Hot Rods Aluminum or Copper/Brass Radiator?
Discussion in 'The Hokey Ass Message Board' started by Hnstray, May 17, 2016.
  1. Uh buy aluminum and paint it black? :rolleyes: :D :D
    Hnstray and Blues4U like this.
  2. tfeverfred
    tfeverfred
    That would be faking it. Wouldn't it? Either all in or....... what ever.
    Moriarity likes this.
  3. :D :D
  4. Blues4U
    Blues4U
    from So Cal
    What you're referring to is a chemical reaction that occurs in the coolant, that breaks down the compounds in antifreeze into acidic and corrosive compounds. This occurs in all cooling system, to all coolants, and it negatively effects all cooling systems, not just aluminum, though aluminum may be more susceptible just due to its nature as a soft metal (slightly softer than Copper, Br*** is even harder yet). Like all chemical reactions, the rate of degradation is increased due to heat. Arrenius rule says for every 10 degrees C increase in temp, the rate of reaction doubles. You want you system to reach operating temperature, but excessive temps will break the antifreeze down quicker.
    An additional issue is that some coolants use nitrite additives to combat cavitation erosion, and those nitrites can break down in use to nitrates, which can be aggressive against aluminum, so I always recommend the use of nitrite free coolants in systems with a lot of aluminum. Check the label, or google it, and read up on it. Nitrite free coolants tend to be a little more expensive, so if you're buying the cheapest **** house blend from somewhere, it's not likely to be nitrite free. They will usually advertise it on the label or on the product data sheet if you google it.
    Electrolysis has been mentioned several times, and electrolysis occurs in cooling systems when there is poor or no electrical ground for the electrical system on the engine. In that case the electricity takes the path of least resistance to ground, and without a good ground that is usually the coolant. When this happens the breakdown of the coolant occurs very rapidly and the acid level in the coolant rises and it starts to attack the metals in the cooling system. Due to the soft nature of aluminum I already mentioned, the aluminum corrodes quickly.
    There are test strips you can use to test your coolant that monitor the ph level, that can alert you to acidic conditions in the coolant.
    Hope this helps.
    Hnstray and metlmunchr like this.
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    My experience with Walker was exactly like V8 Bob's. I tried to get Walker to build me a radiator for my 27 years ago and they rudely said "No, a radiator that chopped will not cool a sbf......goodbye !" The Br***works did build me one and the motor never gets over 170 here in Florida, and they were superb to deal with. That is why I just plunked down another $1000 a few months ago to buy a new one from them. The radiator is a work of art.
    Same experience with PRC. Chris out there is a super nice guy, we exchanged emails and phone calls, and he was only too happy to build the radiator exactly how I needed it........move the neck over here, make the bottom mounting plate longer, etc, etc. He also responds right back when I call or email, and is always extremely pleasant to do business with.
    I wouldn't send Walker a dime of my money because I hate doing business with people who don't know how to treat a customer.
    Don
    Hnstray likes this.
  6. flux capacitor
    flux capacitor
    Not traditional but, a double p*** / crossflow alluminum works nicely too as it allows the fluid more time to actually stay in the radiator p***ages. My a Dad had one built for a 57 hardtop years ago to help mask the ill heating effects of a 3500 stall converter in traffic. Did the job. Flux
    Hnstray likes this.
  7. wuga
    wuga
    One of my cars is a 1962 Cutl*** with a very warm 215 aluminum V8. This car was notorious from the factory for over heating. About 12 years ago I purchased from US Rad a br***/copper triple core with the triple p*** option. I also bought their shroud with twin 11" low profile fans. At my request, they also moved the upper inlet to the opposite side. Since installing this rad, even in the hottest of weather, the car runs all day at 180 degrees. They were really easy to deal with and their pricing was on par with aluminum and way cheaper then Griffin. Also, it fit like a glove.
    Warren
    H380, Hnstray and flux capacitor like this.
  8. Gman0046
    Gman0046
    The biggest drawback on cheap Chinese aluminum radiators is the cooling tubes are epoxied rather then Tig welded. If problems occur, they are unrepairable resulting in a throw away radiator. There's a reason Chinese radiators are cheap. The worlds greatest truism is you get what you pay for.
    Gary
    Hnstray likes this.
  9. Truck64
    Truck64
    from Ioway
    Huh? Aluminium is well known to react with steel, this is why br***/copper was used to begin with.
    All sorts of problems, with dissimilar metal corrosion aka galvanic, is well evidenced in the trucking industry and everywhere else. Special coolants are recommended and the rest of it.
    Modern radiator construction techniques mean smaller radiators cool better than old school rads, but br*** has twice the cooling capacity of aluminium all things being equal. Unfortunately it's about twice the price, or more. Finally while they work well, the el-cheapo AL rads cannot ordinarily be repaired.
    Hnstray likes this.
  10. jimmy six
    jimmy six
    US Radiators made the one for my 56 Ford Victoria. I called and also research their website. 4 different grades were available in the br***/copper style. I wanted it to look original so I choose their original style tank. I added a lower auto trans cooler too. I bought their 3rd highest grade. They will make one stock looking with the hoses any where you like. These guy were great to work with and I was lucky and could drive up to get it in Vernon Ca.
    We do use an aluminum double cross in our 1/2 mile dirt car built for 600 hp and never heat up. Just looks funny with the bottom and top hose on the same side. Good luck
    Hnstray likes this.
  11. HOTRODPRIMER
    HOTRODPRIMER
    The bitterness of poor quality remains long after the sweetness of low price is forgotten. HRP
    Asphalt Angel, H380, Gman0046 and 5 others like this.
  12. Blues4U
    Blues4U
    from So Cal
    That's not correct, it's actually reversed, aluminum has about twice the heat transfer property as br***, but copper has about twice the heat transfer capacity as aluminum, and the core of br***/copper radiators is made of copper, so they will transfer heat to the atmosphere better. The advantage of br*** tanks is superior resistance to corrosion vs Aluminum, and far easier repair if/when they need it. So with the combination of the br*** tanks and copper core you get the best of both for a much better radiator.
    http://www.engineeringtoolbox.com/thermal-conductivity-d_429.html
    metlmunchr, Truck64 and Hnstray like this.
  13. Powder coated Satin Black ($40) and they look like a high dollar copper one!!
  14. UNCLECHET
    UNCLECHET
    rad.jpg Last winter I took the leaking original rad out of my 40 Ford to my go to rad guy. He said he thought he could fix it. A few days later he called and said he'd misspoken. It could be repaired but it'd be about 600 to 700 dollars. I don't have that kind of jack so I ordered a Champion aluminum rad from Bob Drake. It works great and while I guess it's not trad I like the way it looks. I really wanted to polish the upper tank on the original rad but it wasn't worth 700 bucks to me.
  15. Truck64
    Truck64
    from Ioway
    Well I should have mentioned the copper part I guess. I used br*** as shorthand. Isn't br*** mostly copper anyway, like 95%?
    Curious, that chart says Zinc is higher conductivity than Br***? I think there's a big typo in there. Br*** should have a heat conductivity rating very similar to copper. One would think. I'm prepared to be wrong, I often am.
    At any rate the old school radiators from a materials standpoint cool far better than aluminium, all things being equal, except for today the improved internal designs means modern radiators can be physically smaller.
    Copper itself is reasonably inexpensive, but for some reason anything made with it is usually off the charts expensive. Not just radiators. Buckets and kettles for example, all kinds of things. Never understood that.
  16. joe clotfelter
    joe clotfelter
    Why do you believe it cools better than copper and br*** it may look better
  17. jeffd1988
    jeffd1988
    I guess im compareing to the old original one. I notice my temp guage is down about 20 degrees.
  18. Tony
    Tony
    I use and prefer copper/br*** every time unless its physically not possible to get one.
    Single and only reason for ME..
    Road side, or on the road repairs.
    Yes, both meterials can be repaired by a quality shop, but i can and have soldered, repaired a copper/br*** rad in my truck, on the road.
    I cant tig an aluminim one on the road to get me home, and i put a lot of miles on.
    So its just my strange forward thinking i guess.
    Thats genuinly the only reason.
    Tony
  19. Hnstray
    Hnstray
    from Quincy, IL
    Thanks to everyone who has replied. It has been a great discussion and provides worthwhile things to consider. From material choice, longevity and repairability to 'best vendor'.......much appreciated.
    Ray
    jeffd1988 likes this.
  20. HOTRODPRIMER
    HOTRODPRIMER
    I believe the main reason behind the use of aluminum radiators in new cars is cost,they are cheaper and the auto manufacturers don't always think about longevity of a product so much as the price of quan***y.
    More product for the same dollars spent equals more profit.
    Example,I purchased a new Chrysler Town & Country mini van for Brenda to use for deliveries for her flower shop,the van now has just over 104 thousand miles and we have never had any major problems with it except I have has to replaced the aluminum radiator twice in the last 7 years. HRP
  21. Blues4U
    Blues4U
    from So Cal
    Another consideration is weight, with the need to meet CAFE standards the OEM's scratch for every little improvement they can get. A lb here and a lb there add up to weight savings that translates into MPG increase. AL radiators make a win/win for the OEM's, as long as the warranty coverage doesn't kill them.
    Hnstray and jeffd1988 like this.
  22. 302aod
    302aod
    from Pelham,Tn.
    I worked for dealerships ( Ford 25 Chevy 1) Any time we sent a radiator to the shop to get a leak fixed they would say it was too rotten to fix (All Aluminum)and we had to buy a new radiator. They said everytime they fixed one place it would start leaking nearby. In my experience, when they get old aluminum can't be fixed or it was their way of selling new radiators
  23. Truck64
    Truck64
    from Ioway
    What is the failure mode. Maybe the wrong coolant, or some kind of corrosion, either stray voltage, dissimilar metals or a combination?
    Everybody gets spooled up about using distilled water these days too. It won't break the bank, but. Water with no minerals is likely to draw ions into solution? I dunno. I recall the Champion rads have a warning right on the box about using distilled. Nothing about the coolant itself.
    I do know we used the Green stuff and filled with a garden hose and never had much trouble over the years. Hm.
  24. Stu D Baker
    Stu D Baker
    from Illinois
    Ray, I've got a Walker in my 37. No over heating ever. I change out to a "new" Walker about 9 years ago. Sold the "old one" (Just thought after 17 years, it would be worth the peace of mind) . Your mileage may vary.
    Hnstray likes this.
  25. seb fontana
    seb fontana
    from ct
    The above Radiator is triple p***? How as its not a crossflow...
  26. wuga
    wuga
    The original rad was a down flow with both necks on the p***enger side. The coolant entered the rad and took the easiest route to the exit which was straight down thereby really utilizing about half the cooling capacity. The only original looking rad I could find was the US Rad and with the walls they put in it, the water is forced to go past the entire face of the rad. I also had them put the upper neck to the other side. With the original rad style (actually a new replacement) even with the twin electric fans, the bulk of the water was going straight down and only half the rad was being utilized. http://www.usradiator.com/cores
    Warren
  27. Hnstray
    Hnstray
    from Quincy, IL
    ^^^^^^^^not sure that physics would support that theory. Seems to me the water pump creates a pressure differential and in effect, pressurizes the water entering the upper tank and creates a suction on the lower tank, in addition to gravity. Unless some portion of the radiator was restricted more than other parts of the core, the water would flow equally through all of the tubes.
    That is not to say multi-p*** cores are not functional........only to say single p*** should flow equally no matter which side of the tank the hose connections are located.
    Ray
  28. 2OLD2FAST
    2OLD2FAST
    from illinois
    Agreed !!
    dave
  29. Gman0046
    Gman0046
    How much quality could anyone expect to get out of a cheap Chinese aluminum radiator built by small children that sells for $100 - $150? You don't have to be a Rocket Scientist to figure that one out.
    Gary
    HOTRODPRIMER likes this.
