Looking for info
Discussion in 'HA/GR' started by CrkInsp, Jun 4, 2016.
  1. CrkInsp
    CrkInsp
    from B.A. OK
    I am looking for info on a Wolverine cam. I have a cam # 38-0975 with lifters. I haven't been able to locate anything on this cam. All I know is, it is for a 6 cyl with center dist. drive. it has casting
    #CM 1001. I have the lifters (HL2011) that are still in the boxes.
    I would like any info on this cam.
    Thanks
  2. CrkInsp
    CrkInsp
    from B.A. OK
    well it looks like it could be Chry, by the lifters.
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
    Pictures might help.
  4. HAMBsterLady
    HAMBsterLady
    You were right about the lifters. HL2011 lifters Mopar 1968-1992. Brand: Elgin
  5. Daniel Clark
    Daniel Clark
  6. 64 DODGE 440
    64 DODGE 440
    from so cal
    Pictures of the box don't show much. :rolleyes:
    Daniel Clark likes this.
  7. Daniel Clark
    Daniel Clark
    I know [emoji17] that's all I had on my phone. I'll try and get a picture today.
    Sent from my SAMSUNG-SM-N910A using H.A.M.B. mobile app
  8. Daniel Clark
    Daniel Clark
  9. Old6rodder
    Old6rodder
    from SoCal
    Everything's in correct position for a slant 6 cam (though I'm not familiar with that rectangular lug on the back). If it's the same vintage as the lifters, then that's most likely, as that's the only p***enger car six Ma had in '68.
    ps. Are the lifters dumbell style? And is there a cross drilled hole in the rear bearing journal?
  10. 64 DODGE 440
    64 DODGE 440
    from so cal
    Yup, looks like a camshaft.
  11. CrkInsp
    CrkInsp
    from B.A. OK
    There is not a cross hole in the rear bearing.
    The lifters are not dumbbell.
    That rectangle on the back has confused a lot of people.
  12. 64 DODGE 440
    64 DODGE 440
    from so cal
    The rectangle may have been to index it in the machining process. Possibly marine or industrial grind, it doesn't appear to have a large amount of lift.
  13. Daniel Clark
    Daniel Clark
  14. Daniel Clark
    Daniel Clark
    Thanks guys for your help. This fell in our laps. I think it's so cool how it's all there and is so old.
  15. Old6rodder
    Old6rodder
    from SoCal
    The lifters look like they may be the dual use shells type that could take either solid or hydro internals, strictly an aftermarket item. Still haven't found any lobe specs, but will be dealing with Oregon Cam later this year, and will ask.
  16. Daniel Clark
    Daniel Clark
    Thank ya sir!!! Dad has combed the Internet and that came up.
  17. 64 DODGE 440
    64 DODGE 440
    from so cal
    The lifters definite look like hydraulics. Probably a replacement cam for a late model slant as the early models all had mechanical lifters.
