Projects My dad's '35 Pickup will be my son's first car
Discussion in 'Traditional Hot Rods' started by Flat Ernie, May 17, 2016.
  1. Flat Ernie
    Flat Ernie
    Tech Editor
    My 14yr old son just started asking about cars late last summer. He mentioned maybe fixing up one of my old trucks. Well, I don't have any other than my daily driver '54 F100, but told him we'd find him a good project. My dad went and looked at a Willys pickup that was too rusty and also sold by the time he got there. But my dad mentioned that his '35 Pickup was pretty far down his list of projects and he wasn't sure when he'd ever get to it and if my son wanted that, he could have it.
    When I told my son about it, he wanted to look at it. So, we went to my dad's (about 3hrs away) and checked it out. The carb base plate was frozen solid from sitting, so I had my son remove it and we went through it with parts from my stash. He did all the work and put it all back together, we bolted it on, and filled the bowl with gas and after filing the points, it fired right up! This really lit the excitement for my son! [​IMG]
    My dad bought his pickup about 15 years ago. It had an early SBC adapted to the original 3-spd and hydraulic brakes, but otherwise, pretty original. About 10 years ago, we swapped in an 8BA and a '39 box, worked on the juice brakes that were previously converted with a '39 pedal & backing plates, and had it driveable. My dad started really working on the truck - dis***embling it, making small repairs, and removing everything to get the interior pretty nice, but the exterior was always going to be as-is. It's a solid truck, but not without some minor rust here and there. Then my dad's life got a little busy, he was selling his business, house, retiring, and moving. Other projects got pushed ahead, and the truck just sat. But my dad had collected virtually everything my son would need to re***emble the truck into a nice driver. It was almost a kit.
    Back when I was helping with the engine & brakes all those years ago, I noticed some rust undernearth the right rear frame rail at the kickup - a common rust area on these years. I welded in some strap as a temporary reinforcement, but told my dad he needed to replace that section. One of the things he bought was replacement frame sections for the area, along with replacement pieces for the crossmembers (which weren't bad).
    Fast forward to a couple of months ago, and for spring break, I helped my son dis***emble the bed, rear fenders, and running boards so we could get to those frame sections first. The kickup was worse than I knew, but what was even worse, was the entire right frame rail, which we couldn't see with the running boards on, was almost completely eaten away. This wasn't noticeable from the inside because someone had welded in some C-channel on both sides at some point in the distant past. The C-channel was keeping this frame together...at least on the right side [​IMG]
    So now we're on the hunt for a decent frame. I've found a couple good ones, but they're way out west and it's simply not feasible to get them back to FL. I've posted a wanted ad here on the board:
    http://www.jalopyjournal.com/forum/threads/1935-40-ford-frame.1016194/
    But equally just wanted to share the excitement of another generation getting involved. I just hope we can find a frame soon - the few I've looked at locally are either butchered or as rusty as mine. I don't remind replacing crossmembers, and could easily make it work with just the frame rail itself, but a full frame would get us rolling quickly. I was hoping for few setbacks to keep my son's motivation up. I have to head out of state for a few months for work in July and really wanted to get him going before I left...
    Ron Funkhouser and kidcampbell71 like this.
  2. Chris
    Chris
    That is so cool. Frames are not too hard to find around here...but we are 3,000 miles away
  3. Schwanke Engines
    Schwanke Engines
    Looks like a nice solid start, there are a few frames around MN here that are decent. I had my 2 and 4 year old helping me this weekend wash up a 50 chevy 4 door we picked up. they love old junk.
  4. glrbird
    glrbird
    That's one hell of a grand pa!
  5. treb11
    treb11
  6. oldsjoe
    oldsjoe
    One lucky Son / Grandson looks to be on the path of one cool truck! Joe
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    I don't think they're in business anymore...and I've already got the repair sections....unfortunately, the entire right rail is rusted through on the side under the running board, well beyond the reach of the repair sections
  8. Flat Ernie
    Flat Ernie
    Tech Editor
    Hopefully, we can find a frame and keep him motivated!
  9. oldsjoe
    oldsjoe
    Get him in on the search if he isn't already, sometimes digging around for the parts is just as exciting as turning the wrenches! Joe
  10. mutant55
    mutant55
    I agree, the hunt is a great part of building cars, especially with what we are all doing here! Not to mention the knowledge he will gain with the experience! Just my 2 cents.
