Technical 1939 Mercury Build
Discussion in 'Traditional Customs' started by swissmike, Jun 28, 2015.
  1. swissmike
    swissmike
    Made a flange on the side of the door jamb long enough to use the shrinker. This will leave a formed edge rather than a weld.
    The shrinker couldn't quite make a tight enough radius, so I cut the flange back to the final height
    And formed it over the wooden buck.
    Fit is good enough for now. I first bent the crease in the piece using the vise and flanging pliers but the crease was not crisp enough and I had to chase it from the back of the panel.
    Spot welded the left piece in place. I have to weld the fender nuts on the middle piece and do some final adjustments before welding it in. I always want to have at least one solid reference point from an original body panel so I hopefully won't be off much in the end.
  2. Hank37
    Hank37
    Subscribed to a informative piece of body work!
  3. swissmike
    swissmike
    I was missing the two caged nuts for the fender to continue and weld the piece in place. The caged nuts are 5/16-24, but are available from Mac's etc. Instead of waiting for a week I decided to make a few from s****.
    I flattened one of the old ones to use as a template, the made the square nuts from stainless stock, and copied the template in 18 gauge steel. I made a tool to serve as a buck and help form the cage.
    Clamp a flat piece, then fold the short sides down, and start flattening the longer tabs.
    To finish, force the longer tabs between the jaws of the vice with a hammer, the progressively tighten the vice and repeat until sharp corners are reached.
    Finished cage nuts!
  4. Peanut 1959
    Peanut 1959
  5. jakespeed63
    jakespeed63
    Peanut1959, My sentiments exactly! Does Lauren ever come out to the garage, to see all this genius in action?? ;)
  6. 1952B3b23
    1952B3b23
    from Western MA
    Nice work, it's cool to see you doing a lot with non-fancy tools. You're using the most important tool, your brain. Good work man!
    -Chris
  7. swissmike
    swissmike
    Thanks for the comments!
  8. The 39 guy
    The 39 guy
    This is my kind of thread with lots of shots of the steps it takes to make all of the little pieces. I am enjoying your posts and learning new little tips each time.
  9. ynottayblock
    ynottayblock
    Amen to that! I love seeing inner structure metal work fabrication
  10. Great car and a great thread !
  11. swissmike
    swissmike
    Making the door jamb piece with a lip to be able to weld on the flat rather than a corner edge.
    The flange will eventually be spot welded to the subrail.
    Made a small angle piece and bent it using the stretcher, then welded in place.
    Here is the middle piece with the new caged nuts welded in.
    Everything tacked in place. Took me several tries and a lot of swearing to get the first couple of tacks in place without pulling the pieces out of alignment. Didn't help that I had the welder set too high.
    Everything will be welded solid next and the the only piece left is a cap at the bottom, with a flange going under the subrail for spot welding.
    Profile seems to match ok. I really hope everything will line up with the doors in place.
  12. bengeltiger
    bengeltiger
    Wow, been away from the HAMB for a little while and missed a bunch! Great work, thanks for sharing your progress.
    swissmike likes this.
  13. vonpahrkur
    vonpahrkur
    You're sure doing a nice job, keep up the excellent work!
  14. ken/alabama
    ken/alabama
    from Alabama
    Is anyone still reproducing the engine mounts for the Cadillac swap ? I'm looking for a pair.
  15. vonpahrkur
    vonpahrkur
    i bought a set a while back for my merc, i contacted the guy i got them from and will get you the info when i hear back.
  16. 1941coupe
    1941coupe
    I also bought repro hurst caddy motor mounts from a guy on ebay he makes them,real nice quality im working on a 53 331 caddy engine that will hopefully wind up in an early ford
  17. X38
    X38
    Thanks for do***enting everything. Threads like these are the best of the HAMB.
    vonpahrkur and kidcampbell71 like this.
  18. What a great thread. Thanks for taking the time to post your progress and pics
  19. swissmike
    swissmike
    Thanks everybody. Will have more updates this weekend.
    I bought my motor mounts off eBay from probably the same guy.
    They are nicely made and great price.
  20. swissmike
    swissmike
    All welded up. Ended up with a low spot at the top. Might cut out a strip and make a small patch, or just fill it in. But now let's move on.
    Bottom of B-post: made a template, transferred to quarter inch plate and tacked to sheet metal piece.
    I always use a hardwood block to shape the edge. The trim the edge so the weld will be in the middle of the jog. The mating piece will be formed on the stretcher, the trimmed to the correct height. Same with the last piece...
    Welded from B-side.
  21. swissmike
    swissmike
    Starting on the lower quarter by making a wooden template again.
    Used the break to make the first bend, then used the English wheel to give it a 1/4" crown. Then needed to do an opposite bend, which was hard to do because of the crown. I'll probably only use the wheel after this step on the other side
    Starting to take the general shape.
  22. swissmike
    swissmike
    I made several bucks to hammer the contour after hand bending a slight radius into the panel. Because of the stiffening effect of the bends, it is hard to get the curvature all the way to the bend, that's why I had to hammer shape it with the wooden bucks.
    Long side of the panel coming along
    Using different buck to shape lower side
    Still has a few lumps, but almost there. That's all for now...
  23. brady1929
    brady1929
  24. swissmike
    swissmike
    Second side done.
    36 ROKIT, Vhodoo and The 39 guy like this.
  25. bengeltiger
    bengeltiger
    Well done. And showing it doesn't have to require a garage filled with equipment to achieve results.
  26. Very cool keep the updates coming
  27. bigbore
    bigbore
    Very nice job! Any update?
  28. swissmike
    swissmike
  29. swissmike
    swissmike
    Testing one two...
  30. HRK-hotrods
    HRK-hotrods
    Amazing work on that floor man...
