BEAUTIFUL... BEAUTIFUL... BEAUTIFUL!!! ........ 1933 Plymouth Roadster ........ This Hot ROD just SitsRIGHT! and Has THE L@@K! We Feel this is Really a Work ofART that you can also Drive and Enjoy... ***Words Can't Describe howGreat this ...Car Drivesand HowFUN! Beautiful! ***LE IS FOR A 1933 Plymouth READY TO TRANSFER, NO PROBLEMS! BODY: 1933 Plymouth Roadster Coupe Chopped Windshield Body has been Shaved and Bobbed Fabbed Deck Lid w/ Rounded Corners Suicide Doors w/ Bear Claw Door Latches Deck Lid has Hide-able Leather Pull Strap Fabbed Tail Pan w/ '58 Chevy Taillight Housings & '56 Lenses Kustom Steel Grille w/ working '58 Edsel Headlights/Bezels Smoothed Firewall w/ Moon Gauges Paint is Base White w/ Clear Coat Mixed with a hint of Red Pearl! Custom Antenna (can be changed very easily) THE ENGINE /DRIVETRAIN: 1970 Steel Crank 440 Mopar Motor 727 Automatic Transmission Drive train was from a Running/Driving ...36,000 mile Chrysler Imperial It was since tore down, inspected and Cleaned up New Gaskets were Installed Cal-Custom Valve Covers Chrome Headers Red Top Battery New Water Pump, Fuel Pump and Radiator Electric Fan keeps it running Cool! SUSPENSION/CH***IS: Front Rails are Pinched 2x6 Rectangle, Rear is '33 Plymouth Front End is 4" Dropped Model A w/ Split '42-8 Wishbones and Chrome Pete and Jakes Spindles Chrome Pete and Jakes Bolt on Steering Arms Rear End is 8 3/4" Mopar Sure Grip (Posi) w/ 3:23 Gears Setup with Early Wishbones and Coil Springs w/ Panhard Bar New Firestone Wide White Wall Tires, (Big n' Littles) New Chrome Reverse Wheels w/ Spider Caps *New Pete and Jakes Super Stopper front Disc Brake Kit **Chrome Caliper Covers and Chrome Backing Plates! All New Brake Shoes, Wheels Cylinders and Rear Drum New Master Cylinder New Brake Lines, Transmission Lines, and Fuel Lines New Wiring INTERIOR: One of Kind and Comfortable Full Custom Interior w/ White Tuck n' Roll Throughout High Grade Boat Vinyl, Water is No Worry! Panels behind Rear Wheels, Front Frame Horns and Headlights are all removable! Brand New Lokar Shifter w/ Eelco Pistol Grip Shifter Handle Brand New Ignition Switch, High/Low Beam Switch and Fan Switch New Mooneyes Steering 1951 Ford Gauge Cluster (would need rebuilt) New Gl*** New Gold Loop Carpet Trunk is Also Upholstered Splash Proof Fuel Cell Moon Tach not hooked up Very High End Looking and Feeling Interior! VERY COMFORTABLE !!! ..... Plenty of Leg Roomfor Bigger Guys! Call/Text: 606-776-2886 Email: HotRodDirty@yahoo.com www.TraditionalHotRod.com
