Projects The bucket of ugly! A de-uglifying thread...
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 14, 2013.
  1. tfeverfred
    tfeverfred
    Hmm....... no explanation for that. They show up fine for me and I posted them from my album...........oh shit. Hold on.
  2. tfeverfred
    tfeverfred
  3. jalopy45
    jalopy45
    That works, thanx, I like that... :)
  4. 37hotrod
    37hotrod
    I think I started something here.....
    kiwijeff and AndersF like this.
  5. 37hotrod
    37hotrod
    Gonna look like this someday....
  6. tfeverfred
    tfeverfred
  7. steel rebel
    steel rebel
    My roadster has seen many changes. These didn't last too long. Like around the block once. They just bounced.
    Gary
    AndersF likes this.
  8. tfeverfred
    tfeverfred
    Gary, WTH were you thinking?
  9. jalopy45
    jalopy45
    You saw the "T" body in Portland Gary now this is the body that is going to replace it (17 Dodge) ,[​IMG]
    kiwijeff, AndersF and 37hotrod like this.
  10. steel rebel
    steel rebel
    Fred, who knows what I was thinking. Pretty early in the finished build (early '90s). Look how dark my hair was. "growing pains"
    Gary, good choice I like those bodies and none of us have the slim trim bodies we used to. "No offense". Their was a flathead powered yellow Dodge bucket running around the Bay Area rod shows in the mid '60s. Three of us piled in it for a food run from setup at a Richmond show then. But then all three of us probably didn't add up to much over 300 lbs. then.
  11. Those extra few inches would be very welcome inside my T. :D
  12. nobux
    nobux
    Well, I mounted up my new rear tires yesterday. They replaced the Hurst cheater slicks that I couldn't get balanced. I'll take it for a highway drive later today to make sure that all is well.
  13. Hackerbilt
    Hackerbilt
    Wow...thats nice. Really like the body color and the painted wheels.
  14. verde742
    verde742
    LOOK UP; The Lively Set , Its a movie with a Dodge.
  15. t-rod
    t-rod
    What size did you go with?
  16. nobux
    nobux
    They are Mastercraft 265/75R15s. With 20lbs of air, they measure 29.5" tall. It was hard finding tires in that size without big side lugs.
    I just took the daughter for a ride. It rides a lot better. I'll hit the highway on the way to work tomorrow and see how it does.
    kiwijeff, Phillips, AndersF and 4 others like this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    nobux , I really like the way your car is turning out , NICE !!
    dave
  18. tfeverfred
    tfeverfred
    Perfect.
    26 T Ford RPU likes this.
  19. jalopy45
    jalopy45
    This is collection of pictures of that Dodge, great little car.,
    AndersF and 26 T Ford RPU like this.
  20. 26 T Ford RPU
    26 T Ford RPU
    Great roadster but the Ackerman is all up the shit, you can actually see the outside tire toeing in on the curves. JW
  21. verde742
    verde742
    Ackerman is always messed up when tie rod is IN FRONT of kingpins...with a straight axle.
    Most won't ac-know-ledge it.
  22. 26 T Ford RPU
    26 T Ford RPU
    That is incorrect, the arms need to be moved out toward the backing plates, same principle with the line from the rear axle centre, through the king pin and the through the tie rod end centre. JW
    need louvers ? likes this.
  23. deucemac
    deucemac
    The car is an old Prowlers car and is currently on display at Bill Smith's museum in Lincoln Neb. At least it was last Tuesday
    when I was there.
  24. Blue One
    Blue One
    from Alberta
    It might be incorrect but doing what you said isn't easy to get done properly and even then I have always disliked how it looks.
  25. 26 T Ford RPU
    26 T Ford RPU
    How can you ruin the looks by bending them out to where they SHOULD be.
    When that setup turn a tight corner one tire WILL break traction, but hey it looks good, not to me. JW
  26. Blue One
    Blue One
    from Alberta
    I simply mean that having the tie rod out in front of the axle just looks wrong to me regardless.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Bad ackerman shows you couldn't be bothered/didn't know to design your frt. suspension properly...
    dave
    26 T Ford RPU and jalopy45 like this.
  28. RICH B
    RICH B
    Reminds me of a problem my friend had with his T. Mid '70s he bought a shortened T touring, nailhead, '39 trans, banjo rear; "updated" to the latest style with psychedelic paint and "indy" tires (remember them?). Drove it home and found out the back wheels wouldn't fit thru the garage door. We just about died laughing; wish we would have had cell phone cameras back then.
  29. verde742
    verde742
    How long do the have ta be on a 100 inch wheelbase car? A foot long?
    Show me.
    I understand ackerman. When I was young: we called it a suicide front end, 1. Because the first thing damaged was the tie rod.
    2. Because of the ill-handling mess it created.
    Its still done, alot, just Not in my shop.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    A "suicide" frt. end refers to the axle being moved out from under the spring / frame, thus , if something in the suspension breaks the frame will drop to the ground. AFAIK , it doesn't directly refer to the tie-rod....
    dave
    verde742 likes this.
