Smooth casting marks on engine blocks
Discussion in 'The Hokey Ass Message Board' started by charlesincharge09, Aug 26, 2013.
  1. charlesincharge09
    charlesincharge09
    from Wisconsin
    So i tried a google search and a search on here and didnt find much.
    Anyways i started smoothing all the casting marks on my sbc and wanted to see how others have turned out. I figure i will have a lot of time into it, but it will look *****in when its done. I have found that a flapper disc works great for it for larger areas. Hope to see some pictures shared!
  2. chopolds
    chopolds
    from howell, nj
  3. Larry T
    Larry T
    No casting flash here, inside or out. I didn't smooth the whole block though.
    kidcampbell71 likes this.
  4. charlesincharge09
    charlesincharge09
    from Wisconsin
  5. 63dan63
    63dan63
    It is addictive and hard to stop. I found this 1970 Ram Air III motor in a '62 Dodge pickup. 1794542_792151264210867_1914246291559465452_n.jpg 1794542_792151264210867_1914246291559465452_n.jpg DSC01327a.JPG DSC01330.JPG
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Damn, that is pretty !
    Don
    Hnstray and Jet96 like this.
  7. J. A. Miller
    J. A. Miller
    from Central NY
    I had to read that 3 times - a Pontiac engine in a Dodge pickup - that's something you don't see every day!
    I have to agree with Don. ^^^ What's it going in?
    blackandgold likes this.
  8. mgtstumpy
    mgtstumpy
  9. mgtstumpy
    mgtstumpy
    What the heck, might as well do the transmission as well. Had to swap the Corvette output shaft and extension housing over when it was rebuilt. Not that you see this anyway. Trans-1.jpg T700-1.jpg
    saltflats and kidcampbell71 like this.
  10. Atwater Mike
    Atwater Mike
    Watch that stuff slip out from your grasp when you don the white cotton gloves...
    "Whooops!" (CRASH!)
    Stuff's so pretty it makes me noivous!
    J. A. Miller likes this.
  11. tfeverfred
    tfeverfred
    If I had that much spare time, I'd kill myself. Or, smooth down an engine block.:D Great work, guys!
  12. slack
    slack
    I saw a V8 at the World of Wheels (many moons ago) that was so slick it looked like an Almond Joy.:confused:
  13. thefalconer
    thefalconer
    I never smoothed mine out completely, just took off the sharp edges and made sure paint would stick... I think it turned out well for how co**** it was...[​IMG][​IMG]
    Sent from my SM-G900R4 using H.A.M.B. mobile app
    slack and indyjps like this.
  14. BamaMav
    BamaMav
    from Berry, AL
    Are y'all using high temp engine paint or regular enamel? It looks almost like it was poured on thick and smooth, like dipping something in chocolate. Lots of work, but sure looks great!
  15. lippy
    lippy
    from Ks
    OMG That is Wonderful!!! I have never seen anything so smooth!
  16. Don's Hot Rods
    Don's Hot Rods
    from florida
    I did spend a little time on the engine and transmission in my 23. Used Roloc discs, primed with epoxy primer and topcoated with Imron. Never saw one inch of the transmission once the body was on, but I knew it was there. :)
    Don
  17. thefalconer
    thefalconer
  18. indyjps
    indyjps
    4 inch grinder, then a die grinder. I knock down all the casting flash and sharp edges on whatever I build, don't like getting cut.
    I did a sbc valley all the way smooth for oil drain back, never again, I'll never grind all the casting flash off the outside.
    Well, if I ever have a fender less hot rod, maybe.
    Larry T likes this.
  19. seb fontana
    seb fontana
    from ct
    19 posts and nobody warned about over heating!
  20. Larry T
    Larry T
    What's going to overheat?
  21. Don's Hot Rods
    Don's Hot Rods
    from florida
    I guess he is referring to the feeling that some have that the rough surface of the block helps get rid of heat, whereas a smooth surface will not. I live in Florida and have never seen any difference between the two, so who knows if that holds any water. I can't imagine those little bumps really contribute much to cooling.
    If your car overheats from something as simple as smoothing the block, you have bigger issues than that.
    Don
  22. Larry T
    Larry T
    Yea, especially on a water cooled engine.
  23. mgtstumpy
    mgtstumpy
    I can't image that the surface would be diminished that much by smoothing that what's left can't dissipate sufficient heat to cool, plus the transmission and engine are cooled externally as well. Likewise, do alloy or chromed pans trap radiant heat? I've not seen or read anything to the contrary in all my years to support or refute those ***ertions that heat is trapped to such an extent that smoothing is detrimental and affecting cooling. Even so, it might be minuscule. Anyway I had nothing to do for a few hours. Most likely those that do it, appreciate how much work goes into the aesthetics for something that everyone may never really see. :D
