Technical Shoebox bumpers fit all years ?
Discussion in 'Traditional Customs' started by '49 Ford Coupe, Jun 1, 2016.
  1. '49 Ford Coupe
    '49 Ford Coupe
    It's about time to get some bumpers for "The Judge" ('49 Coupe) and I'm just wanting to confirm that a '51 bumper will fit a '49. Seems as if the curvature should be the same, but thought I'd ask before I spend more money...ahahha....Going to have to make the brackets anyway, so bolt locations don't matter (refabbed rear frame and S-10 front frame). Dennis Carpenter is having a sale. Soooooo....Thanks in advance.
  2. Buddy Palumbo
    Buddy Palumbo
    Yes, the bumpers will "fit" all years. They need the irons for the specific year to bolt on to the car , but if you need to make brackets anyways, go for it.
  3. '49 Ford Coupe
    '49 Ford Coupe
    Thanks again, Buddy, for your knowledge
  4. Kiwi 4d
    Kiwi 4d
    We fitted a 50 rear bumper to our 49 , pulled it in 1" 1/2. Also as an aside fitted a full 53 kaiser. Rear bumper bar and bullets.
  5. '49 Ford Coupe
    '49 Ford Coupe
    Thanks, Kiwi... I checked out your "media" and "albums" but didn't see any pics of your rear bumper treatment. For a little while, I considered doing what a guy from Beaumont did, and that was to roll the rear pan and use a set of '58 Pontiac split front bumpers turned upside down with plate in the center. Looked great but after a couple of day's search to find those bumpers, all I came up with were either all beat up or Arizona guys saying they would only sell a complete bumper ***embly....so I'm kind of off of that idea...Do you have a picture of your Henry J. rear bumper?
  6. '49 Ford Coupe
    '49 Ford Coupe
    Well, now I'm in a quandary... I like the looks of the '51 bumpers, and I "think" that's what's on the original '49 that's my avatar, but it seems that the '51 bumpers both have dimples and holes to mount bumper guards, but I'd rather not have bumper guards. Anybody have any ideas?
  7. dtmerc50
    dtmerc50
  8. '49 Ford Coupe
    '49 Ford Coupe
    Thanks, dtmerc50, but 220 bucks for eight bent pieces of steel strap is a bit steep for my budget, plus I will have to modify anyway, since both ends of my frame are not "Ford stock".... I have a torch and a drill..... ahahaha
  9. 50Fraud
    50Fraud
    I think this is accurate: The '49 bumpers are the simplest, and have no stiffening rib on either bumper. The '50 rear has a rib between the bumper guards, but not around the corners; the '51s have a raised rib almost from end to end. As you noted, the ribs on the '51s are interrupted where the bumper guards mount.
    I used '50s on both ends of my Victoria, because I was going for a '50 phantom, and I used the bumper guards because I like them. I have run it without guards on occasion, and it looks nice that way too. I guess if you're committed to running '51 bumpers without guards, and the recesses are unsightly to you, about your only option would be to fill in the gaps with half-round rod to keep the ribs uninterrupted. You'd have to metal finish the welded areas, and replate the bumpers. Sounds like a lot of work, and expensive, to me.
  10. '49 Ford Coupe
    '49 Ford Coupe
    Thanks, 50Fraud.................yes, ideally, and if I were rollin' in cash, I wouldn't hesitate to get them, weld them up, and have them replated...........but............
  11. 'Mo
    'Mo
    How about '53 Merc bumper guards, on your '51 bumper?
  12. '49 Ford Coupe
    '49 Ford Coupe
    I think I could like that
  13. Buddy Palumbo
    Buddy Palumbo
    Personally, I like the super-simple and smooth look of the 49 bumpers . Even if my car was a 50-51 , I would be running those bumpers . It's all personal taste with stuff like that , of course .
  14. tedley
    tedley
    from canada
    Yup i dig the 49 bumpers to
  15. Rathbone
    Rathbone
    The '49 doesn't have brackets (or bolt holes) in the far ends, so they tend not to be straight. You can lean on them wrong and they'll no longer be parallel to the ground.
  16. Well it's been 12 years since I built my Vicky. I'm running 49 Bumpers on it. As I remember the 49 and 51 bumpers also had a different arc and I had to do a lot of work to the 51 splash pan front and rear to match the 49 bumpers. Some of what I did was by choice to get the Fit I liked. I have a Nova graph so I had to build the mounts also. I kind of don't think the 51 are a direct fit even on a stock frame.
    I still have a nice 51 Front around here some where. What does D.C. get for his re pop's?
    The Wizzard
  17. Finnrodder
    Finnrodder
    from Finland
    I am not sure about the Dennis Carpenter's bumpers.I've seen those repop 51 bumpers,they were cheap=smells like china **** to me.I dont personally care much about the '51 bumpers,so i bought a pair of OEM '49 bumpers straight from the chromeplater.
  18. ahshoe
    ahshoe
    I mixed it up a bit and have a 50 on the rear with a 49 Chev license plate guard and I have a 49 smoothie on the front
  19. Most of us with '51s swap for '49-'50 bumpers, '51s aren't really the prettiest. Took me a long time to find some that were in good shape and affordable. If you have cores shoebox-central has pretty decent prices IMO (I don't say that about everything Chris sells). I looked into getting some replated locally and was quoted $1500 each... ouch.
  20. '49 Ford Coupe
    '49 Ford Coupe
    Thanks, Big A.... hell I don't know what I'll end up with..... what does IMO mean ? And I have no cores.. soooo...
  21. critchdizzle
    critchdizzle
    from Owasso, OK
    IMO = in my opinion. I need to get mine taken care of as well, I'm not 100% on whether I want to use the overriders.
  22. '49 Ford Coupe
    '49 Ford Coupe
    Would anybody know if a 55 Plymouth front bumper would fit/work ?? they don't have bumper guards and look like they may fit, sorta.....
    I'm starting to feel a bit dumb but what the heck is overriders?
  23. '49 Ford Coupe
    '49 Ford Coupe
    I like that a lot. ..
  24. 50Fraud
    50Fraud
    I think overriders = bumper guards.
  25. Quote; Would anybody know if a 55 Plymouth front bumper would fit/work ?? they don't have bumper guards and look like they may fit, sorta.....end of Quote.
    You bet they will fit. Just like any other cross breed part. All you have to have is the talent and time to make them fit.
    Will it bolt right on? I seriously doubt it.
    The Wizzard
  26. Kiwi 4d
    Kiwi 4d
    1464990266012-1080525984.jpg 14649903872581052734819.jpg The 50 bumper with 53 kaiser bumper bar we fitted to our 49.we also pulled the bumper in approx 1 1/2". Yep we probably need the splash pan fitted , well something anyway as a stock one won't fit, just to stop stones hooking on the bumper and coming up on the upper body.
  27. Finnrodder
    Finnrodder
    from Finland
    Never thought of that the splash panels are different on '49's.So,the easiest way is to get '49 splash panel?
  28. 50Fraud
    50Fraud
    Front splash pans are different from 49 to 50 to 51, and 6s are different from V8s. There are six different splash pans in all.
  29. Finnrodder
    Finnrodder
    from Finland
    I didnt think that either that the V8 models had different splash panels.Thats really good info,thanks!
  30. Buddy Palumbo
    Buddy Palumbo
    The v8 vs. i6 splash panels are different due to the different locations of the radiators .
    This is the first time I'm hearing of different valance/filler panels for 49-50-51 (other than the v8/i6) . I can only really say that the valance on Craig's '50 worked out good with his '51 bumpers ... I don't know what year the valance is from on my '49 , but it fits good around my '49 bumpers .
