Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. T Hudson
    T Hudson
    Awesome report T-ROD!
  2. Blue One
    Blue One
    from Alberta
    Thanks for doing that. It's much appreciated. I have talked to Jose and was impressed by his knowledge and he also said that he would give me a tour if I came down.
    Looks like a good choice for my chrome work.
    Thanks again.
    Larry
    t-rod likes this.
  3. t-rod
    t-rod
    Glad to do it. Got me out of the shop on my lunch hour.
    Sent from my SM-G386T using H.A.M.B. mobile app
  4. Blue One
    Blue One
    from Alberta
    Getting out for a while is always nice. If I decide to drive down I'll let you know.
  5. Blue One
    Blue One
    from Alberta
    At this point it's looking like I'll be shipping a crate full of parts down. As much as I'd like to get down there, time and funds are better allocated elsewhere. :)
    Thanks for the report and I'll update as time goes by.
    Larry.
    wwilliammc likes this.
  6. t-rod
    t-rod
    That's alright, you can make a trip to Utah later in the hot rod.
  7. Blue One
    Blue One
    from Alberta
    Yes, that will be the goal, a trip to see the salt flats. :cool:
    loudbang and t-rod like this.
  8. t-rod
    t-rod
    Hopefully there will still be salt to see, but that's a different discussion.
  9. Blue One
    Blue One
    from Alberta
    The list of things to do just never ends when you are building a car by yourself. And the hours pile up too. :D
    In preparation for dis***embly and finishing (chroming etc.) I am trying to get every possible thing I can think of fabricated.
    One of the things on the endless list is a set of cycle fenders.
    I want to be able to have them for inspections and registration, however they will fall off afterwards ;)
    I wanted them to be lightweight and look good too so that if I decided to run them at times, then I could.
    I ordered up a set of fenders in fibergl*** from Mark Bull in the UK and then proceeded to widen them to suit my tire size.
    I went to a local bicycle repair shop and picked up a half dozen bicycle forks to build mounts from.
    The shouldered ****on head screws are shortened fairing plastic bolts from a Honda ST1300 motorcycle.
    I ordered 16 of them at the Honda shop. :)
    2 days of work led to one front fender mounted.
    Larry 20160318_112636 (2).jpg 20160523_130104_resized (2).jpg 20160523_130126_resized (2).jpg 20160523_145427_resized (2).jpg 20160523_145453_resized (2).jpg 20160523_145555_resized (2).jpg 20160523_150120_resized (2).jpg 20160523_150139_resized (2).jpg
    Dannerr, Uncle Lee, mctim64 and 8 others like this.
  10. brad2v
    brad2v
    Love the cycle fenders Larry, nice job on the brackets. Consider the idea stolen :D
  11. t-rod
    t-rod
  12. 57 Fargo
    57 Fargo
    The fenders look good so far Larry, you may need to run them more than you think, we have a sheriff up here whose whole life seems to revolve around writing tickets for no mudflaps on pickups!
  13. 57 Fargo
    57 Fargo
  14. Super cool and tidy, Larry. With some threaded bosses welded inside the backing plates that would make fitting and removal easy.....but I bet you have already thought of that. JW
  15. Trucker Jim
    Trucker Jim
  16. t-rod
    t-rod
    The third most common question I get about my car is if I ever get h***led about no fenders. I always ask the questioner if he's an off-roader, and the answer is nearly always yes.
  17. Blue One
    Blue One
    from Alberta
    I'm torn between the fendered look and non fendered. I really lean more towards the fenderless side.
    I know it's a lot of work for something than will sit on the shelf however I wanted to make life easier for inspections and things like that.
    For the most part running fenderless is h***le free in Alberta and apparently in BC too.
    I know lots of guys I both places that have been running that way for many years without issue.
    I just wanted to have the option to have them on or off. The off part will probably win out most of the time ;)
    Bulletnose26 and loudbang like this.
  18. Blue One
    Blue One
    from Alberta
    An update. I finished the front fenders.
    Moved them away from the tire a small amount for better clearance.
    mctim64, loudbang, AndersF and 4 others like this.
  19. The 39 guy
    The 39 guy
    Nice fenders, They look good on the car! Well thought out and fabricated!
  20. Must of been a match stick width the move as they still look very sharp. Very good.
  21. prpmmp
    prpmmp
    Very Nice!!! Pete
  22. Blue One
    Blue One
    from Alberta
    Thanks fellas.
    I had originally used 3/8" thick plywood spacers to space the brackets out from the tires and they were really close.
    I moved them out using 5/8 " plywood for spacers and the difference is much better clearance but still looking good.
    Larry.
  23. bengeltiger
    bengeltiger
    I wondered about that earlier. I know that (at least with motorcycle tires) the tires can increase slightly in diameter at speed. Wrinkle slicks on dragsters would be an extreme example. I think increasing clearance was a good move.
    Car looks great. I've been subscribed for some time now. Thanks for sharing your build.
  24. Mr. Mac
    Mr. Mac
    Good thinking on the fender's, I like them of co**** I like your hole car.
  25. Blue One
    Blue One
    from Alberta
    I am working on the rear fenders and mounts.
    When you remove the front fenders all you see are a couple of mounting holes in the backing plates.
    For the rear I wanted to have nothing left if I remove the fenders. No brackets, nothing. :)
    So I made a couple of band brackets that wrap around the QC and the fender braces will mount to them.
    mctim64, brad2v, loudbang and 3 others like this.
  26. Blue One
    Blue One
    from Alberta
    No pictures this time around.
    The rear fenders happen to be a slightly different radius than the rear tires I'm using so a little bit of slicing and fibergl*** work is underway to adjust the radius.
    I'm using the same technique I used to widen them so a little bit more resin and gl*** work and I'll have them right.
    Larry
  27. Dick Stevens
    Dick Stevens
    Larry, I am impressed with the front fenders and mounts, can't wait to see the rears on it.
  28. Blue One
    Blue One
    from Alberta
    The rear fender radius adjusted. 6 slice cuts backed with plastic strips and tape.
    Welding rod to hold the shape.
    Next comes resin and gl*** cloth from the inside to fill in the cuts and hold - form the new radius. :cool:
    Dannerr, b-bop, brad2v and 3 others like this.
  29. The 39 guy
    The 39 guy
    Please show your fibergl*** lay up procedure. I know it's been shown before by others but it looks like you had great success with your front fenders and you may have some tips and tricks to share.
  30. Blue One
    Blue One
    from Alberta
    What I did to widen the fenders was pretty simple.
    As you can see in the pictures there are a couple of strips of gl*** showing no gel coat,indicating where the widening took place.
    I sliced them with a zip blade on my grinder, then spaced them to the width I wanted using masking tape and some 1/8 " thick plastic spacers (in my case I made the spacers 3/4"wide.)
    Then using strips of thin plastic cut out of windshield washer fluid jugs I taped them to the outside of the fenders as a backing /mold .
    After that it was a matter of mixing the resin (pulling out the spacers ) then brushing it in the inside followed by a few layers of fibergl*** cloth soaked in resin.
    Once they have cured you can peel off the plastic and tape, the resin doesn't stick to it.
    A little bit of sanding later with the DA and maybe a skim of filler before epoxy primer and you will never miss the gel coat.
    Uncle Lee, b-bop, brad2v and 3 others like this.
