Projects The bucket of ugly! A de-uglifying thread...
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 14, 2013.
  1. k1w1rodder
    k1w1rodder
  2. steel rebel
    steel rebel
    CUT AWAY. THE LESS THE BETTER.
    verde742 likes this.
  3. verde742
    verde742
    And sell the bottom to someone.... ya don't need it !!!:D
    Don't remember seeing a chopped grille shell, :oops:with a stock bottom, that looked good..
  4. steel rebel
    steel rebel
    I have to agree verd The bottom hanging out there doesn't look good. Sorry Graham but look at Tweedy Pie and you will understand.
    brad2v and verde742 like this.
  5. verde742
    verde742
    A PERFECT example of UGLY !!! thanks Rebel...
  6. Blue One
    Blue One
    from Alberta
    I don't know about that fellas, I cut an inch and a half out of mine and then shortened and retained the bottom to cover my front crossmember a little and hide the U bolts that hold the spring a little as well.
    I think it looks good combined with my SS mesh screen and headlight bar. :)
    Don't forget that I also have the MT products Lincoln front drum brakes now in place of the discs :cool:
    Larry.
  7. verde742
    verde742
    Not TOO bad, But if it gets chromed, IT will light up !!!!? IMO
  8. 26 T Ford RPU
    26 T Ford RPU
    You can only loose the bottom if you have a spring out front to hide it. JMO. JW
  9. Tim_with_a_T
    Tim_with_a_T
    I think that with enough thought, either leaving the bottom off the cut down shell or splicing it back on can look good, as we've seen good examples of both. I do agree that Tweedy Pie would have looked better with the bottom left off - it looks awkward from the front.
    Random question time: anyone on here have a receiver hitch on their bucket (or pictures of one)? I've got a bad crush on teardrop trailers lately... I have two ideas so far- one bad one, and one maybe. I'd like to see pics if one of you has already gone through that battle.
  10. Blue One
    Blue One
    from Alberta
    It will not be chromed, it will be body color.
    dana barlow and Ron Funkhouser like this.
  11. verde742
    verde742
    " Never do anything you wouldn't want to explain to a paramedic"
  12. steel rebel
    steel rebel
    Just a couple of guys opinion and you know that THEY say about opinions and ass holes. If you are sure you like the look, or don't care, it is your rod. Again I say get back and look, and look, and look if you do care. I'm still doing that after 36 years and still things on my roadster bug me.
  13. t-rod
    t-rod
    My car is oranges to your apples, but my hitch is one of my favorite details on my car, and this is a chance to show it off.[​IMG][​IMG]
  14. Tim_with_a_T
    Tim_with_a_T
    How is it attached to your frame? Bolted? Welded? Pictures? Your stealth setup looks great. Nice job!
    brad2v and t-rod like this.
  15. t-rod
    t-rod
    Thanks! Years ago, we had a Chevy Venture which I added a hitch to. While the roadster was under construction, the van died. Before it went to the wrecking yard, I pulled the hitch off of it. That hitch got cut up to fit this car. Two "stubs" are welded to the Model A rear crossmember, then the cut up hitch is installed to them. I found a flat 4 plug with a rubber flange around it (it has a Ford logo on it, maybe off a truck?) which I mounted into a piece of aluminum sheet, then mounted to the hitch.[​IMG][​IMG][​IMG]
    loudbang and AndersF like this.
  16. tfeverfred
    tfeverfred
    Now, THAT, is cooler than the few parts I got this week. Awesome thinking on that one.
    AndersF and t-rod like this.
  17. t-rod
    t-rod
    Thank you.
    Sent from my SM-G386T using H.A.M.B. mobile app
  18. t-rod
    t-rod
    However, I'm interested in the progress on your car, too.
  19. RICH B
    RICH B
    You got some more parts! Where's your update? :) Gotta keep this going.
  20. tfeverfred
    tfeverfred
    It's just a few more pieces to complete my chassis. Brake/master cylinder assembly, engine mounts for the frame, steering box mount and transmission mount/cross member.
    The trans/cross member has another piece which mounts the trans and attaches to this piece. Note the holes, which allow any number of different transmissions to be used.
    Beautifully TIG welded.
    Blue One and RICH B like this.
  21. tfeverfred
    tfeverfred
    The master cylinder arrived today, so I did a trial fit.
  22. k1w1rodder
    k1w1rodder
  23. Blue One
    Blue One
    from Alberta
    I like the lower look. I think it will be great. Better than before. :cool:
  24. Looks MIG to me.
  25. steel rebel
    steel rebel
    Much better Graham. I like it.
  26. Blue One
    Blue One
    from Alberta
    Nope, Tig.
  27. Needs practice then. But, I am used to being around some of the best welds you can find so I am jaded.
  28. 26 T Ford RPU
    26 T Ford RPU
    Looks good Graham, but I liked it before as well.:rolleyes::) JW
  29. tfeverfred
    tfeverfred
    Great work, Graham!
  30. tfeverfred
    tfeverfred
    Cool. Let's see some.
    6inarow likes this.
