shoebox airbag question for the rear
Discussion in 'The Hokey Ass Message Board' started by GRSMNKYCUSTOMS, Mar 10, 2006.
  1. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    im hoping some one has a shoebox here thats bagged and the rear lays on the ground cuz this question is for you
    im running 6.40x15's and a super notch in the rear, am i going to have to cut out the tops of my rear wheel wells, if my measurements are correct it looks like it, but im hoping i dont have to.
    anyone here know for sure?
  2. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
  3. Killer
    Killer
    you'll need to cut em if it lays frame.
  4. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    and just reinforce the rear package tray and surounding areas?...did you do this to yours? and if so, what did you use to close it back up? i dont wanna just leave it, and i certainly dont wanna waste 30 man hours reshaping inner wheel wells if there is a faster option
  5. LuckyBastardMiguel
    LuckyBastardMiguel
    Your best bet is to pm Killer he has a bad*** shoebox he is doing right now and it looks like it lays frame.
  6. oldskool55
    oldskool55
    from socal
    trailer fenders
  7. Killer
    Killer
    trailer fenders and flat sheet... put some beads in it or run 16 gauge.
  8. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    yeah i know, i seen it when rocky had it. mines no slouch either, looks different now than in this pic, bare metal right now, probably will be at viva
  9. MercMan1951
    MercMan1951
    I second the trailer fenders...tough, cheap, and simple to modify:
    (scroll down)
    http://landyachts.homestead.com/mercresto5.html
  10. rat boy
    rat boy
    from Merced ca
    My buddy and I did his 49 and yes we most definately did have to cut and raise the rear wheel wells. I can't see any way around it if you want it to lay out right. Unless you want to run a 13" wheel. "Yeah, they 13's, but I keep em clean"
  11. jakdupkustoms
    jakdupkustoms
    mine lays hard. Trailer fenders and a driveline tunnel is a must
  12. Circus Bear
    Circus Bear
    Whille we're on the subject, what about 50 chevy sedan. I'm ***uming I'm in the same boat as you.
  13. Circus Bear
    Circus Bear
    no one has bagged a chevy?
  14. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    i like the trailer fender method.havnt used it yet thow .here at my shop and guys i know we've been cuttin the well wells at the base and razin them up and then fillen in the metal thats missing.its alot of work.both the chevys and the fords you gota do it to lay out.the next one we do here at the shop well try the trailer fender seems like it be faster.
  15. jakdupkustoms
    jakdupkustoms
    Have bagged 54 and 52 chevys I would imagine a 50 would be close to being the same about the only way you can get them to lay without cuttin the rear fenders out it to run a really small rear tire. I did a 50 ford and it layed without cutting but it has 165-15 on it. I think it looks kinda silly. But it works for him, so Im happy. Hes happy everybodys happy. The driveline seems to hit before the tires do a tunnel and some minor rear seat reworking should do the trick.
  16. Circus Bear
    Circus Bear
    awesome, thanks. I have to rework under the seat anyways due to s10 frame I'm runnin.
