Projects 1953 Plymouth Cranbrook
Discussion in 'Traditional Customs' started by NRErickson_84, May 7, 2016.
  1. NRErickson_84
    NRErickson_84
    Hey guys. I acquired a 53 Cranbrook and I was trying to sell it but no one bought it so I'm going to build it. I was driving it for a while on the stock drivetrain and the engine took a dump so now I'm in scramble mode to get it back on the road. The plan for now is to get it on a modern ch***is and a more reliable drivetrain. S10 frame swap using the power brakes, power steering and a 350/350 combo. Should be fun. ImageUploadedByH.A.M.B.1462680654.355229.jpg ImageUploadedByH.A.M.B.1462680670.971315.jpg
    Gulf Coast Hemi likes this.
  2. RaginPin3Appl3
    RaginPin3Appl3
    [emoji107][emoji107]about that frame swap. Stick with the original frame
    What'cha got in there, kid?
    slv63 and Steve Ray like this.
  3. 504640
    504640
    Fix the Six!
  4. BuiltFerComfort
    BuiltFerComfort
    The stock ch***is is fine - factory IFS. Use a Cherokee or Explorer rear end to keep the same lug pattern. Your choice of small blocks will fit fine; you can often (still) find running flathead motors cheap.
    I once saw one of these motors rebuilt in the car - head off, oil pan out, a couple of cylinders honed, etc. they are tough motors - what happened to yours?
  5. ehdave
    ehdave
    There's plenty of info on adding Explorer diff and front brakes on these and steering racks, it would be less work than a ch***is swap.
    Here' in Australia we had Chrysler Royal's based off the same body/ch***is with Poly V8's from factory too. Here's my Chrysler Royal AP2 Poly V8 Custom, I looked at a ch***is swap but upgrades are easier.
  6. NRErickson_84
    NRErickson_84
    Upon further inspection of my six I found that a large piece of sludge had plugged up an oil hole and starved a rod journal or I wasn't getting enough oil to a wrist pin. Motor won't turn at all.
    The six is done. The block may still be ok. It's been bored 40 over already. It will be cheaper for me to swap than fix. Most of the parts I have laying around. Definitely a budget build. Plus when it was driving it was all over the place so vice replacing the entire suspension anyway. This is the route I'm going. Cheap to find parts too. I'll have to cut a section out of the frame for sure and build new body mounts. Probably build the steering with u joints. As I go if anyone is looking for parts let me know.
  7. jimmy six
    jimmy six
    318 Poly with a Push****on Torqueflight....or a 270 hemi.
    ehdave likes this.
  8. oldwood
    oldwood
    from arkansas
    Keep it Mopar^^^^
  9. Bader2
    Bader2
    318/360/727 is way better combo than 350/350,identical in dimensions,way tougher. And not Chevy.
  10. "Hey guys. I acquired a 53 Cranbrook and I was trying to sell it but no one bought it "
    Who wouldn't want a car with the ultra-kool name of "Cranbrook"? ;)
  11. madfish
    madfish
    Drop it, put some white walls and imperial wire wheels on it. Add skirts, hop up the flathead and add two rows of
    louvers in the hood. My 2 cents.
  12. 73RR
    73RR
  13. NRErickson_84
    NRErickson_84
    That's what I thought but apparently everyone looking for a car around me.
  14. NRErickson_84
    NRErickson_84
    I would love to do a lot of the thinks you guys are talking about (especially the red ram hemi) but this is a budget build for now so I am limited my what I have laying around. I already have a 350 combo. Wait till you see what I have in store for it when I finish my shoebox. Then it's time to breakout the torch and welders.
  15. Gulf Coast Hemi
    Gulf Coast Hemi
    Can we get an updat on this vehicle? Look like I'm doing a 1953 belvedere the same way maybe ? Thanks
  16. Gulf Coast Hemi
    Gulf Coast Hemi
    Red ram hemi?
  17. bobss396
    bobss396
    Don't sell that 6 too short, they were capable of taking more than a .040" over bore.
  18. Matt Dudley
    Matt Dudley
    from New York
    I would recommend the original ch***is. An S10 ch***is fits… an S10. The suspension on the old Mopar cars is actually very good. Mopar built cars that were quality, not flashy. They put a lot of engineering into making sure they were good cars
  19. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
    x2
  20. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
  21. Stan Back
    Stan Back
    Please let me tell this story. I'll try to tell the story without and blaspheme words which would kick it out. This car was a $500 Plymouth. I bought a later model medium/small car built by a large general automotive manufacturer. From that I got much better braking systems without the stupid transmission drum, an easier steering system, a 3-speed automatic transmission, a non-generator 12-volt electrical system, a tilt power steering system and more for $250. Alas, I did slip back to use a 354" Chrysler motor, but not the carburetor system. They all function together and seem happy. I know I am.
