Projects Finally! The 31 I've been looking for
Discussion in 'Traditional Hot Rods' started by SherrillHotrods, Apr 10, 2016.
  1. SherrillHotrods
    SherrillHotrods
    [​IMG][​IMG]
    Finished stripping paint off body tonight. Now on to shaping up the bondo and probably a roof Insert removal.
    Sent from my SM-N920V using H.A.M.B. mobile app
    mad mikey, waxhead and cretin like this.
  2. 383deuce
    383deuce
    Thanks for liking my build and watching it come along. I will be watching yours also.
    SherrillHotrods likes this.
  3. 383deuce
    383deuce
    I think if it was me I would leave the roof insert in as I think it makes it look good.
    greaser and SherrillHotrods like this.
  4. SherrillHotrods
    SherrillHotrods
    mad mikey likes this.
  5. SherrillHotrods
    SherrillHotrods
    Pretty much done stripping paint. Probably going to be in the market for a new deck lid the one for this car isn't so hot. I'd have to skin and replace prolly bottom third on inside.
    Ron Funkhouser and mad mikey like this.
  6. Me too. Someone went to a lot of trouble to make that happen, and I think it's a desirable modification.
  7. Dino 64
    Dino 64
    from Virginia
    Nice start. How did you strip the paint ?
  8. SherrillHotrods
    SherrillHotrods
    Dino64- I started off by scotch brighting area I wanted to strip then I apply the aircraft paint stripper ( x3 there was 3 layers.. primer, original black and then the light blue) that took it to dirty metal then I hit it with 60 grit real fast to knock off stuff that didn't get stripped, then hit it with 80 grit to get a uniform surface. Then I used a wire wheel on drill to get stuff that stuck in belt and body lines. Once panels are clean I used PHIX a metal conditioner that works wonders... spray that over panel let sit for about a minute or two then scrub the hell out of it with scotch Brite pad once scrubbed real good wipe down with paper towel and it'll leave a white residue behind and that protects the metal. The driver side quarter is my first panel I started on about a month ago and no surface rust at all
  9. hasty
    hasty
    Also like the roof insert. Very jealous
  10. Raiman1959
    Raiman1959
    That is a really nice body;)....and oh my....a Desoto Hemi?....hoooo boyyyy....hold on tight!!!:D:D:D....gonna be a fun car!
  11. SherrillHotrods
    SherrillHotrods
  12. SherrillHotrods
    SherrillHotrods
    Had to throw some primer on. My garage isn't very bare metal friendly Even with the PHIX on it. Pretty much at a stand still till I get 32 rails
    AHotRod and kidcampbell71 like this.
  13. SherrillHotrods
    SherrillHotrods
    Picked up the 32 rails today time for mocking then bobbing and maybe some pinching
  14. 383deuce
    383deuce
    Thanks Ryan for liking my build and keep moving forward on this one as it will be nice when finished. Just remember Rome was not built in a day. Take your time, but try and get something done on it every week (or day if you can) no matter how small, but keep it going.
  15. SherrillHotrods
    SherrillHotrods
    [​IMG][​IMG][​IMG][​IMG]
    Did a little playin around in garage today. Jus stoking the fire a little
    kidcampbell71 and AHotRod like this.
  16. AHotRod
    AHotRod
    So ... is this the direction your headed with your car?
    kidcampbell71 likes this.
  17. SherrillHotrods
    SherrillHotrods
    Oh no jus some sweet pics I picked up at a swap meet.
  18. SherrillHotrods
    SherrillHotrods
    Got my front end mocked up
    Jeff34 and AHotRod like this.
  19. AHotRod
    AHotRod
    Whats going on ?
  20. Fire Fox
    Fire Fox
    Subscribed, I picked up a 31 coupe recently and am going in about the same direction!
  21. Wow.. . so is that's what metal looks like underneath paint?
