Technical Sanding flaws from new whitewalls???
Discussion in 'The Hokey Ass Message Board' started by john worden, May 31, 2016.
  1. john worden
    john worden
    from iowa
    Long story short Coker tire will accept 4 returned new Firestone 820x15 4 1/4" whitewall bias ply tires due to my displeasure at the randon rubber ***s and pits in the whitewalls. Each tire has a flaw in the exact same position showing as either a pit or ***. They say replacements will be identical.
    I can shave the ***s. Has anyone sanded flaws off whitewalls and if so please explain your process. I won't get than all but I think I can really inprove the finish. 102_2385.JPG 102_2386.JPG 102_2388.JPG
    Does anyone have a set of the Denman 5" WW available? Thanks. John
    kidcampbell71 likes this.
  2. It's part of the molding process.
    toreadorxlt and gas pumper like this.
  3. alchemy
    alchemy
    I have taken a sharp new utility knife blade and trimmed the knobs off. Looks pretty smooth on my blackwalls where I took the time.
  4. tfeverfred
    tfeverfred
    Okay. That's ********. As much as those tires cost and you have to "FIX" them? If they told you the replacements will be the same, I'd be asking for a full REFUND and going some where else.
    1927graham, funk 49, Murphy32 and 2 others like this.
  5. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    While I appreciate a tire manufacture that is still producing tires for our dinosaurs, Coker needs to do something about their quality control! Between seeing threads like this and along with me and others getting out of round tires I don't know if I could ever buy any more bias ply tires from them.
    We shouldn't have to "shave" out of round tires (in others words take material off of them that you just paid big buck$ for) just so we could keep up with traffic and not have every piece of hardware rattle loose on our rigs!
    And having to return them (after you paid to mount and balance them) is a h***le that could be avoided!
  6. olscrounger
    olscrounger
    not acceptable--send em back and get your money back--no excuse for the poor quality especially with the cost.
    pecker head likes this.
  7. wutnxt
    wutnxt
    If you don't want to send them back, try a nail clipper with a convex head. That should clean up the ***s anyway.
    scrap metal 48 likes this.
  8. I would send them back and get blackwalls . Be sure to ask first if the blackwalls have the same problem.
    Charlie Stephens
  9. Actually you don't have to fix them that is the way that they came back when Firestone made them. All new tires used to have ***s. I suppose that they could come sans ***s, but someone is going to have to cut them off and that is a lot of extra overhead for a part that is considered to be a utility part.
    You can shave the ***s with a razor blade. sometimes you get black spots where the *** used to be. That can be cured with a white crayon.
    C. John Stutzer and Hitchhiker like this.
  10. alchemy
    alchemy
    John I'll make you a deal. You true up my Firestones and I'll cut the ***s off of yours. :)
    pecker head and BigChief like this.
  11. Gman0046
    Gman0046
    I've heard so many complaints about Coker. Diamondbacks would be the way I'd go.
    Gary
  12. HOTRODPRIMER
    HOTRODPRIMER
    Gary,the problem with diamond back is they don't offer bias ply tires. HRP
    Moriarity likes this.
  13. belair
    belair
    I don't like all this talk about cutting off ***s.
  14. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    I had no such problem with my Coker branded tires. Are the Firestone tires made in original molds?
    Sent from my LG-H900 using H.A.M.B. mobile app
  15. verde742
    verde742
    Having to cut ***s make me throw up a little. :eek: Get Corky on the phone !!!!
    mad mikey likes this.
  16. I haven't tried white walls,
    but there's a few threads on buffing black sidewalls to remove the the lettering and makings. 80 grit on a DA seems to be the the way to go.
    There's also a few threads on making white walls bigger
    john worden and kidcampbell71 like this.
  17. gal6xie5
    gal6xie5
    You could wet sand with 2000 grit after you cut off the excess rubber. But you must sand in circular motions around the whole tire so that you do not get flat spots.
    Firestones are made in copies of original molds. Molds only have so long of a shelf life. I have not seen this dramatic of an excess rubber issue but then again it depends on the size as well. Remember Coker makes like a 500 to 1000 tire run at one time, which is why they are advising that the new set will look the same.
    In all honesty, the originals were worse off looking then this.
  18. tfeverfred
    tfeverfred
    Oooooooook.... Cross members.o_O
  19. tfeverfred
    tfeverfred
    It's not so much the ***s, it's also the dimples. That's acceptable? The ***s on a regular radial wear off in time. Those are nubs that would take a whole day or two, to remove. So, that's okay too. I just don't get it, I guess.
    PunkAssGearhead88 likes this.
  20. Nope those dies are worn out or at least need a good tool and die man to m***age them. I imagine that the tires are functional enough to use but they will never win any beauty contests.
  21. hotroddon
    hotroddon
    There you go - Those Firestone's are as "Traditional" as it gets!
    BigChief likes this.
  22. Yea but our traditional is more refined this is a new millennium. :rolleyes:
    bengeltiger likes this.
  23. Yep, they will look like **** when the car is parked.
    I bet you can not see them from the drivers seat and nobody will be able to see them at 10 Mph of faster.
    Can you tell where I'm going with this ?
  24. john worden
    john worden
    from iowa
    I counted 60 + - highs that I can trim off each tire and 20 + - lows that I may sand.
    I'll use a skiving tool for t******* and that should help the appearance quite a bit.
    I won't settle for anything less than the widest white bias ply available even if it means extra effort.
    It's just that my work is expected to be perfect and It's fair to expect the same of others. Spending so much money for flawed goods is disappointing and maddening.
    Jeff, I appreciate the offer but I'd better do this job.
  25. Jess H
    Jess H
    Hey guys I want to clear up some confusion on what you are seeing on this Firestone tire. As others have mentioned, it is part of the tire building process and while it may appear to some as a flaw or blemish, it is not. As the tire heats up in the mold the rubber must have somewhere to expand, the molds has vent relief holes drilled in them. The vent relief holes is where the rubber flows out and you get ***s on the tire. Since the Firestone tires have lettering in the whitewall, we cannot buff the whitewall completely smooth. As far I know, this is how they appeared originally. If you think it doesn’t look good and would rather have a completely smooth whitewall, check out our BFG Silvertown tires. They do not have lettering in the whitewall so we are able to buff out all the mold ***s, leaving a clean, smooth whitewall.
    As always we stand behind our product 100%, so if you aren’t satisfied with it let me know.
    We appreciate all you and your business.
    Jess Hoodenpyle
    VP Sales and Customer Service
    Coker Tire
    1-800-251-6336
    www.Cokertire.com
    leadfootloon, lbcd, belair and 3 others like this.
  26. typo41
    typo41
    I am with you,,,,
    I am more concerned about going down the road instead of how they look parked at a car show next to the lawn chairs,,,,,,,
    bondolero likes this.
  27. Hitchhiker
    Hitchhiker
    What you don't understand is shaving a bias ply tire to round is and was a common practice when these were new and radial tires had not been invented yet. Mounting a set of old technology and expecting the as good a results as what is on your 2008 honda civic is setting yourself up for disappointment.
    Sent from my SM-G900T using H.A.M.B. mobile app
    56longroof, kidcampbell71 and 117harv like this.
  28. K13
    K13
    Yup I don't get the I insist on the look of a tire from 1950 but I'm angry when I actually get a tire that looks or performs like it would have in 1950.o_O
  29. john worden
    john worden
    from iowa
    I appreciate the response Jess. I attached more photos. The flaws appear to be too random and numerous to all be vents. 60 (sixty) specks, ***s, pits etc. each tire. Why are the black back sides flaw and nearly vent free? What exactly besides the raised letters prevent the side walls from being buffed to a higher standard? Is it buffer operator error or is the buffer too ***bersome to individually buff the flaws away? Do you buff with an abrasive or a liquid of some sort? Magnified photos on the Coker web site of these tires show a blemish free ww. I understand evenly spaced ***s for venting but this example seems flawed. I will most likely detail these tire to my satisfaction . 102_2392.JPG 102_2393.JPG 102_2394.JPG 102_2395.JPG 102_2396.JPG See my next post. Thanks. John
  30. john worden
    john worden
    from iowa
    The attached photos are of a tire that came in with a vehicle. I am in no way claiming that they are from Coker.
    Raised letters in whitewalls with evenly spaced and identical vent hole remnants I guess. This is acceptable in my mind. Just an example. John 102_2389.JPG 102_2390.JPG 102_2391.JPG
