Projects 1957 CHEVY SOUTHEAST GASSERS BUILD
Discussion in 'The Hokey Ass Message Board' started by Zak Hall, May 11, 2015.
  1. Zak Hall
    Zak Hall
    We got the rear brakes all finished up over the weekend, got the line loc bolted on, master cylinder bolted on, ready to run hard lines. Also got the front crossmember made for the radiator/fuel tank mount. Then got that all painted, the radiator painted, and everything bolted on. Gonna try to start the car by next weekend. The front clip is just laying on it to see what it will look like.
    Dog_Patch, AHotRod, 3dnsouth and 3 others like this.
  2. Quain Stott
    Quain Stott
    perfection, full steam ahead. Goal - Greer Drag way April 30th.
    Zak Hall likes this.
  3. mad mikey
    mad mikey
    Lookin good Zak, get that bad boy runnin. :cool:
  4. Zak Hall
    Zak Hall
    We've been thrashing trying to get the car done. Got the intake bolted on permanent, dad built the carbs, we got the fuel lines ran today. Got the flywheel and starter bolted on. A little wiring and a couple hoses, and the car should start.
    mad mikey, AHotRod, 3dnsouth and 3 others like this.
  5. Quain Stott
    Quain Stott
    Looking good y'all have got this.
  6. Zak Hall
    Zak Hall
    We got it started today, and really no issues with the motor. So we are gonna keep working and try as hard as we can to make it. We might have something for C gas this year.
  7. Dog_Patch
    Dog_Patch
    Man you guys with alternators are starting to make me want to run one o_O
  8. Zak Hall
    Zak Hall
    Dog_Patch and AHotRod like this.
  9. 3dnsouth
    3dnsouth
    from North Ga
    'Just a mild oval port 396....' Riiiiiiight. Sounds mean.
  10. HEMIBERT
    HEMIBERT
    Zak, old man still having trouble with those big numbers I see!
  11. Zak Hall
    Zak Hall
    It does sound pretty good for a baby rat motor.
  12. Zak Hall
    Zak Hall
    Got the clutch, pressure plate, and bellhousing on over the weekend, and got the transmission in it. Dads gonna set the gear up tonight. Dropped my yoke and dimensions off at the driveshaft shop, should be picking it up tomorrow. Still gotta mount the shocks, mount the drivers door, finish brake lines, mount the front end, make the clutch linkage, and pop the windshield in it, along with a little wiring. Late nights, and probably dad will take off from work a few days, but we are gonna really try to make it. Everything has fought us, and having to do things like dad had to lathe a line up tool because nobody had a Chrysler 18 spline one, and he had to mill the billet main caps to fit (which we knew would have to be done just time consuming) is killing us. But we're gonna work up till Saturday morning if we have to.
    hechtspeed, AHotRod and Dog_Patch like this.
  13. Zak Hall
    Zak Hall
    And here is a picture I took of him when he was going through my carbs. Milk crates stacked up with a wooden creeper laying across them as a bench, building two holleys. That's old school. Can't thank my dad enough for the late nights, early mornings, and endless hours that he's spent in the garage with me while we've built this car.
    Bad Banana, doliak, swade41 and 7 others like this.
  14. enloe
    enloe
    from east , tn.
    That should be a picture you frame and hang up and cherish a long time.
  15. Dog_Patch
    Dog_Patch
    I envy you having the time with your Dad like that. Can't put a price on that.
    AHotRod, Zak Hall and mad mikey like this.
  16. Higgy's Henry
    Higgy's Henry
    Dads are mint!
    doliak, Dog_Patch, AHotRod and 3 others like this.
  17. HEMIBERT
    HEMIBERT
    MAN, if I had a work chair like that, I'd never get anything done.
  18. Higgy's Henry
    Higgy's Henry
    I tell him that all the time! He's a armchair mechanic! Lol
  19. wheeldog57
    wheeldog57
    Good stuff, thanx for sharing. Good luck making your deadline and have fun
  20. AmishMike
    AmishMike
    I gotta show my son pic of that "work chair" - that is what I need. Got seats & welder - time to make my own.
  21. Zak Hall
    Zak Hall
    Me and dad finished up the brake lines tonight, and dad got the rear end finished up, with the gear set up. Should be driving it around the block in a few days. Trying to get a couple test p***es before Union.
    Dog_Patch and strokedstang331 like this.
  22. HEMIBERT
    HEMIBERT
    Looks good. Don't stop.
  23. Zak Hall
    Zak Hall
    Also got the drive line made. .083 3" shaft, 1350 ****er solid pin joints, and strange chromoly yokes. Also got Mark Williams steel caps in the Dana. Should stand up to the 396 no problem.
  24. Zak Hall
    Zak Hall
    Thanks Robert, things are starting to go smooth now.
  25. elgringo71
    elgringo71
    Looking forward to seeing it make some p***es. It's come a long ways in a short time.
  26. Zak Hall
    Zak Hall
    Finally, got the shifter on the transmission, and the linkage hooked up. Now time to get some sleep, gotta get up early and put it in, and start up on clutch linkage. The first voyage around the neighborhood is getting close.
    mad mikey and Higgy's Henry like this.
  27. Higgy's Henry
    Higgy's Henry
    I know that feeling!!!!
  28. oldcargary
    oldcargary
    from devore, Ca
    Looks great. Nothing better than building it yourself especially with your dad..
    mad mikey and Zak Hall like this.
  29. Zak Hall
    Zak Hall
    Shocks are almost mounted, driveline is in, floor is clearanced for the ram rod linkages, gonna try to finish mounting the shocks tonight, gotta get up early and take my college exit exam. Dad took off work all week this week, so we're gonna keep thrashing.
  30. Zak Hall
    Zak Hall
    Got the z bar mounted, all the linkages made, the shock crossmember welded in, only one hiem and a few wires from driving around the block tomorrow. So set on getting the car done that I'm not even going to my college graduation. Lol
