Hot Rods My 32 roadster project
Discussion in 'The Hokey Ass Message Board' started by Hutch built, May 15, 2016.
  1. 1-SHOT
    1-SHOT
    from Denton
    Pure HOT ROD **** .3 Window Larry will love this. Frank
    3wLarry likes this.
  2. Malcolm
    Malcolm
    from Nebraska
    Wow, damn nice work and a great looking car. I'm following along.
  3. 325w
    325w
    Detail is outa this world. The left door fit is as near perfect as it could ever be. Spreader bar up front is outstanding.
  4. woodz
    woodz
    This thing is crazy awesome! Subscribed!
    Thanks for sharing.
  5. Hutch built
    Hutch built
    Here a some pictures of setting up of the rear end. While mocking up I descovered,at no fault of Shadow Rods, that the tire was not centered in the wheel well. This was do to me using different spring hangers then what Shadow Rods used for their mock up, mine were shorter. The red tape is where it needed to be and the bluetape is where it was. So I just took a saw to it and while I was at it I put "C" notches in it and reinforced the area with some square tubing.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my SPH-L720T using H.A.M.B. mobile app
    ls1yj, mgtstumpy, loudbang and 7 others like this.
  6. lothiandon1940
    lothiandon1940
    I'm just in awe!...............Beautiful!
  7. buck 32
    buck 32
    from Maryland
    Careful I think his head might be swelling. Just kidding Hutch is very talented and has a keen eye for detail.
    lothiandon1940 likes this.
  8. DeLuxe 32
    DeLuxe 32
    Glad I stumbled across this, another HAMB treat. Beautiful work !!
  9. 1-SHOT
    1-SHOT
    from Denton
    You have a good eye and are very talented. Will be following and I am sure to pick up some tricks. Thanks Frank
  10. DDDenny
    Not to take anything away from the other HAMB members' talent but I think we have a new gold standard here. And that rear frame rework is a good example.
    Many times you see people coming on here and starting a thread asking for suggestions on how to "fix" a problem instead of doing what is really required to undo a mistake, many times spending more time hashing it out over and over looking for support instead of just biting the bullet and getting it done and move on.
    @Hutch built thanks for the great close up photo coverage, your attention to detail is outstanding.
    lothiandon1940, buck 32 and The37Kid like this.
  11. HD Driver
    HD Driver
    Very nice work! This would be a strong contender for AMBR.
    lothiandon1940 and The37Kid like this.
  12. Kiwi Tinbender
    Kiwi Tinbender
    Hmmm. Hutch, I wonder if you are from Ohio? A long time ago I got in touch with Josh Shaw about a chopped A Coupe built by Hutch.....It was cool too.......Just thinking.....
    Stunning Craftsmanship. You could write your own ticket if you wanted to do this stuff for a living!
  13. Glenwoodgasser
    Glenwoodgasser
    from Arizona
    John ,it's Tom V. Buckley said you posted the build here. Great that the world can see your work. I hope you enter it in some of the big events as have been suggested here before thrashing on the streets.. It deserves to be seen ,built by a real talented craftsman in a two car garage. I am proud say that you have worked on mine. Hope you can still fit in your hat now.
  14. Hutch built
    Hutch built
    Thanks Tom! Hope you're enjoying your new digs! We'll miss you at York.
  15. bengeltiger
    bengeltiger
    Beautiful fix to the rear frame! Thanks for sharing the pics.
  16. seatex
    seatex
    Absolutely amazing work! Subscribed, welcome to the HAMB!
  17. Wow, you know how to treat metal and amazing how clean your workplace is and even better the work you do. My deepest respect
  18. Hutch built
    Hutch built
    I had my son Kyle, who is 14, help with bending,fish mouthing, and installing the roll bar tubing for the body reinforcement. Been teaching him how to weld and run the lathe too.
    ls1yj, mgtstumpy, loudbang and 8 others like this.
  19. Pewsplace
    Pewsplace
    I love it that you are teaching your son the art you have crafted.
  20. Fitnessguy
    Fitnessguy
    Very good to see your son involved! My son is 9 and shows no interest but I am hoping that will change!
  21. Hutch built
    Hutch built
    Here are some pictures of how I made cowl blister.[​IMG]
    I started with this, it's a damaged S/S ball that goes on the end of a 500 KV electric switch. I've had it in my possession for at least 15 years.[​IMG]
    I cut it into pieces and with my high dollar metal shaping tools gave it a tear drop shape.[​IMG][​IMG][​IMG][​IMG][​IMG]
    After shaping I welded the two halfs together and smoothed it up and put mounting brackets on the inside for hidden attachment points. I'll polish it later.[​IMG][​IMG][​IMG]
    ls1yj, Baron, loudbang and 7 others like this.
  22. waxhead
    waxhead
    from West Oz
  23. Awesome, it looks all so simple and easy. But if you haven't tried it yourself ...
  24. lothiandon1940
    lothiandon1940
    Spectacular! Love that you re-purposed the damaged piece.
  25. AmishMike
    AmishMike
    WOW - nice rod; thanks for all the great pictures & detail. Hope to see it in York. Question: what are/how are spark plugs fired? Can not tell what "covers", coils are at plugs.
  26. Hutch built
    Hutch built
    Standard spark plugs,wires, coil, and distributor it's just hidden behind all the stainless shielding that came on early corvettes.
    AmishMike likes this.
  27. Hutch built
    Hutch built
    Here are some pic's of the rear end mods. I made some rear frame horns that hug the body and made a curved S/S spreader bar like the one on the front. Then made some corner pieces out of exhaust tubing u bends.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    ls1yj, mgtstumpy, Baron and 12 others like this.
  28. Lots of little details make this '32 Roadster a BIG WINNER! :cool:
  29. The37Kid
    The37Kid
    Just noticed the body has a slight channel, nice rear fender well trim pieces. Bob
  30. Gotgas
    Gotgas
    from DFW USA
    Lotsa talent. Cool car, thanks for sharing.
