home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. Jethro
    Jethro
    I've never seen that before.....I really like it!......Gonna make one !
  2. seb fontana
    seb fontana
    from ct
    Put a locnut on bolt to keep from spinning?
  3. bigheadbaxter
    bigheadbaxter
    Yessir or bottom out on the tool
  4. RichFox
    RichFox
    i already posted these pictures on the"Re purposing parts" thread. because I couldn't find this one. But as long as we are talking about band saws. I wanted to cut up that aluminum head to stretch it. But the vise jaws wouldn't open enough even though the blade opening was long enough to cut the head. And sometimes i want to cut something on an angle. Or it's to short for the vise to grip it. So I made two T nuts to fit the moveable vise jaw guide slot. Tapped them both 1/2 and 3/8 so i could use either. now I can just use finger clamps to hold stuff or put the vise back on if I want.
    Speedys Garage, fauj and saltflats like this.
  5. oldpl8s
    oldpl8s
    Not much of a tool, but it did the trick when I needed it. I was helping my son replace his clutch and the pilot bushing puller we had was too big to fit in the bushing. I heard about packing the hole with grease then finding a rod the size if the hole to pound on. This would compact the grease and force the bushing out. I never thought it would work. He said the grease makes a mess and bread works better. I told him he was crazy, but we tried it and it worked!
    We used the slide hammer rod, bread and a hammer. Here it is with the bread plug. pilot-bearing-bread2.JPG
    NAES, 1952B3b23, JOYFLEA and 3 others like this.
  6. cretin
    cretin
    I did the grease trick on my 331 and it worked great. I was even surprised that worked as well as it did. I heard about the bread too, and was quite curious if it would work also. Guess I've got my answer!
  7. slack
    slack
    I cant remember where I picked up that little trick but I have always used bread too. Still messy (It mixes with the residual grease) but easier to clean up. I wrap A rag around the rod to use as a spatter shield. You can also stuff it into a copper riser (that is holding water) so it can be soldered when plumbing copper pipe. It will disintegrate and come through the fixture after. Who'da thunk it? o_O
  8. taildragger1957
    taildragger1957
    I always use wet, wadded up paper. Works like a charm. I bet the bread does too.
    loudbang and slack like this.
  9. henry's57bbwagon
    henry's57bbwagon
    I have threaded the bushing and then used a bolt to push it out.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Once I did the thread trick, I never messed with anything else. In fact the last time i just kept turning the tap and the bushing came right out. Saved a step.
    loudbang, rmcroadster and slack like this.
  11. cretin
    cretin
    I needed to machine my F-1 steering box so I could put a new flange on it. The 4 jaw chuck we have was a bit too small to hold the box, so I made this little fixture to use the 3 jaw. It worked well.
  12. ago
    ago
    from pgh. pa.
    Using your head!
  13. Eljorger
    Eljorger
    New metal shaping stand for sandbag/anvil/dolly...may add other attachments later stand 1.jpg stand 2.jpg stand 3.jpg stand 4.jpg stand 5.jpg stand 6.jpg
    whtbaron, saltflats, loudbang and 3 others like this.
  14. Eljorger
    Eljorger
    Clamp rack...keeps them handy and all in one place...rolls under welding bench. 20150424_150250.jpg 13062100_10206144307871125_3745020683946590977_n.jpg 13062230_10206144305551067_7214013927090109022_n.jpg 13062323_10206144304791048_7277623695359518882_n.jpg
    loudbang, cretin and bct like this.
  15. atch
    atch
    Eljorger likes this.
  16. Eljorger
    Eljorger
    Upgraded and motorized HF Bead roller. 5 volt 15 amp DC power supply with foot pedal control and reverse. added a sprocket and chain and a skateboard 20160116_183044.jpg 20160116_193530.jpg 20160116_193547.jpg 20160117_132526.jpg 20160117_132539.jpg 20160121_174834.jpg 20160121_174946.jpg 20160221_130600.jpg 20160223_171053.jpg 20160319_122324.jpg 20160319_191546.jpg 20160319_191604.jpg 20160319_191942.jpg 20160323_101152.jpg 20160323_101213_001.jpg 20160323_101236.jpg 20160323_101337.jpg 20160323_101152.jpg 20160323_101352.jpg 20160323_101945.jpg wheel for tension.
  17. Eljorger
    Eljorger
    Thanks for the suggestion.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Eljorger,
    That's what i'm talking about. A friggen build thread right inside the main thread. I like all the stuff here,
  19. Fatbrosracing
    Fatbrosracing
    from Australia
    First photos are of a radius cutter I made for my lathe, so I could make rollers for the ring roller I made. IMG_2356.JPG IMG_2357.JPG IMG_2400.JPG IMG_1746.jpg
    UNSHINED 2, RMFH, whtbaron and 7 others like this.
  20. cretin
    cretin
    Very nice. I've been wanting to make a radius cutter like that. I'm not happy with the one we have.
  21. Eljorger
    Eljorger
    Ulu, cretin, bct and 2 others like this.
  22. Gray Ford
    Gray Ford
    from Illinois
    Excellent work .. Good thinking outside the box on the panel holder ....
    Bob...
  23. atch
    atch
  24. PKap
    PKap
    from Alberta
    We call them "bessy clamps" I bought mine at my local welding supply store, and almost every welder I know has a few.
  25. drtrcrV-8
    drtrcrV-8
    Commonly referred to as "Bessey" clamps(due to name of early Co. that makes them), they, or similar, are usually available at welding supply shops, Tractor Supply, Orchard Supply, Home Depot, etc
  26. Sinister Sleds
    Sinister Sleds
    from Gloucester
    In all honesty I'm probably going to steal this idea (for personal use) [emoji2]
    Sent from my SM-G900P using Tapatalk
  27. Eljorger
    Eljorger
    I bought these at Home Depot here in San Diego, they are German made...work really well...about 50.00 bucks a piece.
  28. atch
    atch
    Thanx, guys. I'm surprised I've never seen them before. However, at 50 bux each it's a slam dunk I'll never have any.
    enloe likes this.
  29. bct
    bct
    Keep an eye out in the local cl***ifieds. The best clamps you can buy are used and 30+ years old.
  30. cretin
    cretin
    I got a set of I think it was 8 on sale at MSC. Don't know if they are still on sale, but worth a look.
