Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. Roothawg
    Roothawg
    Since it is a 4.00 bore, I am going to research some later model pistons to see if any have a similar compression height. With all of the SBC stuff they make these days, surely there will be a forged piston out there that will interchange.
    winduptoy likes this.
  2. MOTOV8N
    MOTOV8N
    from Manitoba
    i have not heard of that before. Interesting
  3. Dan Hay
    Dan Hay
    Now I want one! Hope that one on CL is a good core.
    MOTOV8N likes this.
  4. cad-lasalle
    cad-lasalle
    from grafton nh
    We used Chevy rings on my '60 390 with stock pistons. Been severely road tested with no problems and they cost less.
    winduptoy and rust runner like this.
  5. MOTOV8N
    MOTOV8N
    from Manitoba
    So...what was that stamped number?
  6. Roothawg
    Roothawg
    IMG_3299.JPG Dunno yet. It's unloaded, but it is a grimey pig. It has an oil filter adapter on the pass side though. Kind of a clunky looking deal.
  7. Roothawg
    Roothawg
    Looks like I scored after all.
    winduptoy and MOTOV8N like this.
  8. Dan Hay
    Dan Hay
    so it looks to be a 61? Nice.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
  10. Roothawg
    Roothawg
    Just bought a set of Studebaker rocker arms from a fellow hamber last night.
  11. Roothawg
    Roothawg
  12. Dan Hay
    Dan Hay
    It says in that link they fit 51-65 Cadillacs. They might have limited those years because of steering box configuration.
  13. Roothawg
    Roothawg
    I know. It's confusing. You would think they would list the 331 and the 365's if they are all the same.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    The 331 exhaust ports are in the same place but are tiny maybe about half the size of a 390
  15. Dan Hay
    Dan Hay
    My guess is the reason they list odd years instead of CID of the engine is because of fitment into the engine compartment. In other words, these may bolt up to a 331, but the physically won't fit in a 49-50 engine bay, but they will fit in a 51 engine bay. (That's just a guess)
    Roothawg likes this.
  16. Roothawg
    Roothawg
    Gotcha.
  17. hellerlj
    hellerlj
    from Minnesota
    Have never messed with a Caddy, but may venture that way...
    After snagging these, this thread came in mighty handy....
  18. draggin'GTO
    draggin'GTO
    Please post detailed pictures of all the components during the tear down and build, we all need to see what made these Cad engines tick.
  19. Roothawg
    Roothawg
    I plan on it. If nothing else, just for my own reference. Pics are good when memories are bad.
  20. MOTOV8N
    MOTOV8N
    from Manitoba
    ...here's a 1960 390ci in the works... ImageUploadedByH.A.M.B.1463874790.844378.jpg
    draggin49, ls1yj and Roothawg like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    Brought my outlaw clone home from Starbirds, it has a 331 too ImageUploadedByH.A.M.B.1464001665.570219.jpg ImageUploadedByH.A.M.B.1464001680.187074.jpg
  22. Roothawg
    Roothawg
  23. Speed Gems
    Speed Gems
    I just picked up the newest issue (July '16) of Hot Rod Deluxe after work and they have an article on rebuilding a 365 tripower engine****led "Finding Eldorado" on P.66 you might want too stroll on down to your favorite magazine stand and get a copy. I'm reading mine now!
  24. Roothawg
    Roothawg
    I saw that. I had printed the same article off the web the other day. At least I think it was the same article.....
    Speed Gems likes this.
  25. rust
    rust
    I just read that article, Now I know why there is a vacuum line hooked to side of the block.
  26. Roothawg
    Roothawg
    So, I am wondering who on the hamb is an expert on Caddy cams? I see Howards will do a custom grind but I don't really know what the max is before I have to go to adjustable rockers etc. I have recently bought the adjustable Studebaker rocker arms, but I am unsure if I can run those with a hyd cam or or is strictly solid?
  27. rust
    rust
    Would you need them with the hydraulics?
  28. warbird1
    warbird1
    You can run adjustable rocker arms with a hyd. cam; you just need to figure out how much to pre-load the lifters when you set it up. Just remember that it'll require custom push rods and dimpled valve covers to run them...
  29. Roothawg
    Roothawg
    That's one of my questions. At what point are the adjustable rocker arms required? Anything with more lift than stock?
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    It is my understanding that they are needed when the camshaft has a different base circle dimension, lift shouldn't really play into it
    Sharpone and winduptoy like this.
