Technical 1955 - 1959 Chevy truck question
Discussion in 'Traditional Hot Rods' started by deuceV8, May 8, 2016.
  1. deuceV8
    deuceV8
    I'm currently putting a dropped axle under my 55 Chevy truck and want to upgrade the steering box. Does anyone behave any suggestions for a upgraded manual steering box and where to get it. Thanks
  2. squirrel
    The only "upgrade" I can think of, is to overhaul it, they usually need a new pitman shaft bushing and seal. And some fresh grade 0 grease.
    Do you have some particular reason you want to upgrade it? Maybe if there's something wrong with it, we can help you figure out how to fix that problem.
  3. Mengestwinspeedshop
    Mengestwinspeedshop
    from Santa Rosa
    Those are pretty damn good steering boxes from the factory, maybe just needs a rebuild as squirrel mentioned
  4. I agree with the guys above. I had a '57 PU as my daily driver for 10 years. Did a frame-up on it twice, ended up with a 327 & TH-400. Never even thought about changing the steering -- it worked great.
    czuch likes this.
  5. deuceV8
    deuceV8
    Great thanks for the info I bought this truck not running and I going through it so I thought it would be a good time. But if they are good I just rebuild it.
  6. mr57
    mr57
    I know there is a conversion kit to convert a 567 car to roller bearings in the idler arm, called "poor man's power steering". Maybe check with CPP or Brothers or some other supplier and see if there is a similar kit for a truck? I've driven mine for 30 years without....Although I have bad carpal tunnel now so I think I just might take my own advice......
  7. squirrel
    trucks don't have an idler arm....
  8. mr57
    mr57
    And that would be why I couldn't find it.......
  9. 31Apickup
    31Apickup
  10. squirrel
    that's the ****py one...think about how the geometry will work, with those short arms.
  11. If it ain't broke, don't fix it. ;)
