Technical Speedway 97 carbs... Opinions?
Discussion in 'Traditional Hot Rods' started by Dad Was A Racer, May 9, 2016.
  1. Dad Was A Racer
    Dad Was A Racer
    Anyone have first-hand experience with the repop 97 carbs that Speedway is producing? Since I don't see them identified otherwise, I'm ***uming they're produced overseas (ie. China) so tell me if I'm wrong. The "do not use with ethanol fuels" warning worries me a bit, too. Am I better off with the current production Edlebrock 94's? Going on a 3x2 Offy intake on a 8BA flathead FYI.
  2. X38
    X38
    Try the search function. Been discussed a lot over the years. And don't confuse the Speedway super 7 with the actual repro 97.
  3. Kiwi 4d
    Kiwi 4d
  4. Dino 64
    Dino 64
    from Virginia
  5. mgtstumpy
    mgtstumpy
    Not offering my opinion as I've expertise in this area.
  6. Dad Was A Racer
    Dad Was A Racer
    That's exactly the "informed opinion" I was looking for... I see that Mercury Charlie in Austin is listed as a dealer for the Strombergs. Is there a recommend dealer (maybe Alliance member) for these?
  7. Blue One
    Blue One
    from Alberta
  8. Dad Was A Racer
    Dad Was A Racer
    Not sure what the connection is between Mayor McCheese and the Stromberg 97 is, but I'll admit my ignorance.
  9. alchemy
    alchemy
    Uncle Max is the Stromberg expert. He can rebuild originals, or sells and warrantys the real reproduction Strombergs. He is not a dealer for the Chinese Speedway carbs.
  10. IronTrap
    IronTrap
    Going to be running a set of the 97 barn finds on my car. Can't wait to get them on, they look *****in'!
  11. Bruce Lancaster
    Bruce Lancaster
    I find the "do not use with ethanol fuels" to be very disturbing. We may not like the ethanol gas, but even if you live in an area where there are options how far can you get before you have to choose between using the stuff and walking? Something that can't run on the gas we must use could be considered BROKEN.
    zzford likes this.
  12. Truck64
    Truck64
    from Ioway
    Sounds like standard issue CYA boilerplate, though.
  13. Tim
    Tim
    from KCMO
    So I looked at the comparison linked above and all I got out of it is that the speedway carb flows less, that someone has done a dyno test comparison but doesn't offer a link or anything of the findings .
    The rest is just pointing out that it's not a 97 clone just a carb that basically looks like one, and has questionable quality.
    So.... Anybody got a link to the dyno test?
  14. jim1932
    jim1932
    Ditto..... Gotten 4 carbs over the past several years for stuff. He is the guy
  15. Schwanke Engines
    Schwanke Engines
    They are like $400.00 each aren't they? I am running dual 94's on my 286 Flatty, I will have less than $200.00 in them after the rebuild kits.
  16. Rancho55
    Rancho55
    Ok, as the first actual user of the 9super7's to post, I'd like to say how much of a good experience I've had with them! Pretty much bottled them on and went. Running a progressive linkage on a triple setup on a sbc. No trouble starting ever, excellent throttle response and great gas mileage, been running them for two years. Only prob I've had was a br*** curl got stuck in the needle and swat and it jammed open. Would gladly shell out for another set.
  17. Ryan
    Ryan
    ADMINISTRATOR
    We've torn one down and compared it to a real 97 as well as a Clive made 97. The Speedway carbs are Chinese made **** in every sense of the word. Honestly, it should be a crime to sell them...
  18. Blue One
    Blue One
    from Alberta
    Read Ryans reply and educate yourself.
  19. tfeverfred
    tfeverfred
  20. Tim
    Tim
    from KCMO
    Took a minute but here is a direct link to the dyno test that's been mentioned several times but never actually linked
    http://www.garagescene.co.uk/stuff/97.doc
    It doesn't so much talk about power differences as much as how terrible the carbs are. The side by side comparison talks a lot about flaws and what could possibly happen and the dyno confirms those things. Take a look if you like
  21. sacredsteel1
    sacredsteel1
    Speedway = Harbor Freight for hot rodders
    Dale Ferrell, oj and X38 like this.
  22. flatmotor40
    flatmotor40
    from georgia
    Been running 2 Speedways 97 for 3 yrs no problems.Cranks first time and had no problems except when I changed jets the plugs gasket leaked but put 4 more on and no leak.Bad gasket to re use.I guess everyone has good and bad with everything
  23. Ryan
    Ryan
    ADMINISTRATOR
    You got lucky, but honestly... It's just a matter of time. If you take the carbs apart and just use your eyes, you won't need to see the before linked to dyno sheets. Everything about the carb is inferior. Everything about the carb speaks to cutting corners. Everything about the carb goes against what hot rodding is about (to me).
    Seriously, if you are in the market for 97s, don't waste your time on the Speedway import ****.
    http://www.luckys-speed-shop.com/Genuine_Stromberg_vs_Speedway_9-Super-7.pdf
  24. Bruce Lancaster
    Bruce Lancaster
    If a carburetor hasn't shown its mettle by surviving the Depression and WWII, let's say it was made last month and just got off the boat from China, how do you know whether it's tough enough to survive? This board is pretty much about Olde Stuff*, and that's why.
    *With some tolerance for 5 speed transmissions and radios that get FM...
    oj likes this.
  25. badvolvo
    badvolvo
    I have original 97's on one of my flatheads, and three speedway 9super7's on a small block. both have the same kind of issues, minor leaks. both work great for me. But cleaning out Dad's garage, i brought home 6- 97's and a few 94's. i will be building up the old 97's and putting them on my small block. To no fault of the 9super7's I just want that little 97 on the side. I am not concerned with the CFM, as the SB is a driver, It would be faster with a single 4 bbl. not too old school with that AC compressor anyway.
  26. OLDSMAN
    OLDSMAN
    I would trust Ryans thoughts, These carbs Speedway started selling after I left Speedway I still buy some things from them but stay away from the Chinese stuff
  27. flatmotor40
    flatmotor40
    from georgia
    I don't think my flathead will do a dyno at least in HP but I just noted that I have had no trouble with my Speedway and what can you really buy that is not made in China or overseas.It is a day and time we live in.Not t0 get on that soap box.
  28. Rod Father 1944
    Rod Father 1944
    Put 2 Speedway super 97's on my merc and tried for over 2 months to get it to run right. Sooty plugs, starvation, you name it. Finally sent the carbs back. They treated me well and sent back my money. I bought 2 new original 97's from Summit and never a problem. Runs like a bandit.
  29. Rustygt
    Rustygt
    from Emeryville
    Get two 94's and have Henry at Ole's carb shop in South SF rebuild them and be happy ! Or buy two new Edlebrock ones. Or U-Max etc Speedway okay for a small amount of stuff , my experience avoid if possible:(
  30. uncle max
    uncle max
    Courtesy discount on all Genuine Stromberg carbs and parts is extended to anyone reading this.
    I am also the U.S. warranty guy - what little there is - No questions asked; parts, labor and free, fast return shipping.
