Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. Quain Stott
    Quain Stott
    The Alcohol guys only use gas when it's REAL cold out side (at least the ones that know what there doing do) and then it's a mixture of about 75% alcohol and 25% gas. Gas floods the engine real easy if you get too much in there and you would have to miss it bad to flood it with 100% alcohol.
    I guess I'm taking injectors off for Montgomery, they are just to big for the little 331. I have a smaller set I'm going to fix for it. It's going to be candy *** carburetors for Montgomery tho.
  2. Higgy's Henry
    Higgy's Henry
    Whens the official Knoxville recap show being posted?!!!
  3. Quain Stott
    Quain Stott
    They are running a little behind. Mitch has to drive over an hour each way to help with the editing and do the voice overs. Plus we are adding another person to talk with Mitch to make it sound better. This deal is costing a fortune and Mitch is doing his part for free. I never knew there was so much to doing a show this way but we have dove in head first as we do everything else LOL. I'm thinking it will be out this week.
    catdad49, 3dnsouth, saltflats and 3 others like this.
  4. Dog_Patch
    Dog_Patch
    Having a hell of a time finding the 'wheelie spot' on the front ladder bar mounts. I had 2 holes that were almost 2 inches apart. The low hole causes it to stand straight up. The higher one hardly pops the wheels up. So I drilled a new hole right in the middle ;) We'll see what it does Saturday!
  5. Bad Banana
    Bad Banana
  6. it would have to be below 45 degrees before I would use gas. I agree with the ease of starting on alcohol.
    Dog_Patch likes this.
  7. Mike Colemire
    Mike Colemire
    My dragster started best on 87 octane. I had a nitrous plate I used with a small pump from napa and a jr dragster fuel tank. I'd pull the lean out back and run it back on gas to heat up the engine and keep the oil clean. It had a Ron's terminator on it and ran alky. 15 1/2 to 1 comp, 582 BBC, 4.50's in the 1/8. It would kick back on racing gas, and it was running low one day so I poured generator gas in. It started 10 times better.
    Bad Banana and Dog_Patch like this.
  8. What the Mad Banana said! If your new middle hole isn't right, put it on the bottom hole, and start moving 10 lbs at a time to the nose, until the hang time is where you want it, and it's still SEG style.
    Dog_Patch, Bad Banana and Quain Stott like this.
  9. tylercrawford
    tylercrawford
    from Buford, GA
    *cough* instant center *cough* :D
  10. Dog_Patch
    Dog_Patch
    I prefer the ever elusive Gravity Spot :) or ******
  11. Tyresmoke
    Tyresmoke
    from Norfork
    Tony how about the specifications of the Dodge for season 1 and the mods you have done this year
    Sent from my SM-T805 using H.A.M.B. mobile app
  12. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Well ???? It's sunday!
    Higgy's Henry likes this.
  13. Higgy's Henry
    Higgy's Henry
  14. dirty old man
    dirty old man
  15. saltflats
    saltflats
    from Missouri
    Give the champ a brake
    You know he has to compose himself.
  16. Higgy's Henry
    Higgy's Henry
    WHAAAAAAAAAATT?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  17. Dog_Patch
    Dog_Patch
    Wow that event was tough to describe :cool: We got there and started sweating
    And then we were treated to some true Southern hospitality with a low country boil
    Then it rained -
    The power went out. But - the first car to the finish wins! Right?
    The event made it to the semi finals and then the storm was Biblical - sitting on the starting line and watching huge bolts of lightning come down - I'll never forget it! Hottest - wettest - coldest I've ever been in one day :cool:
  18. dirty old man
    dirty old man
    Well , how many times did you get to run and how did Q&D perform?
  19. Dog_Patch
    Dog_Patch
    I got in 3 runs two were about 6 flat and one was a 3rd gear start. :confused: Got to pay attention to the Jerico ..... It never did wheelie so back to the low hole and possibly add some weight up front.
  20. allwilly
    allwilly
    Dat dere video is bad***!
  21. Quain Stott
    Quain Stott
    When you go to the top hole do you readjust your wheelie bar. If not that's your problem because it shouldn't make that much difference just moving it up or down an inch or so. You should see a difference but not that much.
  22. Dog_Patch
    Dog_Patch
    lawman likes this.
  23. Dog_Patch
    Dog_Patch
    The wheelie bar is in the same spot it was in when the Knoxville photo was taken. The clutch might still be to tight on the base pressure. I never did back it out. Its completely toast now - cooked it good on my 3rd gear launch. Its been getting abused until I found the clutch pedal was sticking. This week I'll pull it and and take a look.
    Quain Stott likes this.
  24. dirty old man
    dirty old man
    No rest for the weary, huh?
  25. enloe
    enloe
    from east , tn.
    Or the WICKED
  26. Quain Stott
    Quain Stott
    Same spot by measuring and readjusting after the bar move or same spot but way lower because you rotated the housing to move the ladder bar up. It's a mistake some make, you have to readjust the wheelie bar after rotating the housing.
  27. Dog_Patch
    Dog_Patch
    Oh gotcha. Now I recall you telling me this before. I didn't move the wheelie bar during any of the front bolt testing - just adding to the confusion.
    Yeah Dave lets see:
    - 5/8" stroke so now 467 cubic inch - was 400 cubes
    - 280 @ .050 cam - was 270 @.050
    - 15:1 compression - was 11.5:1
    - stroker crank is 15lbs lighter than a stock crank
    That's about it. I have the rev limiter disconnected - it was too inconsistent with the mag.
    Darlington is August 5th. Plan to do some testing someplace before that though.
    Tyresmoke likes this.
  28. Quain Stott
    Quain Stott
    If you wasn't adjusting the wheelie bar after a ladder bar move that's the problem. When you raised the ladder bar in the front you just lowered the wheelie bar a bunch and there goes your wheelies and traction problem. Lowered the ladder bar back down in front wheelie bar back up instance wheelie's. Leave the ladder bar where it is and reset the wheelie bar.
  29. Dog_Patch
    Dog_Patch
    This Facebook thing is really confusing but has a ton of good pics and videos of the race. Here are a few I snagged.
    13392111_577324459105259_383493052576765141_o.jpg 13418620_577324889105216_8658977590824464492_o.jpg 13458669_1324490000911614_4586759767540512181_o.jpg 13443286_1324490240911590_373312199432054955_o.jpg 13442598_1324490350911579_3021857539309539924_o.jpg 13443197_1324492950911319_2475175566176841515_o.jpg
  30. Dog_Patch
    Dog_Patch
