Hot Rods A little work on a 33 plymouth-----!!! now with paint!!!
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jul 13, 2014.
  1. been doing a little sheet metal work on a friends 33 Plymouth. thought I would share. photo (11).JPG photo (8).JPG photo (10).JPG photo (15).JPG photo (15).JPG photo (14).JPG
    Tim, Barn Hunter, hfh and 10 others like this.
  2. brady1929
    brady1929
  3. Texas Webb
    Texas Webb
    Nice coupe.Need more pics.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Having helped a friend build a '34 Plymouth I really like these cars,,the metal work looks great! HRP
  5. mcmopar
    mcmopar
    from Strum, wi
    I would like to see more pics of this one. Will it have a rumble seat?
  6. im going to try to post more pics soon. I have a bunch on fabing the wheel wells, lower qtrs. and cowl and rear qtr extensions. It still has a bunch of metal finishing to go. It will have a rumble seat and bumpers but we need a front one. The motor is a 354 with a 904 trans. The original seat and column are being used as well. Hopefully the floor will be completed this week. The rear spare tire holes and side mount spare fender recess are next to be filled. I refuse to fill the roof insert! It will use the hood top only for now but I have some ideas on shaping the louvers on the side panels into a "bubble" to clear the valve covers.
  7. Von MoPar
    Von MoPar
    from Australia
    Nice Coupe...keep the picks coming.
    Desmodromic likes this.
  8. hope these pics come thru, still learning how to do this. any way here are some before and a little fab pics. My favorite is the dumpster floor material.
    Photo238_zpsf8621c39[1].jpg 101_3881_zpsefeaa34d[1].jpg 101_3882_zpse90c7c7c[1].jpg 101_3884_zps81247733[1].jpg 101_3887_zpsd0636151[1].jpg 101_3901_zps5dee15a9[1].jpg Photo232_zps3431abc3[1].jpg Photo235_zpsdec0af6d[1].jpg Photo240_zps7514d663[1].jpg Photo324_zps7084e439[1].jpg 101_4577_zps655f09be[1].jpg
  9. fordv8
    fordv8
    Wow, great work! What type of front and rear suspension are you going to run?
    CR
  10. the owner has done all the ch***is work. It has a fatman m2 and ford rear. He almost used the stock axle but talked himself out of it. don't worry that wavy tube axle has found a good home, mine
  11. raymay
    raymay
  12. cool build. we have been looking for a better left front fender, no luck so far. Seems like these cars have hard to find parts unlike fords of the same era.
  13. got some floor work done, just have to fit the brake pedal and finish welding
    dwollam, OahuEli, Stogy and 1 other person like this.
  14. got some paint on today, sorry for the ****y phone pics
    Tim, dwollam, alanp561 and 3 others like this.
  15. some prime time pics
  16. some bed liner under coat
    Tim, dwollam, Stogy and 2 others like this.
  17. in the booth
    dwollam and Stogy like this.
  18. found some lost build pictures cleaning out the phone
    here is one of the new wider wheel houses
    alanp561, Stogy, dwollam and 2 others like this.
  19. some lower QTR love
    Tim, oliver westlund, hfh and 5 others like this.
  20. a little better floor pic
  21. it was originally supposed to flat black
    owner changed his mind after he didn't like it
    he decided to go with this Fiat 500 grayish green
  22. PoRodder
    PoRodder
    from St. Louis
    Ugh. I remember all that rust in all the same places. Mine still has some of that rust. Beautiful work on this one though! I like the floor and wheel well work. I'm inspired. I don't know how these cars got so p***ed over by the aftermarket. Rust repair is a challenge as so few parts are available. Show more!
    oliver westlund likes this.
  23. thanks, there are rear bodys and most of the lower patch panels available, but I like making my own
    they are not very hard to make
    the wheelhouses were made the old school way, tuck shrinking and a hammer and acetylene bottle cap that is welded to my bench. they are 1 3/4 inches wider than stock and have the same shape and contours of the originals
    the lower qtr piece was hammer and dolly only with a little shrinking
    the floor was the simplest, just some good patterns and my modified harbor freight bead roller
    the time consuming part was fitting them together, all the exterior sheet metal is file fit and but welded
  24. PoRodder
    PoRodder
    from St. Louis
    I'm aware of the patch panels available as I have purchased some of them. But I would like to make my own quarter pieces. Hard to beat that bead roller for the price, isn't it?
    Maybe you could do the hood sides like this one instead of hood blisters (courtesy Henry Ford Museum): henry ford roadster.jpg
  25. the current plan is for hood tops only
    I am trying to talk the owner in to letting me reshape the louvers into "blisters" to clear the valve covers
    and the HF beadroller works good when you build a stiffer frame for it
    dwollam and Atwater Mike like this.
  26. exterminator
    exterminator
  27. found a couple of more pictures
    here is the wheel house tig welded to the qtr in the center of the bead
    Tim, dwollam, alanp561 and 4 others like this.
  28. here is the lower QTR welded just before metal finishing
    Tim, alanp561, OahuEli and 4 others like this.
  29. PoRodder
    PoRodder
    from St. Louis
    That's some beautiful work on that rear quarter. Looks factory.
