How To Post Images On A Thread
Discussion in 'Tutorials' started by Ryan, May 12, 2014.
  1. Ryan
    Ryan
    ADMINISTRATOR
    What error message?
  2. The 39 guy
    The 39 guy
    Probably the same as ******'s message. It is a simple banner that pops up for each picture . It does not explain what the problem is. I have found that if I do any lurking on the HAMB before I try to post pictures I will get this message. So I usually log out and back in again before I try to post a batch of pictures. My pictures are usually resized to 460 by whatever these days.
    Another issue that puzzles me is that sometimes I can upload a batch of pictures and other times I can only upload one at a time. Sometimes I get the error message and other times it just won't allow me to choose more than one in my file at a time. I make the multiple picture choices by either holding the shift key for batch of pictures or the control key for singles from a file.
    I use two different PC's for my posting one with windows 8 and the other has windows 10. I use Mozilla for my browser.
    Thanks for taking the time look into this. I know you are a busy man. I think I am almost as addicted as Hotrodpriemer and 3windowLarry....... I just don't post as much........
    Sam
  3. Ryan
    Ryan
    ADMINISTRATOR
  4. The 39 guy
    The 39 guy
    I did a multiple picture post last night and was able to upload a batch of pictures without any problems and went back to upload another picture a few minutes later (that seldom worked before). So I don't know exactly when you fixed it but it worked! Thanks Ryan!
  5. landseaandair
    landseaandair
    from phoenix
  6. Model A Mark
    Model A Mark
    from dallas
  7. Harold's Speed
    Harold's Speed
  8. jambottle
    jambottle
    i have been sitting here for 2 hrs and have tried to post pics always says unable to upload.i now have 3 or 4 gmail accounts,a couple of photo accounts,tried to get hamb apps,i think i always had one.i have no problem with pics on fordbarn.i am not to good on the computer.it always says there was a problem uploading file
    zombiecat likes this.
  9. The 39 guy
    The 39 guy
    I am by no means an expert on this subject but the most often when I see that issue is that the picture is to big. I would suggest trying to reducehe picture size to around 600 before you try to post it and see if that works.
  10. jambottle
    jambottle
    i tried small pics and big pics.i have no problem on fordbarn?
  11. The 39 guy
    The 39 guy
    OK , well Ryan checks this thread sometimes maybe he will chime in with some help.
  12. leadfootloon
    leadfootloon
    Test was never able to post pictures off my phone. Cross my fingers.
  13. leadfootloon
    leadfootloon
    That is so cool. I'm going to start a build thread!!
  14. landseaandair
    landseaandair
    from phoenix
  15. oneredryderone
    oneredryderone
    this dummie needs some help...............i posted a cl***ified w/ pictures...............no real probs i was unable to figger-out, came away feeling proud of my efforts. however i would like to 'edit' my pictures. when i use the 'edit'...... nuthin happens! i was expecting access to either 'image or text', but nuthin happens! yep, i unnerstand the ***le is.....how-to-post-images-on-a- thread, but..... did i miss sumpin?
    FALSE ALARM!---------------i filed the 'help' request, then re-visited the edit feature, tried the 'more options feature', finally figgered-out my prob!
    red
  16. 41sedanetteowner
    41sedanetteowner
    Someone needs to look at Lancers thread. There are ****o graphic pictures on there! Get it off this site and report him to the authorities!
    Sent from my SPH-L600 using H.A.M.B. mobile app
  17. MCI5C
    MCI5C
    from peabody ma
  18. dmac620
    dmac620
  19. garagebuiltbob
    garagebuiltbob
    from michigan
  20. garagebuiltbob
    garagebuiltbob
    from michigan
  21. gatz
    gatz
    test
    Are you for sure clicking on the UPLOAD A FILE ****on at the lower right of this posting window
    and not the other choices shown on the header above the window?
    When you click on that ****on, a window should pop up asking for what file you want.
    Then upload the pic from you computer.
  22. zombiecat
    zombiecat
    I'm having problems posting pictures also. I tried the "upload a file" ****on and also tried to insert an image from Photobucket. I have only been able to upload one picture in several dozen attempts. I've even tried using different browsers and still no success. I keep getting a message that there was a problem uploading your file. Is there a size limit on the files or something else I should know about?
  23. zombiecat
    zombiecat
    Well, it think I just figured it out. There has to be a size limit on the pictures. I tried pictures from a different batch of pictures that I had taken with a cheaper camera, that were lower resolution, and they all uploaded just fine.
    lothiandon1940 likes this.
  24. Maladjusted
    Maladjusted
    20140519_114918 (1).jpg 20140601_115908.jpg First time with the photos
  25. stanlow69
    stanlow69
    test----test failed.
  26. ClayMart
    ClayMart
    You've attempted to upload a .PDF file which isn't a valid file format to display a photo here. :oops: Try uploading the image as a .jpg file. ;)
    lothiandon1940 and stanlow69 like this.
  27. AKCJ
    AKCJ
  28. NWRustyJunk
    NWRustyJunk
    Testing.... testing.... 14344774_10207269592122054_1141729046107128236_n.jpg testing.....
