Technical *** June 2016 Banger Meet - Time for Crickets and June bugs***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 31, 2016.
  1. No worries, we may not be racing for a while.
    Sorry to hear that you are going through that, been there, done that.
    When you do finally make it, look us up, we will have more adult beverages than tools in our pit.
    J
  2. youngrodder1929
    youngrodder1929
    Got the car back togther switched the cast iron malory out for a advancing unit got the spark plug issue sorted hopefully and a new head gasket almost ready for the dirt drags !
    Sent from my SGH-I317M using H.A.M.B. mobile app
    Bigcheese327, 29bowtie, Tiny and 4 others like this.
  3. 97
    97
    Interested to hear how you resolved the spark plug issue...
  4. youngrodder1929
    youngrodder1929
    Going to use an exstended tip 3/4" reach (1" -14mm doesn't isn't made) Still is ample piston clearance but will get the spark out of the hole
  5. Bluto
    Bluto
    OK I'm back in towno_O
  6. V4F
    V4F
    from middle ca.
    well I'm glad . it was a job to keep the news papers from piling up at the front door . hope all is ok ..
  7. Bluto
    Bluto
    Were the papers in Polish? If not your watching the wrong house on Goggle Earth
  8. noboD
    noboD
    Are you working in the shop, Bluto?
  9. V4F
    V4F
    from middle ca.
    ooopppsss no they were not . disregard
  10. Bluto
    Bluto
    Not much Doug. Hand tremors still....
  11. The37Kid
    The37Kid
    ^^^^^^^^^^^^^ Hope you can open the package I'm mailing tomorrow. Bob
  12. Window Licker
    Window Licker
    first time she stranded me so far
  13. blgitn
    blgitn
    Nice car,.. except for the flatuency of the perimeter!
  14. orangeamcs
    orangeamcs
    Where can I find actual winfield cam specs. I recently aquired a winfield ca. Just trying to figure out what it is
  15. search up Brierley cams, Jim has the masters and all the specs.
    John
  16. junk yard kid
    junk yard kid
    Gotta watch out for those French tires! They'll go down on ya....
  17. colinsmithson
    colinsmithson
    It is only flat on the bottom if you turn it around a little it will be fine
    that is how mine takes a break
  18. V4F
    V4F
    from middle ca.
    can you be more specific as one link had a virus ............ steve
  19. orangeamcs
    orangeamcs
    from my preliminary measurements the Winfield cam has .340 lift or just under that maybe .334. I cant read the markings on the one end of it and the other is stamped Winfield clearly. It came with a engine I bought in pieces with a iron miller cragar ohv and a wico mag.
  20. V4F
    V4F
    from middle ca.
    so are you saying you have an extra cragar ?
  21. orangeamcs
    orangeamcs
    I only have one and if I had a dozen would any of them really be "extra" lol
    On another note I'm trying to finish the exhaust on my car out the back. I started w 2.25 off the cast iron header. I'm thinking I should go to 2" and s**** the 2.25 or maybe just neck the tailpipe down to 2" everything I have read says 2" single will support around 150hp easily. I'm not making 150 or close ro it but hoping w the ohv I'll be closer to that than I am now. Anyone have any thoughts. The 2.25 that goes about 2.5 feet off the cast iron header us way to loud and annoying. It doesn't have any tone. It was temporary anyhow and now it's time to do it right.
    youngrodder1929 likes this.
  22. V4F
    V4F
    from middle ca.
    LOL good luck
  23. 62pan
    62pan
    In the list I have of Brierley cams he has one listed as 280V, duration is 280 lift is .336 It will work with a flathead or Cragar.
  24. V4F
    V4F
    from middle ca.
    62 pan , I would go to the horses mouth . ask jim , he is a nice guy
  25. 62pan
    62pan
    V4F, I was p***ing the info along for orangeamcs not asking questions.
  26. V4F
    V4F
    from middle ca.
    ooppss ................. sorry
  27. bangerbob
    bangerbob
    Off Idle Hesitation!!! This is what I have:
    stock block and pistons
    Holly 847 carb and homemade down draft intake
    34 Ford dist with centrif advance
    5.5 Snyder head
    Everthing is good, spark 5 deg bdc, accelerator pump squirts good, idles great.. Has a slight hesitation off idle that makes the car jump then it is fine... AM I FIGHTING THE 65 POUND FLYWHEEL M*** ? ModA 531.jpg
  28. Juggler
    Juggler
    HAL McDowell on the sand at Pendine last weekend
    96.2608 mph (half mile course + 110 yards through the traps)
    29 Speedster and Dannerr like this.
  29. orangeamcs
    orangeamcs
    Banger bob have you played w the timing?
