Technical how did you paint that? fixtures and taping technics
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 10, 2016.
  1. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    I really love post like these . Even after 40 years I still find new " hey that's a great idea"!!! moments Larry
    tb33anda3rd likes this.
  2. tb33anda3rd
    tb33anda3rd
    thanks me too. even if some of the stuff seams simple, it may "spark" an idea when needed.:)
  3. tb33anda3rd
    tb33anda3rd
    this cab could have been painted, inside and out, all at one time but trying to keep the hidden dust/dirt, that is hiding in the nooks and crannies of the inside, from getting on the out side, is impossible. i painted the insides and bottom first and any edges first. i also painted the hard to get spots on the outside, for example the backs of the hinges, the inside of the rain gutter, around the window, the underside of the cowl drain and the cowl vent channels. these are the areas that are hard to paint thoroughly without making a run/sag. by painting these areas prior to wet sanding i can be ***ured the areas have enough paint that when i do the final paint i don't risk a run.
    taping off all the insides, including holes will ***ure that the dust from the inside will not get in the paint. DSCF4984.JPG
    nunattax, cptn60 and ct1932ford like this.
  4. Cosmo49
    Cosmo49
    Stay with me on this one folks...give the picture a 'click'.
    pat59, Sporty45, bengeltiger and 4 others like this.
  5. jailbar joe
    jailbar joe
    needed to paint the custom nose/grille for my rod....think ala kart and found the best way to do it was bolt it to
    my engine stand....was able to rotate it for perfect coverage;)
  6. tb33anda3rd
    tb33anda3rd
    this is how i paint wheels now, but i would like to find a better way. i spin these as i spray by hand, only touching the inner rim that doesn't show. DSCF2531.JPG
  7. snopeks garage
    snopeks garage
    from macomb MI
    I made brackets to hang chains from the walls. Majority of things can be hung by wire, put on a saw horse or on top of a table. 20160420_071329.jpg
    shortypu and tb33anda3rd like this.
  8. paintman27
    paintman27
    from new jersey
    I'll play along. I built a wooden rack for the doors on my 46. I fastened it to the ceiling beams. I used 3/4" plywood on the sides this slid perfectly up into the window channels perfectly.
    [​IMG][/URL]
    nunattax, clem, pat59 and 6 others like this.
  9. falcongeorge
    falcongeorge
    from BC
    Now THATS a cool idea!
  10. Anything round and painted on two sides
    WillyKJr, brad2v and tb33anda3rd like this.
  11. TagMan
    TagMan
    I pick up cheap engine stands and made a couple to my own specs to use for painting. Here's one of my deck lid and a couple of my fenders on them. I used some s****s of Kindorf I scrounged up for the mounting arms. The work well for working on them, painting & sandblasting............................
    clem, tb33anda3rd and Wayne67vert like this.
  12. bigheadbaxter
    bigheadbaxter
    ImageUploadedByH.A.M.B.1461533940.229020.jpg ImageUploadedByH.A.M.B.1461533950.861449.jpg ImageUploadedByH.A.M.B.1461533968.211618.jpg ImageUploadedByH.A.M.B.1461534069.344399.jpg . Made these little stands to stabilize these buckets. I used this expanded metal table top to lightly bolt the bases to.
    MP&C, brad2v, tb33anda3rd and 3 others like this.
  13. blowby
    blowby
    from Nicasio Ca
    I learned a couple of tricks from my community college auto body cl*** teacher. If you are painting a car and not removing the windshield or rear window, and it is held in with a rubber gasket/molding, shove a piece of string or wire between the gasket and the body to hold them apart. Makes taping easier and gets some paint down under the gasket.
    The other doesn't directly involve painting. I had a couple of dime size holes in my window channel that I was fumbling trying to wedge a piece of metal in to weld. The teacher took the stud gun, zapped a stud to it, held it in the hole with that while he tacked it in. Duh..
  14. tb33anda3rd
    tb33anda3rd
    no holes in this air filter oil tray so i stuck a magnet to it and hooked the magnet DSCF5028.JPG
    bct, brad2v and bigheadbaxter like this.
  15. tb33anda3rd
    tb33anda3rd
    back side of dash painted gloss white with a spray bomb before installation. this makes working under the dash easier/brighter. DSCF5182.JPG
  16. The37Kid
    The37Kid
    ^^^^ Smoke damage from the wiring shows up a lot quicker too. Bob
    6-bangertim and bengeltiger like this.
  17. tb33anda3rd
    tb33anda3rd
    hah!
  18. jakesbackyard
    jakesbackyard
    from ND
    image.jpeg image.jpeg Hung my headlight bar to prime it...what a pain. Plywood and two pieces of ready rod will make painting it much easier.
  19. indyjps
    indyjps
    Set up your paint area with unistrut on the ceiling. You can get it at lowes, or almost any salvage yard as s****. Sure makes hanging parts easy. The posts that stop signs are put in with is about the same material in square, but I can't recommend stealing stop signs
  20. tb33anda3rd
    tb33anda3rd
    wrapped a magnet in paper, stuck it to a stand, this holds small parts for priming. DSCF5517.JPG
    clem, kbgreen, chrisp and 7 others like this.
  21. tb33anda3rd
    tb33anda3rd
    an extra piece of wire added to the end of a part gives you a handle to lift and twist to insure complete coverage. DSCF5518.JPG
  22. Binger
    Binger
    from wyoming
    I love that magnet idea!! I will be using that one.
  23. bigheadbaxter
    bigheadbaxter
    [​IMG][​IMG][​IMG]. My third hand paper/ tape dispenser. Mount it in the vise. Old bearing race. A piece of conduit with a dowel pin and some 1/4" plate.
  24. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I made this rotisserie last week to hold my hood for body work and painting. It will allow my to tilt it from side to side so that I can work the middle of the hood without leaning out over it. The other stand
    holds the two front fenders. partstand10.jpg The metal tubing is recycled shipping pallets given to me by a friend.
    John
    cptn60, Binger and tb33anda3rd like this.
  25. donno21
    donno21
    Great thread!!! Something I find handy is a "Lazy Susan "turn table for painting small parts.
  26. tb33anda3rd
    tb33anda3rd
    something sometimes is better than nothing. needed protection from the elements.
    brush and roller, prime and paint the inside of the bed.
    nunattax and deathrowdave like this.
  27. bigheadbaxter
    bigheadbaxter
  28. atch
    atch
    ...and if you power the lazy susan with an old electric rotisserie motor it turns itself at a perfect speed. Also works to weld around round parts.
  29. thommoina33
    thommoina33
    Alliance Member
    from australia
    Some all thread, nuts and rhs to paint both sides of my tank.
  30. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^ That worked very nicely. Bob
