Hot Rods Clutch flight 727
Discussion in 'The Hokey Ass Message Board' started by 39chevygasser, Jun 5, 2016.
  1. 39chevygasser
    39chevygasser
    I'm building a C/Gas 39 chevy with a original B@M clutch flight i need a throwout bearing and a clutch fork any info or help would be awesome
  2. Jalopy Joker
    Jalopy Joker
    try: smrtrans.tripod.com/smrtransmissions/id40.html
  3. 39chevygasser
    39chevygasser
    thanks ill give them a call
  4. Kan Kustom
    Kan Kustom
    The hot setup back in the day.
  5. 39chevygasser
    39chevygasser
    yes it was the car has had this trans since they first came out with clutch flites mid 60s iirc
    turboroadster likes this.
  6. sunbeam
    sunbeam
    What bellhousing are you running? The through out bearing will have to be compatable with a long pressure plate.
  7. 39chevygasser
    39chevygasser
    I'm running a lakewood blowsheild thats been on the car since the 60s
    and a Borg@beck PP
  8. greg32
    greg32
    from Indiana
    Try search, couple of older threads about these and clutch turbos you'll find interesting. And part sources.
  9. sunbeam
    sunbeam
    I don't see why the clutch release arm would not be the same a manual trans. and the through out bearing the same as long as front bearing retainer is the same size and has a flat face. If the trans has a manual valve body be prepared for a bone jarring 1-2 shift with out the cushion of the torque converter.
  10. 39chevygasser
    39chevygasser
    yes it's a manual Valve body ohh I'm well aware of the hard shifts
    I've searched around but nothing really I've called maverick performance which is one company still making the clutch turbo's he couldn't help me cause my throw out bearing ID was bigger then there's
    1.62 Vers there's is 1.42
  11. volvobrynk
    volvobrynk
    from Denmark
    I'm no expert, but pics of what you got, might be help towards what you don't have!
    Because some of these guys have done mad skill.
    Just use plenty of photos, then hard tasks becomes possible!! :D
  12. 39chevygasser
    39chevygasser
  13. Last edited: Jun 7, 2016
  14. sunbeam
    sunbeam
    Timken site jumps from 1.50 to 1.73
  15. seb fontana
    seb fontana
    from ct
    ID of bearing its self or the collar that holds it? The area that the collar slides on looks a little short but if things have worked in the past we should be able to get them to work again..
  16. greg32
    greg32
    from Indiana
  17. 39chevygasser
    39chevygasser
    No luck finding a throw out bearing still might have to just make something [emoji53]
  18. 39chevygasser
    39chevygasser
    can't believe its this hard to find a throwout bearing
