Projects 49 Custom Sedan build
Discussion in 'Traditional Customs' started by NRErickson_84, May 15, 2014.
  1. NRErickson_84
    NRErickson_84
    Got some help today. I cut and welded in the frenched tail lights while my buddy Jeff spread the filler. We got most of the p***enger side done with at least one coat of filler. Filled the door handle, antenna, and door lock holes. Have to do some repair work on the rockers and build a French antenna tube. Working on getting bearclaw latches in and have to buy poppers. I'll probably just run a mechanical release until I have the funds. Now I have a dilemma. The flatly is running a little rough. I am planning on having this as my daily. The cool factor with the flathead is through the roof but the reliability without a full rebuild is not really there. Neither are the funds to do it. So what do I do. I have always said I didn't want to swap in a sbc but the availability of parts and price is drawing me in. Is the 289 or 302 as reliable or cheap. Thanks for the help. Here are the pictures of the progress. ImageUploadedByH.A.M.B.1438473561.540991.jpg ImageUploadedByH.A.M.B.1438473575.606448.jpg ImageUploadedByH.A.M.B.1438473600.177224.jpg ImageUploadedByH.A.M.B.1438473622.946627.jpg ImageUploadedByH.A.M.B.1438473640.382556.jpg ImageUploadedByH.A.M.B.1438473652.717149.jpg
  2. Buddy Palumbo
    Buddy Palumbo
    Looks nice , good work.
    To answer your engine question - YES , the small block Ford can be as cheap to install and run as the belly ****on setup. I am running a mount kit from Jamco (you can see pics on my build thread below) , and we used an Opie's mount kit on my friend's 50 Shoebox (from Butch's cool stuff , I believe). Both were nice kits and fit and work well. Keeping it all Ford is simple and cheap.
    Cooon and NRErickson_84 like this.
  3. tedley
    tedley
    from canada
    As much as i love flattys but to much money i needed a motor that will go and get parts for anywhere. 302 ho. c-4 maveric rear for a budget power train. Loving it after 3rd season of driving. Made my own mounts. Pretty simple. Added some big block merc valve covers and air cleaner for that old timey look. 50 ford 518 (Medium).jpg
    daddio211 likes this.
  4. NRErickson_84
    NRErickson_84
    That looks great. Nice work.
  5. george775
    george775
    from Nor Nev
    Not much different here. 302, C4, 8" and 50's Thunderbird valve covers adapted to the SBF. IMG_1528.jpg
    NRErickson_84 likes this.
  6. chemlab
    chemlab
    from Hell, Az
    Why is the cleaner backwards?
  7. george775
    george775
    from Nor Nev
    Good question. It is a full sized Cadillac from the '50s and needs to be reversed to clear the front mounted distributor on the 302. Better question - How do you get Ford FE big block valve covers on a SBF? Answer - machined adapters mounted to the heads. Customized car, customized engine.
    chemlab and NRErickson_84 like this.
  8. george775
    george775
    from Nor Nev
    I also needed the space to clear the firewall.
  9. chemlab
    chemlab
    from Hell, Az
    I see, I didn't even notice the distributor in the front :(
  10. NRErickson_84
    NRErickson_84
    Ok so after long deliberation and a look at the budget a full swap is not in the budget either. So I'm going to run what I got until it breaks then worry about it then. In the mean time I'm throwing some parts at her. I got water pumps, fuel pump, exhaust, head studs and bolts, rebuilt the 94. I'm locating a distributor and coil.
  11. NRErickson_84
    NRErickson_84
    Got some work done on the front end. Prepped the French headlights. Welded seams and filled in the parking light holes. It's looking good. ImageUploadedByH.A.M.B.1439670697.680283.jpg ImageUploadedByH.A.M.B.1439670731.897531.jpg ImageUploadedByH.A.M.B.1439670744.549862.jpg ImageUploadedByH.A.M.B.1439670767.688558.jpg ImageUploadedByH.A.M.B.1439670793.089006.jpg
    beyond static likes this.
  12. TS057
    TS057
    from Fargo, ND
    Looks good! What headlight rings are you using?
  13. 1936dodge
    1936dodge
  14. NRErickson_84
    NRErickson_84
    They're the ones from shoebox central. They leave you a lot of material to figure out what you want. I mounted my head light bucket from the back then measured the width of original stainless rings. I liked how they flowed better but I wanted the 1 1/2" lip that these have. They look great. I'll post more pictures when I get the welded in.
  15. NRErickson_84
    NRErickson_84
    More progress today. Finished the headlights and welded up most of the front. My buddy Jeff got some putty on the door top. And roof of the drivers side. Waiting on some engine parts and I'll be getting greasy too. ImageUploadedByH.A.M.B.1440282491.544929.jpg ImageUploadedByH.A.M.B.1440282504.462068.jpg ImageUploadedByH.A.M.B.1440282521.397012.jpg ImageUploadedByH.A.M.B.1440282534.266083.jpg ImageUploadedByH.A.M.B.1440282548.465576.jpg ImageUploadedByH.A.M.B.1440282562.401035.jpg ImageUploadedByH.A.M.B.1440282574.835648.jpg ImageUploadedByH.A.M.B.1440282584.719655.jpg
  16. 49Flatty
    49Flatty
  17. NRErickson_84
    NRErickson_84
    So here is a little update on the progress of my car.
    I used to work at a "restoration"/collision shop and I traded a 28ft trailer to my boss to help me finish the bodywork and get it in to a base coat of paint. Well I got sick and had to take off work and during that time he laid me off. Since then it had been a fight to get him to do anything on my car. Finally after 6 months of the car sitting in the weather and surface rust coming through the bodywork that we just did I just pulled my car. I can't believe there are people still in business that act like this. I'm probably going to have to start over on much of the car.
  18. NRErickson_84
    NRErickson_84
  19. grf-x
    grf-x
    That ****s. Unfortunately, there are more and more people like that in the world. At least it seems that way. I hope you can recover and get the project back on track. Hopefully your health is better as well.
  20. NRErickson_84
    NRErickson_84
    Health is great now. More and more it seems that you really can't rely on anyone but those closest to you. Integrity is so uncommon anymore and I'm a young guy.
  21. grf-x
    grf-x
    Judging by your signature, your youthfulness has no bearing. If you were/are a Marine, or even raised by one… integrity is drilled into you as much as marching, PT and marksmanship is. Same can be said for any other service member/veteran.
    I find it harder and harder to trust anyone. Even on a handshake. Our breed is dying.
    So where do you thing you will begin on getting back on track with the shoebox?
  22. NRErickson_84
    NRErickson_84
    I couldn't agree more.
    I think the first thing I'm going to do is get an estimate from another shop as to how much it will cost to complete the job. Not that I will use them but that gives me a do***ent to take to court with. Then I'm going to inspect the work done. I'm noticing a lot of rust coming through the body work so I may have to take it back down to bare metal in those spots and start over. I've collected a lot of engine parts as well over the last year so I want to pull the flatty and start cleaning that up. Still a long way to go. But plugging away at her.
  23. grf-x
    grf-x
    I think your on the right track with Do***entation. Im in the same boat for progress. Replacing sheet metal. I got lucky and got the original flathead with the car. Ive not started with the engine yet. But it does turn over. As usual, pics would be awesome.
  24. Buddy Palumbo
    Buddy Palumbo
    Well that really ****s ! Not only did your car not progress , it took a step back :( . If he did nothing, go get your trailer back - especially if it's still in your name.
  25. NRErickson_84
    NRErickson_84
    He made sure to put the trailer in his name but I have enough do***entation that I think I have a case.
  26. NRErickson_84
    NRErickson_84
    I'm going to coffin cut my deck lid. Haven't seen a lot of these done this way so I'm going to try it out. I was trying to get a comparison of a low cut and a high cut. I'm going with the high then smooth the *** end out. Garnish with some pinstripes when she's in paint. So happy to be getting on the '49 again! ImageUploadedByH.A.M.B.1470362344.120476.jpg
  27. Peanut 1959
    Peanut 1959
    Never heard of a "coffin cut". Is there anything that makes it different than pancaking?
  28. NRErickson_84
    NRErickson_84
    No. From what I've found it is the same thing. The term pancaking seems to be a broader brush for more things though. I had an old timer explain coffin cutting to me and it stuck. I've found more pictures of what I want to do under pancaking though.
    Peanut 1959 likes this.
