Projects New project 1936 Chevy Master Deluxe
Discussion in 'Traditional Hot Rods' started by Simon Intrudor, Apr 28, 2016.
  1. Simon Intrudor
    Simon Intrudor
    So for some reason my last thread was deleted, must be some aussie hate going on haha.
    Anyway I just purchased my first project, a 1936 Chevrolet Master Deluxe.
    Got a few big plans for her which were in my other post so I don't wanna have to type them again because I'm lazy.
    6inarow likes this.
  2. Smiffy
    Smiffy
    Nice shape and a good project. Hope you've got your wood working tools ready these old girls are full of it. All the best look forward to updates.
  3. Simon Intrudor
    Simon Intrudor
    All the wood will be ripped out and replaced with steel :)
    Sent from my SM-N9005 using H.A.M.B. mobile app
  4. Simon Intrudor
    Simon Intrudor
    Can admin please move this to the right section
  5. I think i seen one of these here that they turned into a panel looked pretty cool good luck
    Sent from my LGMS330 using H.A.M.B. mobile app
  6. Simon Intrudor
    Simon Intrudor
    First step is to remove all the wood and replace with steel.
    Will post updates as i go.
    Gonna be a long term project.
  7. I don't envy your having to build a steel framework for that car. I just did that with a '21 T Roadster body. It was a lot of work, but nothing like what you're up against. :eek:
  8. Hey, steering wheel on the wrong side.
    Ha, Ha!!
    Nice car. Keep us posted..............
  9. Simon Intrudor
    Simon Intrudor
    I have the determination so hopefully she comes out good!
    Haha honestly i wish it was left hand drive. This chev is different from the American ones, ch***is built in America and body is built over here in Aud by GMH(Holden)
  10. Simon Intrudor
    Simon Intrudor
    Just wondering what everyone thinks. I plan on cutting the roof down and steel out of the frame, which one should be done first?
  11. Blade58
    Blade58
    from apopka ,Fl
    Frame 1st, here is a picture of one just clean and lowered and one with a chopped top on a 2 door
    bigheadbaxter likes this.
  12. Simon Intrudor
    Simon Intrudor
    Started stripping the body down to lift off the ch***is
  13. tb33anda3rd
    tb33anda3rd
    you should rebuild all the body supports and get it square ON the ch***is. the car should be sitting square, on four even tires or jack stands.
    don't rip all the wood out if it is good. hard to tell from here but the wood around the door windows looks fine. replacing/repairing/bracing the wood might be easier than making steel replacements.
  14. dorf
    dorf
    from ohio
    some thing doesn't jive . those are 35 doors .either the radiator shell has been changed or the doors have been changed , I suspect the shell .
  15. X38
    X38
    Back a few posts, from the OP:
  16. Simon Intrudor
    Simon Intrudor
    Aussie made body on chev ch***is
    Tripped me out aswell
  17. Simon Intrudor
    Simon Intrudor
    tb33anda3rd likes this.
  18. 38Chevy454
    38Chevy454
    Sheetmetal seems good shape, and glad to hear you have a good at***ude to change out the wood for steel. One year later and it would not have all that wood. I always liked the more rounded windows on the pre-37 as opposed to the 37-39 shape.
    You also got the unfortunate master deluxe front end. I have that same on my 37 Chevy Ute. It works, but the std solid axle is a lot better.
  19. mgtstumpy
    mgtstumpy
    Lots of work ahead. There is a local rodder down here steeling out his body and doors at present. Holden body won't interchange with Fisher body, only the fenders and hood; doors etc are different.
    You could tudor and chop it;)
  20. Simon Intrudor
    Simon Intrudor
    Well my last name is Tudor! !
  21. X38
    X38
    FORD is the only company that spelled two door like that.
    Pet irk.
  22. DLRIDES
    DLRIDES
    from Newton NC
    Level and support frame, chop, then replace wood before thinking of removing body. I just went through this on a 32 Chevy.
  23. DLRIDES
    DLRIDES
    from Newton NC
    [/QUOTE]
    I would NOT reccomend this.
  24. Simon Intrudor
    Simon Intrudor
    I would NOT reccomend this.[/QUOTE]
    Should i steel it out then lift off? Cause i wanna get the ch***is blasted and powdercoated
  25. tb33anda3rd
    tb33anda3rd
    Sent from my SM-N9005 using H.A.M.B. mobile app[/QUOTE]
    it is best to "pre build" the car before doing any final paint/powdercoat. get the frame level, then get the body welded up. fit the mechanicals, plan out every hole that needs to be drilled, bracket that needs to be added, notch that needs to be cut, etc before doing paint work. i have even gone as far as driving a hot rod i built before blowing it all apart and painting.it seems like extra work but it saves time and repainting.
    Late to the Party likes this.
  26. Simon Intrudor
    Simon Intrudor
    Ah yep i understand now haha. Thanks for the advice
  27. Simon Intrudor
    Simon Intrudor
    Removed all the body lead and she aint pretty...
  28. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
  29. Gary Addcox
    Gary Addcox
    Are these Aussies speaking Kiwi ?
