Customs 47 Plymouth disc brakes
Discussion in 'The Hokey Ass Message Board' started by MWWADE, Jun 12, 2016.
  1. MWWADE
    MWWADE
    I would like to replace my stock 47 rearend with a later model rearend with disc brakes. I would also like for the stock rims to fit the new rearend. Then I would like to install disc on the front of the car. Any ideas on this? Thanks in advance for any help!
  2. porky55
    porky55
    Explorer or jeep rear end should be in the ball park. Both offer disc brakes. Scarebird is where I got my front kit
  3. 53 hemi
    53 hemi
  4. MWWADE
    MWWADE
    Porky, will the stock rims clear the disc?
  5. raff23089
    raff23089
  6. 55 dude
    55 dude
    your stock rims won't clear the calipers, my daily is a 98 grand cherokee and i would go with the explorer rear end since the dana 35 is junk in my opinion.
  7. MWWADE
    MWWADE
    Will the stock rims fit on the explorers?
  8. 50dodge4x4
    50dodge4x4
    If you have 15" stock rims, they may clear the disc calipers (front and rear) if they are spaced out a 1/4". The issue is disc brake wheels have a dish built into them where the wheel mounts to the hub, and the stock wheels are flat there. You need the extra space to clear the calipers. The original wheels fit both the front rotors and the Explorer 8.8 disc rotors when there are not calipers mounted.
    If you have 14" wheels, they will not clear the rotors or the calipers. If you are running radial tires on those 40s wheels, the wheels are probably flexing when you turn! The basically flat centers are not up to the grip of today's radial tires. Then, if you use disc brake wheels, your hub caps might not fit. Despite the challenges, the disc brake upgrade is worth the effort. Gene
  9. Jeepnjay
    Jeepnjay
