Technical Rear seal kit for 51 Pontiac
Discussion in 'Traditional Customs' started by SJ, Jun 5, 2016.
  1. SJ
    SJ
    from Boise
    Does anyone know where to source a rear seal for a 51" Poncho? Ive tried all the normal sources like Kanter and Pontiac restoration, dumb question but is there another option for a seal other than an oem spec ie: could I find something similar on Summit that is semi universal that will work for a 268?
    I'll preface this by saying I am not much of an engine guy, so if someone knows of an option I would appreciate the info.
    Gracias
    SJ
  2. Joe H
    Joe H
  3. SJ
    SJ
    from Boise
    Thanks Joe I really appreciate that.
  4. Joe H
    Joe H
    If you use one of the seals, follow the directions to a T. It will not leak! The material they use works so good, I locked up a 455 Pontiac by packing it just a little, the second seal I follow directions and it worked perfect, and still it.
    Joe
  5. SJ
    SJ
    from Boise
    Thanks again Joe for that info I just got my order in. You saved me the longest hunt in internet history :)
