Technical Bolt thread size
Discussion in 'The Hokey Ass Message Board' started by Tom Noller, May 18, 2016.
  1. Tom Noller
    Tom Noller
    from Iowa
    This is an odd-ball request... I've managed to lose the 4 short bolts that hold the shifter on my old BW T-5 ****** and nothing I have in my stash fits. Duh! It looks to be 5/16ths fine thread. Is there a tool that can give me the right thread size? Thanks!
  2. 57 HEAP
    57 HEAP
    Usually I just find a bolt I think will work and screw it in. If the diameter or pitch is not right, it won't go.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Not that I've ever seen. Unless you have an expensive metrology gauge set. A step thread gauge would be too hard to read in that size hole.
    If your best guess 5/16ths. Then I'd just go to the nearest hardware and buy one of every thread count per inch in the fine thread area. It may very well be metric.
  4. big duece
    big duece
    from kansas
    They are metric. Take one you your local hardware store and match it, I had to do it.
  5. get one of these from Dorman , every guy that works on cars should have the tools and ability to check for thread size
    part # 415-103
    pat59, Hnstray and Petejoe like this.
  6. prpmmp
    prpmmp
    M8x1.25x20mm
    Atwater Mike likes this.
  7. blowby
    blowby
    from Nicasio Ca
    Yep. And you'll find the old ones the moment you get back home.
  8. prpmmp
    prpmmp
    Uh!! He lost them!! He doesn't have one!!! Pete
    tfeverfred and firstinsteele like this.
  9. 57 HEAP
    57 HEAP
  10. ChucksCrib
    ChucksCrib
    from Uranus
    Yep.... Heads are 13mm if I remember correctly
  11. Atwater Mike
    Atwater Mike
    That would be proportional...However, some are available with 12mm hex heads, (more 'costly' imports came with those, usually in 'space-saving' places)
    German suppliers (VW, Porsche, BMW dealers) are BEST, when you have the choice...
  12. tb33anda3rd
    tb33anda3rd
    see if one of the other bolts off the ****** will fit, then take that to the hardware store to match up.
  13. rfraze
    rfraze
  14. volvobrynk
    volvobrynk
    from Denmark
    M8x20, we only add the pitch when it's "odd".
    Regular pitch is 1.25
    13 mm head 1/2 is 12.8 mm.
    Japanese cars are often fine aka. 1.0
    And has a 14 mm head.
    8.8 is grade 6 hardware
    10.9 is grade 8 hardware
    That hex head matte black bolts at grade 8.
    There is no lines on the head of a Metric bolt, for those who care.
    tb33anda3rd likes this.
  15. aaggie
    aaggie
    When in doubt I use a thread tap from my tap and die set to get the correct size then go to Ace Hardware and buy the bolts.
  16. Tom Noller
    Tom Noller
    from Iowa
    You guys rock! Thanks so much!
  17. blowby
    blowby
    from Nicasio Ca
    Bring back the Imperial system!
  18. brady1929
    brady1929
    Great info here, thanks.
  19. 69thumper
    69thumper
    that is correct
  20. volvobrynk
    volvobrynk
    from Denmark
    When was it ever gone?
