Projects My '54 210 section and chop
Discussion in 'Traditional Customs' started by royalflushcustoms, Apr 21, 2016.
  1. royalflushcustoms
    royalflushcustoms
    Had time to set the gearstage in today. Had to trim the center section because of such a tall gear setup. I'll get a picture up later today.
  2. Hdonlybob
    Hdonlybob
    Unreal talent... love it :)
  3. royalflushcustoms
    royalflushcustoms
    Thank you.
  4. royalflushcustoms
    royalflushcustoms
    20160427_235000.jpg 20160427_234938.jpg 20160427_235020.jpg Decided to show off my third member this morning. Had to clearance for the ring gear bolts and limited slip because of the tall 3.25s I'm running. I decided on that ratio because of the short 24-25" tire I'll have to run to fit the low profile of the rear quarter.
    RockinRivi and timmy2times like this.
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
    Holy ****.....how did I miss this....a chop and section in a week! Damn....very cool...I can't wait to see the finished product....but please keep the hood closed haha
    RockinRivi and kidcampbell71 like this.
  6. royalflushcustoms
    royalflushcustoms
    Haha. Thanks. I'm going to do my best to clean the electronics off the engine.
    RockinRivi likes this.
  7. mgtstumpy
    mgtstumpy
  8. flamingokid
    flamingokid
    I hope you have a good gl*** man,that back window's gonna be a mother.Subscribed!
  9. royalflushcustoms
    royalflushcustoms
    Thank you.
  10. royalflushcustoms
    royalflushcustoms
    Hopefully it won't be too bad. It's a chopped 55 chevy truck windshield flipped around.
  11. royalflushcustoms
    royalflushcustoms
    Got the stearing knuckle remake back and it's a perfect fit. 20160505_234316.jpg
    RockinRivi and michael knight like this.
  12. royalflushcustoms
    royalflushcustoms
    Had to cut and notch my short shifter to add the new chrome shifter to it. 20160428_220520.jpg 20160429_172458.jpg
  13. 'Mo
    'Mo
    I believe Dan Landon's Chevy windshield was chopped less than the top itself, carrying the gl*** back into the roof.
    The same was true for the Matranga Merc.
    Food for thought.
  14. royalflushcustoms
    royalflushcustoms
    That's an interesting thought. The first chops I ever did I set the windshield down in the cowl.
  15. ehdave
    ehdave
    We took 2 inches out of my Chrysler WITHOUT chopping the screen, we laid it back an inch and then took an inch above the windscreen.
    koolkemp likes this.
  16. mike bowling
    mike bowling
    Unreal! One thing for sure, you're not afraid to jump in with both feet!
  17. 'Mo
    'Mo
    Spot on topic!
    How 'bout some pics, ehdave?
    Both feet? More like head first!:D
    RockinRivi and royalflushcustoms like this.
  18. royalflushcustoms
    royalflushcustoms
    Haha yea after I did one I no longer have any reservations.
  19. ehdave
    ehdave
    Its still far from finished, when we cut the section out of the roof above the windscreen we left a strip and stepped a flange for the roof skin to overlap.
    At the base of the pillar we cut a slit to allow it to lean back, surprisingly it didn't take much lean to lose an inch in height. It will probably need some work at the lower, centre section of the frame near the cowl vent to get the frame fitting the windscreen properly but I'm waiting on a new seal to work with.
  20. banditomerc
    banditomerc
    and the big question....where did you get your gl*** cut down?
  21. snopeks garage
    snopeks garage
    from macomb MI
    a saw, cut off wheel, welder, man on a mission, and a drive way, this is what its all about! beautiful vision and skills my man!!!! i LOVE IT.
    CowboyTed likes this.
  22. rytang
    rytang
    from Arizona
    Bad ***! I'm sectioning my 54 right now... Insane amount of work! Check out my post.
    RockinRivi and JGFabrication like this.
  23. JGFabrication
    JGFabrication
    So sick! That's moving right along.
    JG Design & Fab
    Ventura, CA
  24. royalflushcustoms
    royalflushcustoms
    Sorry I've been gone a while. Started working some more. Here is a few pictures of recent work. Got the motor mounts in and started working on the front suspension. IMG_20161114_220308.jpg IMG_20161024_230853.jpg
  25. royalflushcustoms
    royalflushcustoms
    Brackets for the underdash booster and clutch m/c. 20160526_212731.jpg 20160526_234800.jpg 20160526_234918.jpg 20161119_220349.jpg 20161119_220442.jpg 20161119_223248.jpg
  26. voodookustoms
    voodookustoms
  27. dirt t
    dirt t
    Keep posting.
  28. 1-SHOT
    1-SHOT
    from Denton
    Your fabrication on your work looks good. Frank
  29. royalflushcustoms
    royalflushcustoms
  30. royalflushcustoms
    royalflushcustoms
    Will try to keep up.
    lowerdtrucks likes this.
