Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Aaron D.
    Aaron D.
    That looks great Dumprat.
  2. bengeltiger
    bengeltiger
    Looks great. I'd drive it just like that with a big sh*t eating grin on my face. You do good work.
  3. Good looking truck!
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
  5. Larry Pearsall
    Larry Pearsall
    My first build was also a pickup with the same problems, Not much has changed in 46 years. New England was just as hard, as to rust.
  6. Jeff34
    Jeff34
    Truck's lookin' great, rat! Looking forward to seeing more of this "cheap ***" truck build :)
  7. FastLivin
    FastLivin
    Looking good! Love the engine choice.
  8. shadams
    shadams
    Very cool and great work! What happend with the wires you got coated?
  9. dumprat
    dumprat
    from b.c.
    I have a set of wires. But decided to run solids instead.
    Jeff34 had his coated. Mine are still in original rusty condition.
    Jeff34 and shadams like this.
  10. falcongeorge
    falcongeorge
    from BC
    Truck is coming along nicely, looking good. I ran 400 and 800 meters in high school, I was pretty fast, but that was a LOOOOONG time ago! Small world.
  11. Jeff34
    Jeff34
    [emoji106]
    Yes I did and I really like the way they look for 30 bux.
    Any more work on the truck?
  12. dumprat
    dumprat
    from b.c.
    Going to work on it this morning. Track meet in the afternoon.
  13. dumprat
    dumprat
    from b.c.
    Fiddled around with fitting the hood today. Drivers side still needs some work around the hinge and the p***engers side needs some more curve. I am only running the tops and I think I will run rods through the side hinge loops to keep it latched. image.jpeg
    Departed, ratrodrodder, brEad and 8 others like this.
  14. ss34coupe
    ss34coupe
  15. termite53
    termite53
    That's going to make a cool truck for sure. Yep family comes first. I've been trying to work on my 53 five window since 1992. Haha it's a lifetime project I guess.
    Sent from my QTAQZ3 using H.A.M.B. mobile app
  16. dumprat
    dumprat
    from b.c.
    image.jpeg Been busy with work family and getting ready for camping season. And I needed a break from sheet metal work and @Running shine posted such pretty pictures of his carbs and intake I felt bad and needed to measure up.
    ( honestly I got three parts carbs at the local swap and need to get the intake figured out so I can see if my hood will clear)
    Mmmmm sleazy carberator bits!
  17. dumprat
    dumprat
    from b.c.
    image.jpeg Bushed the throttle bores.
    tb33anda3rd and Stogy like this.
  18. dumprat
    dumprat
    from b.c.
    image.jpeg Machined the necks for standard style air cleaners, dint want the V band style.
    Tim_with_a_T and Stogy like this.
  19. dumprat
    dumprat
    from b.c.
    image.jpeg I alodine do the zinc parts and am now sitting with a beverage doing ***embly.
  20. edwardlloyd
    edwardlloyd
    from Germany
    Oh I like it. I do like 32-34 pickups. I'm just about to start my second one.
    natedeville likes this.
  21. dumprat
    dumprat
    from b.c.
    image.jpeg ****! Anybody have a carter 1bbl ball&ball 0-635 carb body they wanna part with? Threads looked ok but pulled right out when I threaded in the needle and seat.
  22. 64 DODGE 440
    64 DODGE 440
    from so cal
    Looks like time for a helicoil.
    ratrodrodder, Stogy and volvobrynk like this.
  23. dumprat
    dumprat
    from b.c.
    Hell of an idea! I think I am going to ditch the gasket in favour of an O-ring as well.
    volvobrynk likes this.
  24. Six Ball
    Six Ball
    from Nevada
    Helicoil would be my first choice but I have made long lasting and nearly invisible similar repairs with JD Weld. It can be threaded. I know, I know………...:)
  25. dumprat
    dumprat
    from b.c.
    image.jpeg image.jpeg All fixed up and ****oned up and ready to test fit to make sure I can make air cleaners that will clear the hood easily.
    Carter carbs sure are **** though! Something wrong when you need a hammer to install parts on a carb.
    brEad, tb33anda3rd, kiwijeff and 5 others like this.
  26. dumprat
    dumprat
    from b.c.
    Hmm not sure why the double pics though?
  27. Looking good Matt.
  28. Jethro
    Jethro
    Looks good Matt. It's nice to see different carbs from time to time. Are you gonna run them progressive or in sync(not the boy band)
    Tim_with_a_T likes this.
  29. jerseyboy
    jerseyboy
    Dumprat,
    What did you clean the carb bodies with? They look good.
    Runnin shine likes this.
  30. dumprat
    dumprat
    from b.c.
    Jeff. They must be run together like a two barrel. I found with my 251 flat six the end holes run lean and centers run rich with one carb.
    Jersey boy. I soaked the carbs in pine cleaner(knock off pinesol) then blasted them with recycled plastic, which works awesome! Then soaked them in alodine and water for two hours at about 1:20 water mix.
    ratrodrodder, JR West and volvobrynk like this.
