plugs next time. http://www.amazon.com/Milton-Indust...&redirect=true&ref_=oh_aui_detailpage_o01_s00
    Jack E/NJ
    ironrodder and Atwater Mike like this.
  8. theHIGHLANDER
    theHIGHLANDER
    This, and frankly on just about everything new and old. I only suffer a little if it's a car that didn't get one or was disrespectfully eliminated. When that's the case, 1 mess, never again. And 90% of what I work on daily is old so...
    With regard to the ***le, I was thinking "Don't we all..."
  9. Larry T
    Larry T
    I've been working on cars for a paycheck since the 60's. I learned a long time ago that ease of maintenance is not a priority of the designers. Ease of ***embly is the priority. Most cars will make it through warranty without any major problems. Then it's not the company's problem, so it's not a problem.
    I guess the first time I realized this was having to drop both sides of the exhaust leadoff pipes off to pull the starter on a 58 Chevy with a 348 in it.
  10. inthweedz
    inthweedz
    Larry T got it right, it's for ease and speed of manufacturing.. To hell with the technician later on in the vehicles life, it's still the same today, or maybe worse, with all the extra electronic wizfiz they have crammed under the hood..
    jeffd1988 and Barn Find like this.
  11. aaggie
    aaggie
    When I build a project and have to make a bracket or gizmo of some sort I always ask myself, if it fails can I fix it by the roadside, in the dark with nothing but tools in the trunk. A little thought up front can make a big difference later.
    A little off topic but the oil filter on my Harley is horizontal in front of the engine and if unscrewed it pours oil all down the front of the engine and frame. They sell a strangely shaped plastic funnel that inserts under the filter and it comes with a regular 16d nail. You insert the funnel then punch a hole in the top of the filter with the nail and turn the filter so the nail hole is down and it drains the oil into the funnel and into a catch container.
  12. Larry T
    Larry T
    Punching a hole in the filter won't work with most cars. A Harley is a dry sump system with all the oil in a tank above the filter level, so it all drains out. Most of the oil in a car is below the filter level. Making a funnel to catch the oil and route it to your oil catch can is a great idea.
  13. 62pan
    62pan
    I always thought this stuff was because as kids we use to pick on the kids that ended up as designers and engineers and this was their way of getting payback.
  14. slack
    slack
    Worse :mad:
    stimpy likes this.
  15. Texas Webb
    Texas Webb
    More billable hours for the dealer.
    jeffd1988 likes this.
  16. 37hotrod
    37hotrod
    You can also dilute it with unicorn blood and orphan tears. :)
    belair, kiwijeff and el Scotto like this.
  17. indyjps
    indyjps
    I've made some creative aluminum foil shapes to get around some of this.
    My daily 2006 silverado will fill the transfer case crossmember with oil when I pull the oil filter if I don't build an aluminum foil dome over it.
    Saxman and swade41 like this.
  18. pat59
    pat59
    I got a 2 foot by 3 foot black plastic cement mixing pan at home depot. about 10 inches high. I use it for just those occasions, catches most of it. :)
    BradinNC and jeffd1988 like this.
  19. D-man313
    D-man313
    Another one is no drain plug in Gm transmission pans. Manage to catch a few quarts and the rest ends up on the garage floor.
  20. HOTRODPRIMER
    HOTRODPRIMER
    After this long,67 years,I doubt Ford will have a recall to correct the problem.:D HRP
  21. Gman0046
    Gman0046
    Larry T, I once replaced the starter on my58 Impala 280 HP 348 and didn't check its operation before ****oning it up. Turned out the new starter was inoperative. At least disconnecting the pipes was much easier the second time. Learned a valuable lesson that day.
    Gary
  22. toml24
    toml24
    I had a co-worker with a lot of tools do a tune-up for a OT 1972 Ford Maverick. You should have seen the horrible skinned knuckles and heard the loud cursing as he tried to remove the spark plugs. Some cars it seems are meant to be disposed of before any maintenance is done.
  23. Ebbsspeed
    Ebbsspeed
    O/T, but this is kind of the flip side of engineers and designers not caring about maintenance. I was faced with changing the engine in my son's Subaru Baja this weekend and was thinking it would be a huge h***le. Not so much. Two motor mount bolts, two bolts to remove the radiator, eight bellhousing bolts, unplug four electrical connectors, six exhaust manifold bolts, a few miscellaneous hoses for vacuum/fuel/coolant, and boom, out of the bay in under two hours. Pop off the flywheel, bolt it to the new motor, new clutch, back in and running three hours later. An anomaly I'm sure, but I was pleasantly surprised as to how easy it was.
  24. stimpy
    stimpy
  25. stimpy
    stimpy
    we buy the B&m kit and then take a 3/8 drill bit a cordless drill ( this is where the one your mother in law gave you that wobbles ) and a spray paint cap and drill a hole thru the cap and then use a hose clamp or duct tape to hold the cap in place and then drill the pan carefully over a pan where you want the trans drain to be and walla , the cap sits against the pan while you drill ( preventing the circle shower ) then when it penetrates the pan, the cap then catches the hot/warm fluid then you pull the drill off and let drain it in the catch pan below the hole . then remove the pan and install the drain kit or replace the pan with a drain equiped one . learned this from the trans shop guys they said it saved them the trouble of having a pan drop all the way and then knocking over the tall pan or splashing over the side .
    indyjps likes this.
  26. stimpy
    stimpy
    they did!! a plug that falls out as it breaks and into the fluid and then it will not go back in ... and the then you find out its a dealer only part and the parts dept just closed or its saturday and not open .... or better yet NLA and revised mid year ....
  27. jimmy six
    jimmy six
    I've been ice picking oil filters for years letting them drain into a separate pan while either lubing zerk fittings or draining the oil. All the Hondas we've had, the filter were 90* to the block. My 2013 Eco Ford pickup has a drain trough when take off the filter. It p***es the oil to the opposite side of the engine.
  28. David Gersic
    David Gersic
    from DeKalb, IL
    Plastic oil bottles can be chopped up to make splash guard / funnels. I just did that draining the radiator on my '37 Chevy. Crack the pet**** with pliers, then jam the plastic bottle with one side mostly cut away in between the bottom of the radiator and the crossmember, with the spout pointed down and the bottle covering the area around the pet****. Turn the pet**** open with a screwdriver and watch it drain in to the pan without making a mess.
  29. bchctybob
    bchctybob
    My lovely wife gave me a form-able funnel that I use for everything. It has a green rubberized coating over something that bends and holds it's shape - even a tube shape. My '55 F100 with a 302 has an oil pan plug that drains right onto the crossmember, that funnel works great.
    http://www.amazon.com/Form-Funnel®-Flexible-Draining-Tool/dp/B003V9JWHO
    While you have the coolant drained put in a better pet****, maybe even add a hard line and move the pet**** somewhere convenient.
    gas pumper and 37hotrod like this.
  30. David Gersic
    David Gersic
    from DeKalb, IL
    For oil drains, I'm a fan of the Fumoto ball valves.
