Projects Official Chrysler Flathead 6 W/ Dual Carbs Dual Exhaust Thread
Discussion in 'The Hokey Ass Message Board' started by Flat Six Fix, May 12, 2016.
  1. Flat Six Fix
    Flat Six Fix
    Today my new George Asche/Kingsbury AoK Racing dual carb intake, tru split exhaust (not just a 2nd dump) , large bore/cfm truck Carter B&Bs linkages, arrived.
    This is going onto my 1955 Fargo 238 Chrysler flathead 6 engine.
    I plan to use this set-up on this engine, for the time being, and do have a high-perf 265 Mopar flattie in the planning stages.
    So any and all please share your stories experiences and post on this topic...
    lemondana, Sharpone, EVL401 and 6 others like this.
  2. Flat Six Fix
    Flat Six Fix
    bump for the day shift, gotta be some Chrysler flathead 6 guys on here
    Sharpone, 6inarow and Rumblin Rolf like this.
  3. wbrw32
    wbrw32
  4. Flat Six Fix
    Flat Six Fix
    Really!
    Sharpone and Rumblin Rolf like this.
  5. patmanta
    patmanta
    from Woburn, MA
    I'm going to tag along. I was interested in doing a flat six when I still had that '17 Dodge a while back.
    Sharpone likes this.
  6. Flat Six Fix
    Flat Six Fix
    Okay great, nice to meet your acquaintance BTW.
    There are a couple of threads, relating to Chrysler flathead 6 performance, but not much.
    I invite all those interested or experienced to share on this topic...
  7. deanopopino
    deanopopino
    from Troy, MO
    Something like that would look sweet under the hood of my '53 Plymouth.
  8. patmanta
    patmanta
    from Woburn, MA
    Likewise. Here's the link to my old thread. There's some discussion on these engines in it and maybe some links/threads that you haven't found yet:
    http://www.jalopyjournal.com/forum/...hers-touring-halloween-yard-art.947165/page-2
  9. Flat Six Fix
    Flat Six Fix
    It would look good, but this is for a 25 inch long block engine.
    All Canadian Chrysler flathead 6s were based on the 25 inch long blocks..
  10. Bmartin
    Bmartin
    from mesa,az
    I'm working on getting mine together. 230 with Edmunds intake and split exhaust. Engine and OD ****** built by Mr. Asche.
  11. steinauge
    steinauge
    from 1960
    I am waiting on the block for my speedster to get back from the machine shop.Once that happens I can go ahead and ***emble the engine.(1949 218)
  12. coffman
    coffman
    '54 Chrysler 264ci, balanced and bored, Spitfire head cut .125 and cleared for valves, factory 2.5" Dodge truck intake& exhaust,Webber 2barrels, Heim joint custom linkage. 5spd. In my '47 Plymouth Deluxe. IMG_2949.JPG IMG_2937.JPG
  13. Flat Six Fix
    Flat Six Fix
    Very Nice.
    Betcha your Plym, pulls away a lot better than a short 218 stock engine? Very Nice set-up
  14. oldwood
    oldwood
    from arkansas
    I always look at the threads dealing with the Mopar Flathead. Here is my work in progress. Flathead with 3 onda tree.
      258.1 KB
    55Deso and Truckdoctor Andy like this.
  15. Robin (UK)
    Robin (UK)
    I run this Plymouth convertible in London, England...
    230 Dodge motor, Fenton head, Fenton headers with dual pipes all the way back.
    Plus an overdrive transmission.
    I've recently changed from a Sharp dual carb intake, to a water-heated Edmunds. That seems to have given the car even more 'pep'.
    I'll be running the car (again) at the VHRA Hot Rod Races at Pendine Sands in a few weeks time...
    Bigcheese327, hfh, Jet96 and 10 others like this.
  16. 36DodgeRam
    36DodgeRam
    I put this Fenton intake system together in the late seventies and ran it on my '40 coupe for many years. These flat head sixes look, run, and sound great with the dual intake and split exhaust! Fenton intake.jpg
  17. Flat Six Fix
    Flat Six Fix
    Yup, nice engines, and still built for modern times, full pressure oil, bearing inserts, aluminum pistons, forged cranks, hardened exhaust valve seats.
    How much difference do you think I should notice with my new upgrades?
    At some point either building a 265, or gonna heat up this motor, shaved head, hotter cam...
  18. Flat Six Fix
    Flat Six Fix
    Well a little progress, have a new gasket set for the manifolds.
    The manifold stud nuts back off easy, the good news, bad news is 2 studs are backing out, so have to drain antifreeze, no big deal.
    I had the manifolds off less than 2 years ago, so the ****** of a job was back then.
    I have a carter gl*** bowl filter, so will mount it with the fuel block, and it will be on the firewall far away from the exhaust...
    Hope to install the duals soon, tossing around whether I will repaint engine and paint up all the parts..
  19. Flat Six Fix
    Flat Six Fix
    Here is a video I made earlier today, did the install last week, still need air cleaners and a little more exhaust work.
    I built all the exhaust at home with what I had,
    Hollywood-East likes this.
  20. Flat Six Fix
    Flat Six Fix
    Here spruced up the engine, waiting on air cleaners, but done for now, if that's possible.
    The engine is a little tired, but gonna build a 265, hotter cam and shaved head yada yada, and swap in at some point, that will liven up things.
    Big Swede, mgtstumpy and Johnnyr13 like this.
  21. Well hey, swing by and pick me up so we can go zooming around.;)
    Sounds good, I have always liked the ****ing sound a carb on an old flathead 6 makes. One of my buddies in high school had a '48 Desoto that we out the biggest Chrysler 6 in it we could find. Whenever he g***ed it the carb made the absolute neatest ****ing sound. I loved it. :cool:
  22. Flat Six Fix
    Flat Six Fix
    Hey ******, it ain't too far, well just about 800 miles north on I 29 in Canada.
    Its a nice set-up, might be burning a tad rich, have not had a chance to get out for a decent long drive....
  23. Well at least you can't get lost on the way. :D
  24. oldwood
    oldwood
    from arkansas
    What is the approximate cost to do a dual carb and exhaust for the 230??? Ya'll have me itching to do this to my green '59 Dodge Coronet 4dr sedan. I need to sell the tan colored '59 which also has a flathead in it.
      258.1 KB
      223 KB
    Caprice89 likes this.
  25. UNCLECHET
    UNCLECHET
    I like it! Keep up the good work!
  26. mrdodge
    mrdodge
    Looking to put a flat 6 in my Model A RPU once the banger dies (it's getting sick). Have a 218 out of a '53 Dodge panel van. I've got an Edgy finned head & side plates & a twin carb manifold to go with it & a S10 T5 to replace the 3 speeder. If anyone knows how to fit a 23" motor into a Model A engine bay without cutting the firewall, I'd be real keen to hear your thoughts.
  27. Flat Six Fix
    Flat Six Fix
    With freshly rebuilt matching carbs, the linkage, the dual intake, either header or a customade made split exhaust manifold, and new exhaust, count on a $1000. If you pull the cam and put in something with more L&D, then add $250
    That would be kool, before you get all hung up on the T5 with this set-up, do your homework on the pitfalls of that conversion, as there are pitfalls.
    You can convert t a Chrylser A833 4 spd overdrive, with a very simple adapter plate, the gear spread is right, and this is a tough trans.
    Byron McMahon, ezrods, FIFTY2 and 3 others like this.
  28. Flat Six Fix
    Flat Six Fix
    Here's an updated video,
    Big Swede likes this.
  29. casper50
    casper50
    from alaska
    Can anyone give me some tips/instructions on how to dial in a dual carb setup on a 230ci? I have the va***n gauge but have no idea how to go about this.
  30. mrdodge
    mrdodge
